Everything posted by mtaylor
Thanks all. Both drops are finished (except for the acanthus leaves - carvings) and mounted. I've flipped it over back to right side up on my "jig" board and and starting the roofs. This should be interesting for me.... More multi-curves to shape.
I caught myself smiling at those, Jesse. They are looking great.
- 1,306 replies
- syren
- model shipways
It's taken longer than I thought to get to this point. I had a minor issue with wood that had defects unseen from the surface, but that goes with the territory and then also quite a bit going on in "life". There will be another pause coming up for Janet's surgeries, but for the most part, that will just entail my keeping an eye on things during the recovery process. The first drop is essentially finished except for some minor touch up (and the carvings...). I've finessed it to fit the hull and the molding and it just needs a bit of touch up on the sweeping curve from top to bottom before gluing into place. The other side is finessed into place and just needs the final shaping to get the curve and then any touch up work. Once these are done, I'll post both sides and a stern shot. I'll need stern shot anyway for my records and to check for uniformity. I won't be applying any finish for now until the wood has a chance to age and regain some of it's patina. Here's the photos...
Sweet work, Pat. Looking really great.
- 517 replies
- Endeavour
- Artesania Latina
Beautiful work, Glenn. Sorry that the metalwork is over for now. Everything is very crisp and clean and well fitted. Ah..well worth the wait for the weekly update.
Anthony, I'd go with what Bob said. Danny V. did that on his center section he's building and it's very effective.
- 99 replies
- turtle ship
- korean
No CA here... only PVA or epoxy. PVA for wood and epoxy for metal to wood. CA does bizarre things to my sinuses.
- 194 replies
Ok.. I think I understand it. I was just thinking if the linkage could be done under the deck, let the rigging above deck just be a dummy. I do hope you can get it sorted. I want to see a video of her sailing.
- 79 replies
- pride of baltimore
- privateer
(and 3 more)
It's safe to say we have faith in your abilities, Ulises. I too am not sure about aluminum.. styrene or wood maybe?
- 786 replies
- Royal Louis
- Finished
Beautiful work, Bob. Your detailing is incredible.
- 348 replies
- pequot
- cable ship
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
There is more than one stubborn builder here? I'm shocked. Shocked I tell you! That looks like a great solution to the problem, Nenad.- 4,152 replies
- cutty sark
- tehnodidakta
I saw them on Amazon. Does Amazon ship to you? Here's the main search that I used. Just sort through for the size and grit you want (easiest way is the column on the left). https://www.amazon.com/Power-Sander-PSA-Discs/b?ie=UTF8&node=256178011
I quite agree with Brian, John. Leave the photos as they will help someone. Looking pretty good. How does it look from dead astern and dead foreward? Down low I should add. Spiling isn't a bad thing. It can get a bit tedious but once you get into the rhythm, it flows well. I had to spile just about every strake on my current build.
- 194 replies
I hope you get it sorted, Jerry. No way to do a direct linkage to the rudder itself, maybe a quadrant gear setup?
- 79 replies
- privateer
(and 3 more)
Lovely work, Siggi. The frieze came out great.
- 58 replies
- barge
- ships boat
They do make disks for the sanders in "standard" (for some value of "standard") sizes with come with sticky back on them. I use them not just for my disk sander but also when making sanding sticks, etc. Here in the States I get them at the local hardware/lumber/home improvement store but I have seen them online. A variety of grits and types of grit seem to be available for reasonable money.
Jud, On the angles... the hawse holes were not typically parallel to the water or decks. There is an angle downward from inside to outside which seems to have varied depending on country, shipyard, etc. The hawse holes were also lined with lead to ease on the chaffing and wear and tear on the ship and the cable. And lastly, somewhere I read that in hoisting the anchor, there was some greasing of the hawse holes/cable... but I'm sure how common that was. It may have been anecdotal for one incident. When I remember where I read it, I'll dig it out.
Chuck, I'd say play to your strengths. You design beautiful kits with a history. Instructions that are second to none. There's options on purchasing (that's a big plus) such that if the buyer wants better wood, they can get what they need from you and "good wood" from elsewhere. This saves the buyer some cash on the kit. Options on the fittings. You're already basically allowing your customers to "roll their own prices". You have range of kits in work or available. I take it that Winchelsea is next? From what I see, you're doing right by your customers.
