Everything posted by mtaylor
Thinking Things Through - French Frigates
mtaylor replied to mtaylor's topic in Nautical/Naval History
This may be one of things where "close counts". At the scale I'm building at, 1 or 2 inches won't matter on planking or anything wood. I notice that they do the rigging area a bit different and it's just one measurement. But, I do like answers to mysteries but with this, it may not be possible. -
So Pat will have to stop by my place to pick up the leftovers and Mario wants to place an order.... Hmm.... when would I build? And here all along, I thought I retired so I wouldn't have to work.. what could I have been thinking? Pat, I'm not sure there will be leftovers. I always find I short myself when I do this....
Page 95. Gaetan. I believe the discussion on measurements is on page 63. The computer hiccupped after I typed into the translator and I haven't redone it yet. The only version they have of this is French which is why I'm hammering away at a translation via Google Translate and several on-line dictionaries. Thanks for all your help Gaetan. You're a model saver! Thanks Augie. I wasn't aware of that. -
Thank you for the comments and likes. I found some time to make about a dozen more plank clamps from wooden clothes pins (pegs to those who prefer the mother language). I lined the ends with some sandpaper after changing the design slightly. I have planks in the water and planking starts tomorrow. There's a few places I need to touch with sandpaper and also re-do some reference lines that seem to have disappeared...
It's the ANCRE La Belle-Poule monograh, Gaetan. From their website: Author : Jean BOUDRIOT & Hubert BERTI I'm assuming the pouces/lignes are the French inch which, and I might have mistranslated it, are the "old" pouces/lignes. If I measure the figure in the plans, he's larger than the figure in the other two monographs I have from them. So it's possible that the 195/100 is the comparison. although some others are of the form: 8 lignes - 37/100e or 1 pouce 1/2 90/100. Very different to my brain. I'm only trying to sort this out to get the rigging right... so I guess close counts. -
Thanks Mark.. Yes, the pouces are in "French Inches" which was explained as "about 10% bigger". Hmm... I'll have to see if that centimeter reference will work. -
Just stunning, Gaetan. Your carvings are magnificent.
- 728 replies
- le fleuron
- 64 gun
Another question... Gaetan helped with this (for which I'm very grateful) but there's a sticky question in the back of my head. In the monograph, there's dimensions listed (monograph is in French and I'm using Google to translate it) in the following form: "un diameter de 6po. - 34/100e" I understand the "the diameter is 6 inches" part but not the 34/100e part. Can anyone shed some light? Neither I nor Gaetan had seen this before. I'm concerned this might be something vital and not just a restatement of the dimension. -
Here's some proof of life: In the plastic bin... ebony and swiss pear for the main wales. Ebony for the chain wailes and stern planking. I'm going to laminate pear and ebony for the top strak of the main wales. Next to the right, is the swiss pear for the rest of the wales (10 stakes) then swiss pear for the bulk of the hull planking, then there's the planking for above the wales and the upper works. The strips on the bottom are for the garboard stakes and some spares for a bit of spiling. The planking is made from pre-made strips and also from billets as not all the pre-made stuff was usable. The planking pile doesn't look so intimidating now. I'm going to make about dozen so more planking clamps today. Anyway, that's the plan. But we all know about the best laid plans of mice and men....
You might snoop around here: http://nautarch.tamu.edu/academic/alum.htm There's all sorts of info. Some big, some not so big and some small ships...
Nice going, Denis. You could also use Fimo (I think that's the modeling clay... may have mis-spelled it.).
- 956 replies
- andrea gail
- trawler
Lovely rope, Paul. Are you making this yourself? If so, what kind of ropewalk?
Just magnificent.... If only I had the room to go big...
- 728 replies
- le fleuron
- 64 gun
Can i live without a BYRNES TABLE SAW
mtaylor replied to shihawk's topic in Modeling tools and Workshop Equipment
Yep. (short answer). It's eating the wood for the kerf and thicknessing takes it's share. On that, I thicknessed the planks to 1/32 (they were slightly thicker) and then cut in 1/8 wide using .20 kerf blade (230 teeth). It seems to be accurate. I spot check about every 4th plank or so. The key is to make sure everything is locked down on the saw. I'll be starting the blade eater (ebony) later this week....but luckily, it's only the two 'larger' sizes. For those, I bought billets and cut them into planks on the full size saw. I'll be running them down to what I need for wales, railings, and a few of the smallest size for planking the stern above the counter. It will either be a PITA or fun.. not sure yet. -
All this paint available
mtaylor replied to Nirvana's topic in Painting, finishing and weathering products and techniques
Apparently, they're made by Gunze Sangyo and are a lacquer based paint... Here's some links: http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/t/114013.aspx http://www.armorama.com/modules.php?op=modload&name=SquawkBox&file=index&req=viewtopic&topic_id=142542\ http://www.britmodeller.com/forums/index.php?/topic/234946027-mr-color-paints-in-uk-or-alternative/ http://www.heavyarmourstudio.com/InstructTools3.html (about halfway down the page.) There's lots of forum posts but no real info than apparently it's good stuff. -
I think Bob's problem with dust is that he's got a full-size table saw. The bottom is open unlike our modeling saws which are basically a box. -
A very impressive gundeck, Sjors. She's getting her teeth.
- 1,616 replies
- caldercraft
- agamemnon
Is a waterline marker useful?
mtaylor replied to CharlieZardoz's topic in Modeling tools and Workshop Equipment
Charlie, You could make one.. I use this and just tape a pencil to it. When I'm not using it to mark, it's used to pick off a dimension from the plans and transfer it to the model. . -
Bob, I'm milling planking... 1/16 X 1/8, 1/32 X 1/8 and 3/32 X 3/16 (all dimensions in inches). I'm using my table saw as there isn't any other way to do this that I can see. The wood is ebony and swiss pear. As much use as my MicroLux has had, if I were buying a new saw today, it would be a Byrnes. Just for the precision. There a coupe of problems with the MicroLux.. That little motor gets really hot in production type sawing. I usually take a break every 15 minutes or so to let it cool by running it for 5 minutes under no load. I guess I'm just being finicky on that. But the other hang up is the movable arbor. If lets you cut angles. I'm not sure about the new version, but on the old one, the guage isn't accurate and setting it for 0 degrees or an angle requires a bit of fiddling. Same for the mitre.. Mines off 1/2 degree. Not much until you're trying to cut wood to butt up against another piece. like a coaming. I've had to do a fair amount of "bashing" and calibrating of the thing that I wouldn't have had to with a Byrnes.
