Posts posted by archjofo
- JpR62, Captain Poison, FriedClams and 22 others
- 25
Thanks !
Also thanks to you all for the LIKES.
The ratlines for the mizzen mast are ready.
The preparations for the futtock shrouds are in progress. -
Thanks for nice comment. Also many thanks for the LIKES.
Another small stage of the standing rigg of La Créole has been completed: the ratlines of the mizzen mast are finished.
The integration of the shrouded ladders and the signpost blocks is still missing.
In the meantime, a small detail needs to be clarified once again. The side davits for the "Petit Canoes" of the corvette were made of iron and were lifted with a topping lift. These were shorn by single blocks on the mizzen mast.
How these single blocks were attached to the eyes of the ring fitting on the mizzen mast still needs further clarification. Unfortunately, I do not have any pictures of the original model of the relevant area, where one can see more details. In the documents available to me I could not find anything meaningful about this either.
In this respect a question to the experts here in the forum: How could the fixing of the single block/lead block and the continuation have looked like, e.g. as shown below?
I would be very pleased if I could get answers or hints and suggestions. - I would be very grateful if you could send me your comments.
See you soon ... -
- mtaylor, Wishmaster, Tony Hunt and 23 others
- 26
This is a beautiful showcase for a fantastic model ship.
Congratulations for the completion.- mtaylor, Keith Black and aviaamator
- 3
Hello,
I thank you for the recognition.
Of course I also thank you for the many LIKES. Both motivate and give me confidence to continue.Moques de conduits: Mizzenmast
I almost forgot about them, the signposts blocks for the mizzen masts: -
Hello,
thank you very much for the kind words and thanks to all the others for the many LIKES.
Continuation: Ratlines - Enfléchures
It's been quite a while since I finished the ratlines for the main mast shrouds. Especially with monotonous work, it is good for motivation to deal with other details, such as the signpost blocks, in between and thus provide variety.
Meanwhile I am again dealing with the ratlines, namely those of the mizzen mast shrouds, as you can see on the following pictures. The binding of the eye splice at the first and last shroud I have already described in detail in previous reports.- GrandpaPhil, KARAVOKIRIS, davyboy and 24 others
- 26
- 1
Hello, Eberhard,
I really have to try that.- Keith Black and mtaylor
- 2
Thanks for your appreciation.
I have already thought about that. No matter how cleanly you handle the glue, there is always a residue and you might see that.
My philosophy in model making is, only as much glue as absolutely necessary. -
- mtaylor and Keith Black
- 2
Hello,
in the meantime I have made the 1 and 2-disc blocks, the special kind.
So now a total of 30 pieces of this special block type are finished.
As a reminder: it is a kind of guiding block which was fixed in the shrouds. In French these blocks are called "Moques de conduits".
A kind of fairleads, but with discs. -
".. 1.7 mm x .5mm sheaves???.....that is simply astonishing. How in the world is one even able to apply the groove to the perimeter of the sheave?"
Excuse me,
unfortunately I did not see your question and therefore did not answer it.
But in the meantime I have posted a series of pictures for the production of these blocks. Maybe you have already seen them.
The groove is simply made with a needle file.
- Keith Black, FriedClams and mtaylor
- 3
Hello,
thank you very much for your positive comments.
And thank you all for the many LIKES.
That motivates me a lot."Great work. I'm going to give it a try. Can you tell me where you got the patterns for the blocks?"
Hello, Richard,
for this special type of block, which is only attached to the shrouds, there are corresponding drawings in the Atlas du Génie Maritime on plate no. 212.
Do you know the Atlas du Génie Maritime ?
This is a collection of technical construction drawings of the French Navy from the 19th century.
Here the corresponding plate no. 212:- GrandpaPhil, EJ_L, BETAQDAVE and 8 others
- 11
- WalrusGuy, rybakov, Tigersteve and 19 others
- 22
La Créole 1827 by archjofo - Scale 1/48 - French corvette
in - Build logs for subjects built 1801 - 1850
Posted · Edited by archjofo
The ratelines for the futtock shrouds of the mizzen mast are completed.
Furthermore I mounted a single block next to each trestle tree. These are used for the topping lifts of the mizzen boom.
Soon I will continue with the ratlines of the foremast.
