Everything posted by mtaylor
Go to the very first post and hit "edit".. then (I think) it's "more options" or "full editor" in the lower right hand side.
Soldering dangerously close to the hull
mtaylor replied to popeye2sea's topic in Metal Work, Soldering and Metal Fittings
Henry, I do hope you'll test this first using some scrap plastic for hull.... -
Thanks, Tony. That's good news on the finish.
- 129 replies
- armed launch
- panart
Beautiful work on the Captain's bunk, Giampiero. I like that drawer that actually opens.
I'm speechless... just incredible detail and on such a tiny piece. Well done, Robert.
- 241 replies
- royal caroline
- yacht
Wonderful iron work, Grant. I'm liking the idea of ebony for the guns...
- 456 replies
- finished
- bomb ketch
Echo by Maury S - FINISHED - Cross-Section
mtaylor replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Nothing negative from here, just high praise. Looks super, Maury.- 324 replies
Decided to build the USS Constitution 1/96 Scale Model
mtaylor replied to kmgreene's topic in Plastic model kits
Craig, If you can't find a set, you might take a look at Dafi's (Daniel's) set for the 1:100 Victory. Many of those parts are common parts and the scale is close enough they should work with no fuss and no muss. http://www.dafinismus.de/index_en.html -
Dan, One of these two which have a bigger cutting area, more power, and a motorized z-table. When I bought the one I have, these were roughly $1000 more. http://www.automationtechnologiesinc.com/products-page/laser-engraving/50wlasermachine http://www.automationtechnologiesinc.com/products-page/laser-engraving/co2-laser-engraving-machine-60w I would have to check on the software but it's not MoshiDraw which is crap. And, for my workshop, they're both bigger than what i have now but some serious reshuffling of things would have been involved. If I were going for production, like Chuck does, then it would have to be something like a Boss or Rabbit Laser for more money.
Forget what I said, Henry. I read what was going on in your build log. Resistance might be the best way, but you will need a heatsink to protect that plastic hull. -
Oh... I misinterpreted what you asked on your question about soldering... You're doing this practically flush against the hull then? Can you CA the wire and then touch it up with paint? What I suggested on that soldering topic won't work. Plus you'll have some heat transfer to the brass eyebolts. Edit: Rethink... there might be a way.. Make a jig such that the chain is held at a right angle to the hull. Clamp a metal alligator clip as a heatsink just before the eyebolt. Test on some scrap material as this is going to be risky no matter how you try it.
- 196 replies
- plastic
- soleil royal
Henry, Do you have one of those flexible soldering pads.. like this one: http://www.micromark.com/soldering-pad-6-inches-x-12-inches,7529.html They're flexible and you can cut them with a pair scissors. -
Pat, Looking good on the trucks and beads. I have a question/comment regarding the closeups. Should the beads be bigger than trucks, such that they roll against the mast and trucks don't touch? Visually, what you have looks fantastic, though.
- 517 replies
- Endeavour
- Artesania Latina
That's something worthwhile to look into, Tony. Ebony stain is smelly and doesn't give an even coverage. Ebony is a royal pain. How does the wood take a finish? With ebony stain, it's somewhat hit and miss for some reason.
- 129 replies
- armed launch
- panart
Beautiful work, Dan. And your humor isn't clunky either. The clocks are a nice touch and if any viewer knows here story, they will realize the significance. Thanks for posting this and letting us follow along. It's been a education.
- 108 replies
- andrea doria
- ocean liner
Frégate d'18 par Sané , la Cornélie
mtaylor replied to JohnE's topic in CAD and 3D Modelling/Drafting Plans with Software
As I recall, French frigates didn't have a bridle/chase port mandated until 1787. It was left unfilled until needed and then the gun from the next port back was moved to fill it. On many frigates, this was only port to have a permanent lid. -
Sam, The mirrors can be a bit fiddly... ok.. a lot fiddly. What one does is put a piece of cash register receipt over the target mirror. Say, we need to check #1 (the one at the tube). The paper gets taped to mirror #2. The tube if fired at very low power such that it leaves a small burn mark on the paper. #1 is then adjusted to the burn mark it dead center in #2 at close range and also at maximum range. Rinse, repeat until it's perfect than goto the next mirror. Hmm... I haven't had any success with popcorn because the beam just burns a hole in the bag of Orville Redenbacher's. :D Besides, the average microwave puts out more power than this machine.
Have you had a look at the build logs in the kit area? There's builds such as the Emden, Bismarck, Basilone, etc. Not the same kit or the photo etch but I'd think the principles would apply.
A great milestone, Ulises. Congratulations.
- 786 replies
- Royal Louis
- Finished
Mike, Have a look at Jano's work also. And there's a fairly good tutorial on the Lumberyard page: http://www.dlumberyard.com/articles.html. As for the tiny bits... dental burs. I bought a bunch at a good price on e-bay. New are pricey but if you can bide your time, there's some really good deals there. I'm scared to death of the carving, but getting more confident as I start doing it. Worst that can happen is "feed the scrap box.".
This is the real ship, right? It sure does look real.....
- 728 replies
- le fleuron
- 64 gun
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Sweet work on her majesty's throne, Nenad. And a grand picture of Hothead.- 4,152 replies
- cutty sark
- tehnodidakta
