mtaylor
Moderators
Everything posted by mtaylor
  1. For that difference you'd have to cut 1/32" off the top run and the bottom run if I'm doing my math right. Correct? I'd say go with what looks the best to you. If I recall correctly, the Triton is a 6th rate.
  2. I like it. When I saw the trials, I liked the worn and aged look of the cloth and cardstock but the boat isn't weathered so it wouldn't work. The bond works well, IMO.
  3. No words, Gaetan. The pictures have stunned my brain cells.
  4. Looking grand, Gerhard. Will you be cutting notches in the rest of the keel for the frames? If so, how? I'd think it would be easier to cut them before mounting to the build board.
  5. A special challenge? That is an understatement if ever I heard one. It looks fantastic.
  6. Pete, From the sources (unfortunately all secondary) this seems (operative word: seems) to be true. The English sourced a lot of their shipbuilding materials from other places, such as tar, turpentine, various wood varieties, etc. As for the treenails, I can see the point. Once source did question it but they also looked at other ways of fastening the planks. The staggered timbering and only one treenail (depending on plank width) per frame contact seems to make sense in light of what you've read. Treenails were supposedly superior although I've never found out why the French used a combination of iron nails and wooden treenails.... puzzling to say the least.
  7. Ah... emoticons... Hit the little smiley face at the top of the posting window. It'll load a bunch below the posting window. There's also a bit of light writing about "show all" that opens a pop up with more.
  8. Mike.... I tried to send you a PM but your inbox says it's not taking any messages...????
  9. Well.. I blew it and didn't realize you had two logs for this. I'll kill my post to the other one so you can delete it. I'm still pulling up a chair... somewhere... here or there....
  10. Thanks for all the "likes" and comments. I edited my previous post, seems I mixed up "port" and "starboard".... I'm on hold waiting for glazing to dry. The last window on the port side hit the floor without my knowing it and my foot found it. I made extras but didn't glaze them. Well... I am now. At least I'm not sorting out fitting things, just matching the other side. Yes, Mike, those are all one piece windows as are the stern windows. The dimensions are listed here: http://modelshipworld.com/index.php/topic/5339-licorne-by-mtaylor-pof-316-french-frigate-hahn-version-20/?p=412930 for the gallery windows. There's a picture at the bottom of this post. One frame is not cleaned up and the other is. There's a quarter included for scale. (The quarter is approximately 7/8" or 22 mm in diameter). Carvings are coming... While I'm at it... I wanted a couple of times to PM you.. but it says you can't receive messages. Thanks Pat. You're spot on about confidence and losing the fear of doing something with little to know knowledge.
  11. Not that bad??? No, it's great, sir. Don't beat yourself up because we all our own worst critics.
  12. Don, The only log I've seen so far using one is the original poster's... http://modelshipworld.com/index.php/topic/13427-riva-aquarama-by-aydingocer-amati-radio-a-new-challenge-for-a-so-far-static-ship-builder/ It looks interesting and I can see where it'll be a big help. I'm not ordering one myself at this point as I don't know if the next ship will be a Hahn type or a right-side up type build. Cross that bridge when I get to it.
  13. I think... (operative word here is: think) that I got it. Not as perfect I would like but I've pushed my limits to the extreme. All three windows are in on the starboard side. I might (yeah.. sure... he says to himself... I know I will) re-visit these and see if I can make them better after doing the starboard side. All in all for a first effort at scratching quarter galleries with minimal plans... I'll give myself a B+. A bit of cleanup in the shop, and I'll turn this around to the other side. The next side ought to be a bit faster as I won't be re-cutting windows and reworking everything. That part has been done. <crosses fingers> I'm feeling like if I can do these galleries... I'm ready for anything. Even carving.
  14. NIce planking, Matt. It looks good enough to just finish it and not add the second layer.
  15. I daresay you're right... rudder, left side, right side, forward, reverse.. I wouldn't want to try it but I like watching it.
  16. I liked it. Very maneuverable... What did I miss that makes it painful?
  17. There's always Bondo. Comes in several flavors, as such.. cans, tubes, etc. I've used that and one model.. spackling compound. My current method is sawdust and making a slurry of water and white glue (about 50-50 on the water and glue).
  18. Nice work, Mike. It's great to see progres. One thought though it's too late now. When you're drilling holes for sheaves and fixed blocks, while still on the mill after drilling holes, you can connect the holes (instead of using a gouge or files) by using the drill bit (or change out to a mill bit of the same size) and make that groove. Try it on some scrap next time and you'll see what I mean.
  19. Fantastic micro work. I'm surprised you could make something that tiny functional. Very well done.
  20. It sounds a like a great adventure to do this. I'll go read the link, look up the names you mentioned and not clog your build log.
  21. NIce scarph joints, Mike. Always better to be a bit tight than too loose. Tight can be fixed.
  22. It's good to see that you get to make a bit of sawdust, Walter. You're off with a good start...
  23. Pat, Faking it will work. I've set up the parrels and trucks off ship such that there ends up a single line coming off each end of the parrels much like a necklace. I then wrap and tie the parrels to the yard. I hope that makes sense. If not I'll try to find a picture or make a quick drawing.
  24. Then they should scan it so they have the drawing for when that one falls apart. Engineering departments do that all the time for that very reason.
