HSM
Posts posted by HSM
  1. No worries, mostly fair comments, but I never suggested kits shouldn't be modified... they should be! That is entirely up to the individual builder.
    You expressed repeated confusion over some of the design choices of the kit, I wanted to explain them, that's all. Sounds like mostly a misunderstanding over the intent of the kit as a beginner's model vs. an advanced one.
    I should have also stated I am not part of ME. I was only hired to re-work the existing Phantom to 1:48, make it POB and generate some illustrated instructions. I did the brass work, but the other fittings, plans, marketing, etc... were beyond my scope of work and I have no interest in the kit's sales, other than hoping for the continued success of a respected ship model company.
    Like I said; your work is beautiful and I can't wait to see the finished model.
    Cheers!
    Jarod.
    www.historicshipmodel.com
  2. Seems there is quite a bit of confusion over the design choices in this kit, so I figured I should try to defend it. I designed the 1:48 scale Phantom as an easy Plank-on-Bulkhead model based on the old solid-hull 1:96 version. Yours is the first online build of the Phantom and your workmanship and technique is flawless, but your build is nowhere near a beginner's level. I am afraid your build log unfairly taints the kit and might give it a bad reputation before anyone has given it a chance and built it "out of the box". I will explain some of the decisions made in producing the 1:48 Phantom, a beginner's level model.
    The planking as described in the kit is not run the way it would have been on the real ship, but it is very easy to complete successfully, and that is the primary goal of a beginner's kit. IMHO, spiling planks like you have so expertly done is beyond what most first-timers would be able to do. The Phantom will be covered with paint and copper anyway, and for a beginner a nice looking completed model is the most important goal. The transom not being planked follows the same design philosophy.
    Similarly, for the deck houses I used brass because it would be easier for a beginner to get a nice looking result. I don't like Basswood for complex structures like these because it is hard to sand and fill and get a nice finish on it. I'm sure the Pear or Box you use will look terrific, but those materials and the tools and techniques you use are well beyond a beginner's kit.
    There must be some scaling errors in the production laser-cut kit parts. For example, the molds with alignment holes were drawn once in CAD, then copied and rotated so the holes are in exactly the right position. Model Expo made me a few iterations of the wood parts and I built and modified the files several times to ensure an easy assembly. The alignment holes were perfect in all of those physical examples.
    I appreciate the build-log, but I just don't think it's fair to buy a beginner's kit, and then build it as a master-level scratchbuild, and then complain about all the reasons that beginner's kit doesn't produce a masters-level scratchbuild. If you were to "kit" your masters-level Phantom, it probably wouldn't make sense to point out all the reasons it doesn't make a good beginner's kit.
    With all due respect and admiration, your workmanship is certainly beautiful and I can't wait to see the finished model.
    Cheers!!!
    Jarod
  3. Hey all, I just published video 5 on making custom photo-etched parts and soldering. Hope it helps someone, or at least is mildly entertaining!
    https://historicshipmodel.com/how-they-are-made
    Next-up I will be making some custom photo-etched brass sheets! Any small, thin details you see on the model such as ladders, railings, window frames, antennas, radars, etc... etc... are photo-etched brass. I will show you how I did it from planning and drawing the parts in CAD to sending the files for fabrication to folding the parts to soldering them together and painting. Lots to cover here, but it makes such a difference in the model!!!
  4. Yes Allan you would be right! I am in Winnipeg, Manitoba just North of where North Dakota and Minnesota meet. Your accent identification is impressive! As far as the fibreglass, I'm happy you enjoyed that segment but I'm sure there are much better videos on the subject out there. What I did worked but the radio controlled model airplane guys do that all the time and likely have better explanations.
  5. This isn't really a build log in the classic sense, it is more of a video build log of my recently completed scratchbuilt 1:144 scale cruise ship Oceanic (1963). I documented the build and have edited it into several videos on the design and construction and figured some here may be interested in seeing how it was done. Hope you like the pictures and videos!
  6. I have a 3D printer (Anycubic Photon) and use it for making multiple complex parts (propellers, anchors, davits, lifeboats, etc... for a scratchbuilt ocean liner I am working on). but for masts and spars you are better off with wood. The 3D parts are amazingly detailed and look awesome when properly processed, but they are still plastic. Making correct tapers, etc... is certainly possible, but you have to have a good 3D modeling package and know how to use it.
  7. I bought this one a few months ago with the intention of pushing it under my work table and pulling it out when I work on an awkward area like high rigging or whatever. For the $200CAD that it costs (tabletop is extra) it is very well engineered and high-quality. I have since moved my chair out of the workshop because everything I do I can now do standing up. I can set the table height to wherever I want it to be comfortable and go to work. I have not gotten rid of the chair yet but I could see doing so in the future. If you spend lots of time in the shop these things are great!
  8. It is always fun to experiment, but I have been there and done that and I don't do it anymore. I had the Micromark PE kit and used it for several projects. It works, but is very time-consuming and finicky. About 75% of my attempts were unusable for one reason or another but with lots of work and practice I did use it to make decent parts for maybe 4-6 projects before I gave up.
    Now I send .DXF files to https://ppdltd.com/ and a week later receive perfectly formed parts.
    Cheers and good luck, however you decide to make your parts!
  9. I bought an 8050 (thanks again for the recommendation John!) and love it. I haven't used my old flex-shaft dremel in months. The battery seems to have sufficient run time, at least for me. I have never had it go flat or slow down during a job and I use it daily. The fact that it doesn't remember your last set speed is the most significant drawback to this tool. It can be quite annoying when you are doing lots of slow speed work and have to continually be pushing buttons. I put a jacobs chuck on it and it blocks the lights in such a way that there is light everywhere EXCEPT where the blade meets the work! On the possibility of the battery getting weak over time, I have had mine for 6 months and if it were to die right now I would spend the money to buy another one. I like it that much.
    It is not perfect, but is well worth the money for the cordless convenience. I don't think you would regret buying an 8050.
  10. If you were asking about the Nonsuch built in 1650 and sailed into Hudson's Bay then yes there are very good plans available. I have a set from the Manitoba Museum where the reproduction is housed in my hometown of Winnipeg, Canada. The plans are 1:24 scale and there are probably 15 or more large, detailed sheets. They must be builders' plans because there are some minor differences between the drawings and the physical ship, so they are not "as-built" plans. I started building a scratchbuilt Nonsuch several years ago in between commissions but then got too busy with other projects and have never been able to get back to it. It is an absolutely beautiful ship!
    Jarod Matwiy
  11. On 10/18/2017 at 4:28 PM, John Allen said:
    You really need to look at the Dremel Micro 8050.......
    Thanks for the suggestion John! I have had 15 great years out of my corded Dremel, and wasn't even thinking of replacing it until I read your review, and then other reviews online. I have been leery of battery operated tools in the past, but for smaller jobs (probably 80% of them) this will be great! I will keep my old, powerful corded Dremel and I'm sure the two will complement each other well.
    Will stop at Home Depot on my way home and pick one up :-)
  12. Military modellers have literally THOUSANDS of figures available at a scale of 1:35 and I am sure you will be able to find figures posed and dressed exactly as you like. I just ordered figure sets from HobbyInc for figures I required for a diorama to copy a famous photograph of a meeting between King Aziz of Egypt, FDR, Admiral Nimits and an interpreter that took place on the cruiser Quincy. In my case I had to find clothing and poses that matched the photograph and was able to match each figure pretty accurately.
    The military figure kits come with the body parts all separated so you can mix and match if you don't like the arm position of this figure you can take one from another figure.
  13. I generally put the line through the pin-hole, then around and through again, then I put the pin in the hole to hold it in place. Once I have adjusted all (or most) of the rigging I glue down all of the pins and clip off the excess line. I then add rope coils of appropriate sized line that I make off of the model. You are right... If they yard is down then you would have less of a coil than you would if the yard is hoisted and there would be lots of line to coil.
  14. I am working on the Euromodel Friedrich WIlhelm zu Pferde (strange... spellchecker doesn't like that name!) and am wondering about the shroud run on the mizzen mast.
    The deadeyes for the fore and main mast have wood spacers (channels) that hold them away from the hull and there is room for the rigged shrouds to clear the bulwarks. The deadeyes on the mizzen mast are attached without the spacer to hold them away from the hull, and there appears to be no way to get the shrouds to clear the bulwarks. The shrouds are forced to bend around the hull and I am certain that would never happen in real life. The shrouds would chafe badly and the railing on the poopdeck would be excessively stressed.
    My model will be built admiralty style without masts or rigging so I will likely install the deadeyes as shown on the plans, but what am I missing here?
    Attached are some photos that show the area:
  15. On 2017-03-21 at 8:47 AM, S.Coleman said:
    "Do some ships have removable belaying pins for different configurations? Just noticed the empty hole next to the pin in the picture."
    I think all belaying pins are removable. If the lines need to be freed quickly a sailor can just pull the pin out and let out the line. If it were me I would end up with a tangled mess and swinging from my ankle from the yardarm but I'm sure a sailor would be able to keep it under control quite well.
  16. Someone mentioned moving the lift blocks from the main mast to the topmast so they are more forward. I have done similar even if the plans show the blocks on the aft section of the masthead. Plans are a good starting point, but if there is a more practical and functional way to do it I'm sure the sailors of the day would have made a similar modification in real-life.
