Everything posted by mtaylor
Thanks for the feedback and the "likes". JPett, spiling is an option but at this point, I just use a file sometimes in place, other times, remove the plank, shape and re-fit. After I get these first two wales done, I'll mark off the hull and then have to do tapering, spiling, etc. As Michael says, we all do the dance... Between translating the Belle-Poule monograph and planking, I'm keeping fairly busy and somedays, its seems like I don't get much done. Interesting material in the Belle-Poule monograph. The rigging plan is radically different then Le Venus that Hahn used. I see I'll need some feed-through sheaves amongst other things.
<picks self up off floor><brushes off sawdust><low whistle> Wow... that is tiny and lovely at the same time.
- 515 replies
- artesania latina
- whaleboat
Those chocks look perfect, Mark. They should jump right out with the finish. Keep up the nice work.
- 172 replies
- druid
- sloop of war
Pen Duick 1898 by Mfelinger - 1:20
mtaylor replied to Mfelinger's topic in - Build logs for subjects built 1851 - 1900
Thank you for showing how you did that beautiful work on the planking. -
I agree with Druxey... beautiful work, Gaetan.
- 728 replies
- le fleuron
- 64 gun
Your rigging is just as beautiful as the works in wood, Karl.
- 662 replies
- bonhomme richard
- frigate
Thanks Tim for the comment and to everyone for the "likes". I do start with a longer plank and then bend it to shape. The ends that don't get bent get removed and the planked is checked for length, Carl. I think if they don't line up, one of two things will happen... I'll either shape the other side to match, or rip it off and have another go. I think you're right Denis. I'm beyond V1. Well into the Twilight Zone. Thanks Patrick. They're being ironed out as I go. I do find that I tend to post the "not good" stuff as well as the "good" stuff. I think it's part of the learning curve and finding pitfalls. The really nice thing... perhaps the biggest thing about MSW is that we all learn from each other. Back to planking...
Peaksol, I don't have a Proxxen but a Micromark which is similar. Here's my method: http://modelshipworld.com/index.php/topic/9312-need-advice-with-byrnes-saw/?p=274646 It's repeatable and consistent. Just make sure that the blade doesn't get hot since it will distort.
A beautifully done bulkhead, Sjors. I see lots of progress there on the deck and beams... looks great.
- 1,616 replies
- caldercraft
- agamemnon
Well done on the visor. Sometimes a heavy hand and desperation are our friends. And that ice maker... a 1953 Hotpoint? Has that look to it...
- 956 replies
- andrea gail
- trawler
Mike, You might want to post this in the Books section and open a topic for the AOTS Endeavour book. I suspect that anyone who's not following along or a new builder might not see these logs.
- 517 replies
- Endeavour
- Artesania Latina
Thanks for the "likes". Thanks Pat. I've still got my fingers crossed... Next ship won't be French so hopefully the planking will be easier. Thanks Augie. It is a challenge.. But, I wanted the wale's line to highlight their curve. Thanks George. It's the way the plank runs and twists. I am going to run a file over it and get it looking more even as well as sand everything since there's some unevenness in thickness due to the bends and twists. Since this is the first side, I may use it for the "wall side" as I'll do my experimentation here. :D
I'd say either Olson or the blades from Sawbird. I don't have a link as they dropped off my "Favorites" for some reason.....
Druxey, I would assume they had it figured out somehow.. maybe men below keeping the rope hanging down from tangling? I seriously doubt that cable reels (like power and telcos use) were available. I have a hard time just comprehending that they floated the masts to the ship and using manpower and sheers got the masts installed. Moving all that cordage out to the ship for rigging would have been an operation unto itself. I wish there was more historical info, it would be fascinating to know how the heck they did things like this.
Update.. we ain't dead in the water yet..!!! After milling my wood, I spent a fair amount of time sorting out how to put this together.. the wales. There's 12 strakes that start off a 3/32" thick and as they go down to the main hull planking, they thin to 1/16" which is the "normal" planking thickness. Above the main wales, the upper works planking is 1/32" thick. After much experimentation and sorting things out, my approach is below. First two pics are how I clamp things down... This one shows the actual planking... hang with me, there's issues that I know have to be resolved due to some gaps. 1) is the second strake of wales. Solid swiss pear. 2) is the underlayment of 1/32" thick Swiss Pear. This is for the top strake of wales. 3) is the first of the planking for the upper works. Forward of the first port will be heavier planking going from the wales upward (last photo which is from Karl's build of Bohomme Richard.) 4) Ebony for the top wale. It's 1/16" thick to make it easier to bend than the full thickness of the strake. The issues are the end of the ebony needs adjusting. For some reason it drooped while getting it into place. And there's piece near the stem on the second wale where pear split. I'm not overly concerned about it as the bolster for the hawse pipes goes over that. The whole thing will need sanding and smoothing but for now, I'm going to continue on and finish running these to the stern and then get the other side done. I'm also still sorting out clamps. Seems I broke two frames in the process of getting things glue up. I have to not put so much force on those clamps. As always, feel free to click on the pics to enlarge and criticism, different ideas, etc. are always welcome. I'm still learning this stuff.
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
Well said, Nenad. Enjoy the book.- 4,152 replies
- cutty sark
- tehnodidakta
Looks nice and smooth, Popeye. You best keep it indoors for now as with the snow coming, you might lose her.
- 956 replies
- andrea gail
- trawler
I'd have to make an assumption that there wasn't any kind of affair like a mountain climber's or rappelling gear, so maybe a bosun's seat run up to the euphroe? Or one who had climbed the stay though how he would have hung on is the question. Then two men, one on the top and the other at the euphroe? Slackening the stay for them to work from the top, to me would have been problematical as the stay would have to have been loosened to allow this. Though that might be possible. Yes, there would have been much rope hanging off the top to be fed back and forth but when you consider the amount of line, shrouds, etc. being hung and run through everything, it was obviously doable for them. After running the line, I could see men down on the deck pulling the line to tighten everything up.
That's two items of good news... the Cutty is looking great. I think you've got it!!!! And the strike is over.- 4,152 replies
- cutty sark
- tehnodidakta
Looking good, Popeye. I have no idea what's what there, but I'm sure that when it's all together, I'll know.
- 956 replies
- andrea gail
- trawler
Nice to see you resuming work on this one, Dave. I would think you're right about the decals. Beats trying to paint them and get them all the same size and in the right place. Looks great!!!
- 84 replies
- esmeralda
- training ship
Jason, The frames are pretty much made of smaller timbers the way the plans show except they also used chocks. You might go to the scratch build area and have a look at EdT's Naiad: http://modelshipworld.com/index.php/topic/232-hms-naiad-by-edt-160-frigate-38-1797/page-1?hl=naiad or any of the Swan class scratches such as Danny Vada's Vulture: http://modelshipworld.com/index.php/topic/230-hms-vulture-by-dan-vadas-1776-148-scale-16-gun-swan-class-sloop-from-tffm-plans/ or Toni's Atalanta: http://modelshipworld.com/index.php/topic/198-hms-atalanta-by-tlevine-1775-148-scale-from-tffm-plans/ Wooden treenail and iron bolts were used. Also look at some of the other logs (not mine as didn't do treenails) in the Triton area. Such as EWEK's, Rusty's, Rafine's, bbrockel's, scottacus's and pete38. You might want to get a quick look at the others just in case I missed some of the ones that are finished.
Nicely done on a not so easy to do kit.
- 116 replies
- constellation
- artesania latina
