mtaylor
Moderators
Everything posted by mtaylor
  1. I like the line at the bottom.. "We are humbly of the opinion the prices he asks are reasonable". Big pieces would have priced higher given the state of the art of glass making back then. Thanks for posting this.
  2. Brian, One thing about scanners.. they don't do exactly 100%. Some stupidity about counterfeiting money.. So... either buy a small ruler or make a small ruler on some paper and scan it with your plans/patterns. I pull the drawing into CorelDraw and adjust that the ruler is correct size, then print. Or... you just copy/print from the scanner/printer (assuming it's an all in one device) and adjust the size as you print. Your foredeck came out great in spite of the problems.
  3. Jeff, Are you speaking of the sheer poles? (See the picture.. circled in red.). The easiest way is a spot of glue on the pole and hold it in position until things set up a bit. Then do the lines. More difficult is to tie some string to the pole, clip it into place and then tie it to the shrouds.
  4. Zoltan, I seriously doubt those are made for this hobby. I've seen them for years in electronics stores, etc. A lot of times they're used with mulitmeters to clip the probes to the electrical connection being tested. You might also check with any electrical shops in your area and see if they carry them.
  5. Stunnngly beautiful, Mobbsie. I'm mostly speechless at this.
  6. On some ships, didn't they fold them into a "U" shape also?
  7. Mike, I'd start here for sourcing: http://modelshipworld.com/index.php/topic/384-where-to-buy-wood/ I've found with the "exotics" that supply varies and a place that had wood I wanted last week, won't have it this week. Jason at Crown doesn't carry any black wood of any sort but he does from time to time have off-cuts. I don't have they Jim Saw, but I do cut planks with the one I have so I know it can be done. Somewhere, I think it's in Grant's Granado log that he made a spacing tool (for lack of a better term) to cut planks from stock. Do you have any other table saw or band saw? I used my 8" table saw at one point to cut up some 2 X 3 X 24 billets of ebony I got from Woodcrafter's (I think that was the place).
  8. <smacks head> I'm glad you posted that Grant. I forgot all about it.
  9. Pear isn't all the difficult for planks nor is boxwood. Cherry can work if you like the color as it ages and don't mind the pronounced grain. It does splinter unless it's well steamed. Beech is pretty flexible and would work also but there is a grain in it. Maple and cherry will work well for frames. If you'll go here: http://www.dlumberyard.com/wood.htmland click on Wood Samples (scroll up as you hover over the various woods) you get an idea of what the woods are like and how they're best used.
  10. Chuck, I agree with you on this point. Back on MSW 1.0, there was a "division" but by materials. Plastics had their own build logs and many of the builders felt like second class citizens. Why go back to that? We were all beginners at some point and if it were not being able to mix and mingle with the experienced builders, most of us would have walked away from this hobby calling it "elitist". We're all just builders and the attitude around here since day one is "helping each other".
  11. JP, I would discount any kit models pictures as kits are notoriously inaccurate. What Ofencer said. The ANCRE monograph by Boudroit is probably the most accurate.
  12. I'm just catching up with this. Nice work and research you're doing.
  13. Hamilton, See if you can find Ken Foran's book on "Modeling With Brass". He's a member here (xken) and his book is most informative. Probably tell you more than you ever wanted to know. Otherwise, I know there's been some mini-tutorials in some build logs, but I'm drawing a blank on which ones.....
  14. Ah.. now I got it. I missed the connection between hands, tension, and buzzing.... Somedays, I'm an idiot should be locked in my room.
  15. Hang in there, Denis. I think sanding is the "story of all our lives" in this hobby. And no, it won't be any of us calling the guys in the white coats with the butterfly nets because the next person they could be picking up could easily be one of us.
  16. Ah.. the weekly fix has arrived. And well worth the wait, too. Wonderful work, Glenn.. just wonderful. Is the everything being glued down the main deck at this point? I'm assuming the boiler/mechanical works are all completed.
  17. I hope you'll test it and let us know, Mike. Blackwood is/was supposedly the original "ebony" a century or two ago. I have no knowledge other than what I read. As for testing... when done, clean your blades and tools with acetone (outside of course). Or, if you'll using the wood and need cutting it again, label the blade and keep it for ebony only. I've found it leaves a residue on the blades and transfers that residue to other woods.
  18. I'm thinking it's one of these from éric lémaillet's webpage: http://maquettes-marine.pagesperso-orange.fr/renommee/renommee.html The other models are just as stunning.
  19. Have a nice wedding, Nenad. You are right about life not waiting. Her Majesty is patient... Been there still myself, fighting with life for time in the shop lately.
