archjofo
Everything posted by archjofo
  1. Thank you all. I´m very pleased by yours nice words. Your comments give me more flavor in the works and I will try to do the best possible result. Here's a little update of my report. Look yourself ...
  2. Hello Karl, incredibly realistic-looking cordage! Can you show us your rope making machine?
  3. Hello, here is the continuation of the building report: The breeching rope is attached to the bulwark with strong staples. Here I show you the making of these staples made of brass wire with a diameter of 1 mm. The staples outboard be screwed with square nuts, as shown in the following picture.
  4. Hello, in addition to the breeching ropes for carronades I am also working on the breeching ropes for the 18 pounder guns. A small detail for the height adjustment of the gun barrels had to be done. The straps of the wood blocks had to be installed. In the background is the breeching rope already seen.
  5. Hello, thank you very much for your kind words and the comments. Here I show the continuation of rigging the carronades.
  6. Hello, I wish you all a happy new year. The building report continues with the breeching ropes of the carronades. The special feature is that the rope in the rear region of the breech is protected by a leather taping in the form of a tube. Here are some pictures of the work to breeching ropes.
  7. Hello, many thanks for the nice comments. Lately, here are little progress has been made. Here are just two pictures of the model. I want to wish you all a Merry Christmas and a Happy New Year.
  8. Hello, the nice words are a motivation again and again. Thank you for that! Under no. 244 of my building report I showed the production of hooks for attaching the gunport lids. This version was not satisfactory for me. The original hooks were of flat metal, not from round material. So I made the hooks again. This time I let them etching of brass sheet 0.3 mm. That's not very expensive. The drawing for the exposure film I made with a vector drawing program. And now here are some pictures that probably speak for themselves, better than my poor translation. Here the comparison: Links of the new hook, etched, the right of the old hooked wire. The last picture for today a look at the starboard side of the corvette.
  9. Hello Karl, thank you for demonstrating the process. Beautiful construction.
  10. Hello Friends, thank you for your encouraging comments. At the bow of the French corvette, a small seawater pump was installed. Through a water pipe with a suction sieve, water was pumped up. In the area of the underwater hull 3 more suction sieve were installed. This suction sieve I made out of brass sheet 0.3 mm. To prepare, I show the following Series:
  11. Hello, it has been some time since my last update to my building report. So I made in the meantime other small but important details. So the timberheads received post covers in roof form. Another detail to protect the hull from the anchor flukes was added. Here you can see some pictures. I hope that you like it,
  12. Hello, thanks for the nice comments. I have to correct a statement. This piece of equipment is not a stearing roller (reel ). Meanwhile, I know that this is a chain-pipe. This part is used for the anchor chain, to let down into the chain locker.
  13. Hello, thanks for the kind words. This component I have now burnished. I think it looks better.
  14. Hello, thanks for the nice comments. Another small detail has been made ​​for the French corvette. It is a roller on the Main deck . This is fixed in front of the main mast on the open Main deck . The making of this steering roller (height approx. 8 mm) was performed in three parts, which I turned on my little lathe. The roller was made of brass. For what purpose this roller was used precisely, is what I can only guess. Because it is in the context with the guide rollers (tourniquet), I see a connection there with the messenger. I also hope on the expertise of one or the other on the forum that explain this more detailed To be continued ...
  15. Hello colleagues, thank you for your encouragement. Lately, I was not very productive. To this end, my scanty results: Various works: boarding ladders port side, eye bolts with rings for the deck and inboard. On the port side still had to be mounted the boarding ladders. This I had made ​​some time ago and given to appropriate explanations. For the open battery deck I made still eye bolts with rings, as well inboard of the gun ports, a total of 60 pieces. Also here is to note again that these differ in the size of the eye bolt on the outboard side. To be continued ...
  16. Hello, the image has edited a well-known model-builder for me on the computer. It looks like a photograph from the 19th century, right?
  17. Hello Friends, today I show some news of my little naval shipyards. In the quarter galleries were still glued the window. The tiny windows were made ​​of acrylic glass. I have fixed this with Micro Kristal Klear. As a consequence I had to install wooden strips on the quarter galleries yet. These are just decoration. Soon it continues here again.
  18. Hello Nils, thanks for your nice comment. There are ordinary micro brass rivets. These were soldered and sanded down. This has the following reason: For mounting two bolts are completely sufficient. Otherwise the installation would be too problematic.
  19. Hello, your positive comments are always pleased me. With other fittings on the outboard walls I want to continue my report. In addition to various eye bolts with rings were also fittings to customize for the fore-channels. One of these fittings is used to hook the lower-studding-sail-boom. The other is for the mooring of the flying-jib-guys. I hope you enjoy the pictures.
  20. Hello Karl, the handrails look very realistic. This is a top performance. The idea with the rings you have to remember.
  21. Hello Nigel, this is an outstanding model. A really very precise work. I hope it goes on here soon.
  22. Hello, many thanks für the nice comments. In between, I will still show you how the portholes of the ventilation hatches are constructed. The glass body with a diameter of 1.3 mm were punched out with a specially prepared punch pliers from an acrylic glass plate. Then they were glued with Micro Kristal Klear in a brass tube piece. The brass tube piece has an outside diameter of 2.5 mm. See you soon ..
