mtaylor
Moderators
Everything posted by mtaylor
  1. It's safe to say we have faith in your abilities, Ulises. I too am not sure about aluminum.. styrene or wood maybe?
  2. I agree on the lines. And a very well done bit of drilling those hawse holes.
  3. Beautiful work, Bob. Your detailing is incredible.
  4. There is more than one stubborn builder here? I'm shocked. Shocked I tell you! That looks like a great solution to the problem, Nenad.
  5. I saw them on Amazon. Does Amazon ship to you? Here's the main search that I used. Just sort through for the size and grit you want (easiest way is the column on the left). https://www.amazon.com/Power-Sander-PSA-Discs/b?ie=UTF8&node=256178011
  6. Always makes me drop me jaw, Daniel. Hat's off on some super sub-miniature work.
  7. I quite agree with Brian, John. Leave the photos as they will help someone. Looking pretty good. How does it look from dead astern and dead foreward? Down low I should add. Spiling isn't a bad thing. It can get a bit tedious but once you get into the rhythm, it flows well. I had to spile just about every strake on my current build.
  8. I hope you get it sorted, Jerry. No way to do a direct linkage to the rudder itself, maybe a quadrant gear setup?
  9. Lovely work, Siggi. The frieze came out great.
  10. They do make disks for the sanders in "standard" (for some value of "standard") sizes with come with sticky back on them. I use them not just for my disk sander but also when making sanding sticks, etc. Here in the States I get them at the local hardware/lumber/home improvement store but I have seen them online. A variety of grits and types of grit seem to be available for reasonable money.
  11. Jud, On the angles... the hawse holes were not typically parallel to the water or decks. There is an angle downward from inside to outside which seems to have varied depending on country, shipyard, etc. The hawse holes were also lined with lead to ease on the chaffing and wear and tear on the ship and the cable. And lastly, somewhere I read that in hoisting the anchor, there was some greasing of the hawse holes/cable... but I'm sure how common that was. It may have been anecdotal for one incident. When I remember where I read it, I'll dig it out.
  12. Al, Don't feel bad. I tend to overthink too much also. Here's to us "over thinkers". On the glass... I think I spent like $15 total on the two pieces.
  13. Chuck, I'd say play to your strengths. You design beautiful kits with a history. Instructions that are second to none. There's options on purchasing (that's a big plus) such that if the buyer wants better wood, they can get what they need from you and "good wood" from elsewhere. This saves the buyer some cash on the kit. Options on the fittings. You're already basically allowing your customers to "roll their own prices". You have range of kits in work or available. I take it that Winchelsea is next? From what I see, you're doing right by your customers.
  14. I did a quick search using iPhone and this seems to be the problem.. http://modelshipworld.com/index.php/topic/12173-photos-upload-and-are-upside-down-how-to-fix And here: http://modelshipworld.com/index.php/topic/1641-posted-pictures-upside-down It's an Apple issue but there are fixes and those two posts have some possible solutions.
  15. Go look in here: http://modelshipworld.com/index.php/forum/47-questionsinstructions-on-how-to-use-and-post-to-this-forumsite-problems-or-suggestions/ I think this has been brought up before. Are you using a iPad?
  16. Hmm... plank length.. Hull... closer to 32-36 foot depending....at the time of Revenge, there was still a lot of old, tall oaks in Blighty. Decks.. 20-25... But you can go with one full length strip instead of scale length. Modeler's choice.
  17. Al, I know there's other ways of doing it, but that's the one that's working for me. You might have to look through the logs, possibly the very first ones that were re-posts after the crash (EweK's and Scottucus) and some of the others like Rusty's, zLed', Rafine's and others and see how they did it.
  18. Jud, Have look here: http://modelshipworld.com/index.php/topic/2700-modeling-shipboard-equipment-a-capstan-based-on-hms-victorys/?hl=%2Bcapstan+%2Bmessenger#entry76875 Particularly post #5. Dafi has done a lot research on this.
  19. Here's what I did and used basically the same method on my Licorne. I have 2 pieces of 1/4" thick glass that are 12 X 12. Lay one down and edge glue the first layer of frames. Do be sure to tape the frame assembly to the underside of the glass or lay it on top and cover with plastic wrap so the frame doesn't stick to it. I put glue on the edges, let it get tacky and then stick them together and put the other glass piece on top. About 30 minutes later, add another futtock. Once the first layer is done, add the second layer (let the glue get tacky first) and then put the glass on and let it cure out. I'm sure others have different methods but that worked for me. I think one of the builders did the treenails as they were building but for that, you'd start with the keel pieces and work your way up.
  20. Funny thing about this topic... everyone has their idea of which ship or type of ships. Yet when one looks at the kit builds there's a big gap. There's the Vic's and Connie's en masse. The odd balls, the work ships, the little known... not so much. Even the scratch area although they are all over the map there's still some in the "majority". The ideal model also seems to be divided by continent or country even... One thing I have noticed is that there is a big aftermarket for parts like what Chuck is bringing out. I'm doing a scratchbuild and yes, I'll be using some aftermarket stuff because I don't have the tooling, inclination, nor the expertise to design and build some parts. Maybe the ala carte method is a good one. It's like buying a basic car and the adding options. The problem is the picking of the basic car or ship in this case. I guess I'm saying, I'd sure hate to be a kit designer and try to figure out the market. :
  21. John, The battens and the thread looked pretty good from the pictures. Look everything over from one end, and then the other end until you're pleased with the plank run. You'll be tapering the planks so use the tick strip method between the battens/string to get the plankwidths at each bulkhead. In other words, if it's say 5 full size planks at the midship line (largest area/bulkhead), then as you move for and aft you'll see that those 5 plank will probably narrow. Since this is a kit and spiling may not be possible with the planking materials, drop planks and stealers will work. Have look here: http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php The Chuck tutorials do explain the tick strips pretty well.
  22. Brian, Welcome to MSW. You've done a great job on the St. Helena. I'd suggest you open a log as your building as help will be available, if you need it, during the process and not afterwards. BTW, there is a club that meets in Portland on the riverfront.
