Everything posted by mtaylor
I'm building using the Hahn method also. Attached some pics of the two main tools I used for setting the frames on the buildboard.
Bob and John, I think you'll find that the fastest and best way to get help is to open a build log. If you look at the logs, you'll see what I mean. We're all modelers here and everyone is willing to help if they can.
That makes two of us. I'm learning as I go. I just wish learning wasn't so hard at times.
Cutty Sark by NenadM
mtaylor replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
It could be that we all are quite "mad". Or at least a little crazy.- 4,152 replies
- cutty sark
- tehnodidakta
Done... on the port side at least. I'll finish up the starboard side and then attack the quarterdeck outer bulwarks. Thank heavens they're not as radically shaped. I do, however, really hate macro as I see some things that need fixing before final sanding, like a few gaps in the planking.
Pat, I'm not going to hit "like"... I'm glad that the only damage was to the jib boom as Russ said, it could have been much worse.
- 517 replies
- Endeavour
- Artesania Latina
John, Have a look through the scratch area. There's a few French 74's that have been built or are underway. As for the ANCRE plans, I have the Bonhomme Richard monograph and I've seen the works by others around here that use their plans. You really can't go wrong with them. As I recall, the shipping for the monograph I got wasn't that bad. Thanks for the kind words on my Licorne.
I'm sitting and agreeing with Augie. It's a pity they don't make them like that anymore.
- 49 replies
- amati
- hydroplane
(and 3 more)
Nice work Danny. For the crowns, if you don't want to carve, find the King from a chess set of the appropriate size. One king would give you two half-crowns.
If you cover the plans (after getting them glued down and allowing the glue to cure), do what it says: flat coat them. You can then paint over the lines without any color bleeding through.
Great planking, sir. And without spiling too!!!
- 2,191 replies
- confederacy
- Model Shipways
I just didn't really realize how big that beast was until the last photo. Looking good, Kevin. Both you and the ship.
bench grinder and do you really need one
mtaylor replied to garyshipwright's topic in Modeling tools and Workshop Equipment
Gary, I use a Dremel with a stone for grinding my lathe tools. No need for a bench grinder and no place to store one either. -
I have to learn to stop re-inventing the wheel. There was reason why Hahn did it the way he did it. I've scrapped out all previous methods and did his way. First, I spiled a piece of cherry (2 feet wide X 4 inches thick). Then made Mr. Clamp to get the curve. I soaked the wood for about 12 hours and clamped into place. I ended up with all the curves and bends in the right places. I can live with this. Now to go glue them in place and get the ebony trim fitted and fixed into place.
