Everything posted by mtaylor
HMS Victory by willz
mtaylor replied to willz's topic in - Build logs for subjects built 1751 - 1800
Very ingenious method of making those pieces, William. -
Thanks for the "likes" and comments. Pat... I don't think DARPA will care... they have bigger lasers... much bigger like mulit-MW. Here's the update.. Center line planking is finished and sanded. I've added the bitts that needed to be installed before the planking was done. I'm working on the three ladders going down to the lower deck while I still have access to that. I'd hate to drop one and then figure out how to fish it out. Seems Mr. Murphy has been running rampant around these parts lately. I'm also in the process of building the coamings and grates. I'm going to put blue tape over them before doing the rest of the planking and ceiling just to keep crap from dropping down into the interior. I'm still wanting to keep as much of the furniture out of the way as I can for the ceiling spalls so those other bits and pieces will have to wait. As a sidenote, I only sanded of the loose char and ash as ended up with a nice thin black line between planks for the caulking. Pressing on..... and as always, comments, critiques, better ideas, are always welcome.
Beautiful work, Aydin. I'm looking forward to seeing her on the water like everyone else.
- 414 replies
- riva aquarama
- amati
Congratulations on finishing this beautiful model, Pat. She looks a treat in her new home.
- 517 replies
- Endeavour
- Artesania Latina
Yes. I'm using this for straight pieces and curved one for things like beams. The curved one is pretty custom since not all curves are the same. It dawned on my just now, I don't have a picture of the beam jig, just the straight one.
- 967 replies
- hahn
- oliver cromwell
Mike, Have a look a this which I used for sanding the beams... Seemed to work pretty well. the center piece keeps the wood in place yet the beams can move as they need.
- 967 replies
- hahn
- oliver cromwell
Computer routers
mtaylor replied to Greg the peg leg sailor's topic in Modeling tools and Workshop Equipment
Anthony, Since you know someone who has one, will it machine brass? -
Fantastic details, Denis. Almost too many to absorb but keep 'em coming. She's looking a very workmanlike trawler.
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Just wow, Nenad. Her majesty just keeps getting better and better.- 4,152 replies
- cutty sark
- tehnodidakta
HMCSS Victoria 1855 by BANYAN - 1:72
mtaylor replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Beautiful work to date, Pat, along with some very heavy research. It does seem almost a pity to paint and copper that hull though. She has some good looking lines.- 993 replies
- gun dispatch vessel
- victoria
Thanks for the comments and the "likes". Things have been somewhat at a standstill while I test "feedtrough sheave" making... so far I'm not happy with the results. I'm also finishing up the thick stuff center planking of the gundeck and discovered a few challenges... like the plans seem to be distorted near the bow. The centerline veers to the starboard by a max of 1/16" which means much of my centerline planking is a tad off at the bow. I'm correcting this as I wish to cut the deck planks on the laser. Will it be easier than hand spiling? Probably not, but there's a lot of fun running the Deathstar and I'm pretty happy the way the thick center planking is coming out. Lastly, I'm waiting for a new lens for the Deathstar. Current lens is a 2.0" (50.8mm) focus length and the one on order is a 2.5" (63.5MM). What this should do is give me a better kerf with less of an angle (or wedge when viewed from the end of the cut) as the beam will be "thinner". There's a technical explanation but I'll keep it simple for now. I'm in the process of modifying the spacers that hold the table in place to adjust for this additional focal length. Just trying some different things.... I do hope to have a real update with pictures sometime this weekend.
Computer routers
I'm thinking that's more like a CNC Milling Machine. One could probably do all sorts of neat things with it including turning cannon. That's if it works to the specs. Chinese machine? -
That is one impressive capstan and the hawk just looks perfect on it. Beautiful work, Wayne.
How to cut a limber board
mtaylor replied to tkay11's topic in Building, Framing, Planking and plating a ships hull and deck
Ah.... Occam's razor strikes again. Simple and elegant, Tony. -
Terry, It will boil down to what works for you. Many of us find it's easier to work the masts and yards off ship. Get as much done as possible and then step. Others go the other way and build the masting and yards up in place. I personally find getting as much done off ship works best for me.
Nice work on the lower deck, Tony. The extra step and research on the knees was beneficial and shows in the appearance.
- 132 replies
- triton cross-section
- cross-section
Wow.. tall order, Mike. I suspect it's as Captain Poison's link shows, you'll need more than one book as there are so many aspects to this battle. Even books just on one ship that was participant will have a perspective not found in others. For example, The Billy Ruffian has details from the crew perspective for 3 major battles.. The Glorious First of June, Battle of the Nile, and Trafalgar. It would be great if there was just one source that covered everything, but I fear that it would be a rather large tome.
So close... Wonderful work, Pat. Just wonderful. And the case is ready to boot. I'm looking forward to your launching and display her proudly.
- 517 replies
- Endeavour
- Artesania Latina
Beautiful build, Mike. Congratulations.
- 225 replies
- chaperon
- model shipways
