Everything posted by mtaylor
SOLEIL ROYAL 1669 by michel saunier
mtaylor replied to michel saunier's topic in - Build logs for subjects built 1501 - 1750
Simply stunning work, Michel. -
The "like" is for your work, Patrick. You have my sympathies for the loss of your mother. Edit: just discovered numerous typos.
The railings look pretty perfect from here, Moxis. But then, things never look perfect to us when we're building.
Which flag(s) would a British Navy ship fly in 1830s/40s?
mtaylor replied to RPaul's topic in Nautical/Naval History
This might help... http://tmg110.tripod.com/royal_std.htm -
I'm just following along quietly, Denis and enjoying the ride. Lovely and creative work you're doing.
- 378 replies
- t78 norden
- billing boats
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Nenad, That appears to be a good plan. Sometimes at exact scale, things don't look quite right. Your eyes will be the best judge.- 4,152 replies
- cutty sark
- tehnodidakta
Welcome to MSW, Keith, from a former Buckeye. Local hobbyshops seem to only carry AL kits for some reason. Have a look around here (the front page has a pile of links to various on line resources) and you'll see kits from all over.
HMCSS Victoria 1855 by BANYAN - 1:72
mtaylor replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
That sounds like a great trip, Pat. Take plenty of photos for us to drool over.- 993 replies
- gun dispatch vessel
- victoria
Looking great from here, Piet. I'm wagering that the searchlight will turn up just after you have painted and/or installed the mast. Seems that things work that way.
- 378 replies
- java
- pacific crossroads
Welcome back, Doris. The plastic models are wonderful. Thanks for the links. The work on Royal Katherine is amazing.
- 1,035 replies
- royal katherine
- ship of the line
Thanks for the comments and the likes. Well, reworking the cannons are out I can't reliably jig them into any tool I have for turning without damaging them or the cannon suddenly rotating on the cascabel. Oh well... I have 12 of the 24 carriages (wood parts only) assemble. Fiddly things and since the upper deck(s) guns are even smaller, I'm going to go with a different design. Once all 24 are assembled, I'll add the hardware, blacken the barrels and install them. Drilling for the eyebolts, making the training rig, etc. will follow. For those keeping score, hull is pierced for 26 ports on the gundeck, but the French (as this point in time) left them unfilled for access to anchor cables, etc. Also, there two are on the forward side of the stoves/kitchens and room to work them (and for recoil) is limited. I'll post some progress photos once the carriages are assembled and also as I make them ready with all the hardware, etc.
I'll answer what I can... but it's been a long time.... The two Starboard Stern Timbers... use the Port and just flip the drawing. The other parts I don't think we ever had as far as plans. The -481 sheets were pulled and replaced. You might look through the Full Build logs and see what the others have done.
Indeed what Carl said. She does look to be a speedy vessel. Beautiful work, Pat.- 993 replies
- victoria
Simple Framing Question
mtaylor replied to t5956ws's topic in Building, Framing, Planking and plating a ships hull and deck
Which ship? The thickness/width, etc. was a function of ship type, nation, contracts, and size (length and breadth). -
Surprisingly good tweezers...
mtaylor replied to monkeysarefun's topic in Modeling tools and Workshop Equipment
I'm loving them and I can see where dropping one would be bad. Even worse if lands pointy end on your foot. -
Ship lettering
mtaylor replied to rlundy90's topic in Painting, finishing and weathering products and techniques
Lots of stationary shops carry them in assorted sizes. If none are small enough then Google is your friend. -
Lou, Do-overs seem to part and parcel to model ship building. Sometimes is because of errors and other times it's because we know we can do better. So don't get upset or feel bad about ripping off something to do it again.
