Everything posted by mtaylor
I daresay you're right... rudder, left side, right side, forward, reverse.. I wouldn't want to try it but I like watching it.
Filling - How do you do it?
mtaylor replied to mikiek's topic in Painting, finishing and weathering products and techniques
There's always Bondo. Comes in several flavors, as such.. cans, tubes, etc. I've used that and one model.. spackling compound. My current method is sawdust and making a slurry of water and white glue (about 50-50 on the water and glue). -
Nice work, Mike. It's great to see progres. One thought though it's too late now. When you're drilling holes for sheaves and fixed blocks, while still on the mill after drilling holes, you can connect the holes (instead of using a gouge or files) by using the drill bit (or change out to a mill bit of the same size) and make that groove. Try it on some scrap next time and you'll see what I mean.
Fantastic micro work. I'm surprised you could make something that tiny functional. Very well done.
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
It sounds a like a great adventure to do this. I'll go read the link, look up the names you mentioned and not clog your build log.- 4,152 replies
- cutty sark
- tehnodidakta
NIce scarph joints, Mike. Always better to be a bit tight than too loose. Tight can be fixed.
- 969 replies
- hahn
- oliver cromwell
It's good to see that you get to make a bit of sawdust, Walter. You're off with a good start...
Pat, Faking it will work. I've set up the parrels and trucks off ship such that there ends up a single line coming off each end of the parrels much like a necklace. I then wrap and tie the parrels to the yard. I hope that makes sense. If not I'll try to find a picture or make a quick drawing.
Brig USS Enterprise 1799 info gathering
mtaylor replied to CharlieZardoz's topic in Nautical/Naval History
Then they should scan it so they have the drawing for when that one falls apart. Engineering departments do that all the time for that very reason. -
Pat, If it's not too late, pin the yard to the mast. It'll give you some stability and hold the mast in position.
Oh... a copy... that changes everything then. -
Alex, I don't think your wrong... but there might be other stipulations on the plans or with whoever gave them the plans. Perhaps the issue is that they're worried that someone will take the plans and turn around and sell them like certain pirate sites do? Might be worth a short email explaining that they're for personal use... Then again, some museums are really protective which limits their usefulness as a research resource from a distance. -
Thanks for the comments and "likes". It's mostly just fiddly work in Corel Draw. No programming as such, David. Which makes me very happy. Well, all has not been quiet here in the shipyard. making progress. On the down side, it is slow, slightly maddening work to translate a 2D drawing into a 3D part.... Luckily, when the first side is done, the second side should go a lot faster. I've got two of the three windows glazed and in place. The third is currently somewhere in the workshop with the glazing drying (I'm using liquid glaze). I've probably cut and re-worked, and re-cut 20 or wo windows to get to this point and I find them very fiddly indeed. I've started working on the gallery roof(s) and drop(s) for both sides but have nothing to show in photos yet. So here's the two windows in place. Feel free to speak up if something is awry while I can still get access to the part. The slight (ahem) misfit at the bottom of the taffrail where the lower molding meets will be hidden by carvings. I've started those also....
Amen to the manta, Greg. I was thinking the same thing about cross-sections, etc. It reminded me of Jeronimo's Bon Homme Richard done in 3 sections.
- 889 replies
On the actual ship plans (and not all kit plans have them) there's the lines drawings. If you'll go here and look at Russell Barnes article on interpreting line drawnigs, you'll see them. What Ben is doing is using those type of drawings. The waterlines on the body plan give references (not actual waterlines as we think about it) to height above the keel. Then he's using the warterlines drawing to get the shape of the hull for beveling. I think that with most kits, most builders just fair the bulkheads using a batten strip and don't go to this trouble.
Can i live without a BYRNES TABLE SAW
mtaylor replied to shihawk's topic in Modeling tools and Workshop Equipment
Al, Have a look here: http://www.hobbymillusa.com/byrnes-saw-operation.php Jeff has guidlines for teeth count for different thicknesses of wood. -
I too, know next to nothing about sailing these but what you're showing seems reasonable and less complicated than what the plan called for.
- 64 replies
- 18th century longboat
- model shipways
It's still amazing work you're doing, Greg. Wood kits require a lot of bashing also along with all the poor fit of parts, etc. I'm not sure what it is about ship kits. It might be the markets. Kids seem to be interested in the RC cars and there's the trains and planes. The hobby shops I've been to seldom carry a good selection of kits. But, if you ask, they have the catalogs will order. I think it's the Internet.. a bigger selection, cheaper and faster to buy online.
Bill, Would there even have been room inside for the gun crew to work any guns in those ports?
- 382 replies
- sovereign of the seas
- carving
Looking great, Mick. I like that cutting jig for the ports.
- 504 replies
- washington
- galley
Your buddy could be right. The photos do look like the real thing. Wonderful work, Neal.
It's a pity that the Admirals are spoilsports. That is impressive and a feast for the eyes, Dave.
- 962 replies
- ship of the line
