mtaylor
Moderators
Everything posted by mtaylor
  1. Barry, Here's two links that should help, First Hobbymill's page on the saw (note that this info is good for other saws also): http://www.hobbymillusa.com/byrnes-saw-operation.php And Thurston's webpage for blades: http://www.thurstonmfg.com/cut-off-saws.html I don't have the Byrnes but the Thurston's that Jeff (Hobbymill) recommends are excellent and very reasonably priced.
  2. Ronald, Ask that here: http://modelshipworld.com/index.php/forum/47-questionsinstructions-on-how-to-use-and-post-to-this-forumsite-problems-or-suggestions/
  3. This is a fascinating history, Frolick. I hope you will continue....
  4. John.. there's this topic: http://modelshipworld.com/index.php/topic/11980-solidarity-with-paris/
  5. Maury, Check with John (Texxan5). I don't see them on his webpage but I imagine he can get them.
  6. Those hinges look perfect from here, Michael. I like the way you made them. Fills me with ideas.
  7. Looks fantastic Frank. Even the rigging has weathered look.
  8. Ah.. the basic black dress and the pearls coming up. Sweet work, Patrick.
  9. Great jigs and setups. I'm learning a lot. I like the brass tube for turning round from square. Brilliant!!!
  10. Better buy more cereal boxes, Jason. I'm ending up spiling just about every plank on my build.
  11. I use a silicone spray... spray it on and then after it dries a bit, rub it with a cloth. I've also used Pledge furniture polish and that works well also.
  12. Rob, I'm just following along. I built this kit some years ago and ran into many of the same problems. I later found out that I did the colors wrong (new research) <sigh>. The tower problem goes back to the early days when they were taking the lines off and sorting things out. It's one of the few things Billings never corrected and apparently they did try to keep up with the research. They were the only company to do that which is why they were the "official" kit. I managed to fit the towers in but it was a problem and they are not straight by any means.
  13. "A bit too thick and wide". ????? I'm with the others Jay. Looks good from here. Would some touch up sanding in situ fix it?
  14. Welcome to MSW, Bill. What Chris and Augie suggested is very sound advice.
  15. That's a good question for which I have no answer. However, if you don't get an answer here, ask it up in the Research sub-forum. I think you'll probably get answers there since this area is more for specific questions about kits.
  16. Wow... Looks great, Michael. Sheer artistry.
  17. Precision work your doing, Jay... you got it down.
  18. There's no reason at not to use the scratch section. It covers everything scratch build media.
  19. Indeed... thanks for posting this SOS. Here's to all our brother Marines, past and present. Semper Fi.
  20. Congratulations on a spectacular build, Mobbsie. Impeccable.
  21. MIke, Go with what you're comfortable with. Alan's right... youi'll get better and probably faster the more you do.
  22. Mike, I use an X-acto saw blade.. there's several types and one that worked great is the one that looks like a #11 blade. That is the time saver. The filing and trimming is the time killer but that's part of the job, I guess. I didn't need to worry about an exact fit on the sills as I'm fully planking. I found that I got faster after a doing a couple of them. Still, it's not a project that can be rushed.
