Here she would have floated away with the down poor we've been having lately ... looks like a lass with teeth mate
Carl
Thanks carl,   she is getting there bit by bit,   soon will be the deck railings(still looking at seeing if I can do them in managable lengths not long runs).
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
Manageable lengths is a process done by many good modelers. One long length is very problematic as it often does not fit the contours of the deck. Make your cuts at a post, then allow the rails to slightly overlap each successive length. I have done this many times before and it works very well.
Thanks mate,  suppose I was hoping to cut at every stantion, into average size pieces  say 2-3inches, but I dont think that will happen as I would have to loose some railing without stantions and there wouldn't be enough length then.
OC.
Current builds
Completed works.
I've done the full length one's. You need a little patience OC. Just glue section by section. Glue the first two/three stanchions, then after an inch or two spot glue the next, and so on. If the railing is bent/wobbly, spot glue at shorter distances. When you've finished the entire railing, you glue the remainder of the stanchions. Quick drying CA is the easiest way to get it done
Carl
Hi all,  I started fitting the deck rails starting with the rear deck, after checking the location of the obstructions like the rear tubs, and also the rear accsess hull ladder,  it gave me the the opportunity to cut the railing into three pieces,   this worked quite well  I just sat them in a small smear of thick gorila pva.
Heres the dreaded pictures.
OC.
Current builds
Completed works.
No need to dread OC. Very nice work.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Thanks lou.
OC.
Current builds
Completed works.
1 hour ago, BANYAN said:
Nice work OC, those rails are all nice and straight.
cheers
Pat
Thanks pat much appreciated.
OC.
Current builds
Completed works.
34 minutes ago, RGL said:
Well done mate, you wouldn’t think those railings are so nerve wracking but they are.
Thanks greg,   im finding the thick quick setting gaitor pva glue a real help, as it grabs the rail and within minutes its starting to set,   they are actually less hassle than I thought they would be.
OC.
Current builds
Completed works.
OC.
OC
Is that Gator Grip glue you are using, in the bottle with a green and white label?
If so, that is a great glue for photo etch railings. Excess glue can easily be brushed away with a damp (with water) paint brush, then wick away the water/glue with a dry brush. Makes the join invisible. And it's strong, too. I probably use the thin set version more than the thick (green label) but I think you can thin the thick glue with distilled water, so it makes having both thick and thin bottles redundant.
13 minutes ago, CDW said:
OC
Yes mate thats the stuff - I am frankly amazed how much better it is over standard (cheap) pva glue,   I found out how tuff it is when I left abit of wood stuck in some glue residue ontop of a lid,   the wood stick was almost welded in to the set glue.
OC.
Current builds
Completed works.
Good evening all,   I managed some more time on the bench this evening - I put the deck railings on the rear deck (other side),  then turned my attention to the forward booms and frames, I decided to use the kit ones (well I had no choice as I lost one of the pe frames)  anyway I think they look ok for kit parts,   I also created two pe brackets/cradles for the boom ends to sit in.
Just the two pics tonight.
OC.
Quote
Current builds
Completed works.
nice job with the railings.........looking super  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you denis.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Evening all,   thanks again for all the likes and follows.
After an unexpected  early morning as the wife had a bad night and it was easier to just get up, anyway she lay on the sofa and I hit the bench  - my first job was to paint the forward booms/supports,   then I painted the tops of the rear section railings black,   it came out quite good despite being half asleep.
OC.
Current builds
Completed works.
A bit more work on the bench today  - I constructed the two lookout depth sounding platforms then glued them down,  I then constructed a temporary house for my build out of the kit box - it will receive a couple of coats of white emulsion to cover the box art.
OC.
Current builds
Completed works.
2 minutes ago, cog said:
Didn't know it came in as a full build! She looks great OC, nice coverup ;)
Thanks mate,   yep  I discovered the diemensions by accident when I sat her in the lid to take a pic.
OC.
Current builds
Completed works.
very nice, and is the wife feeling better
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks kevin,   off and on to be honest.
OC.
Current builds
Completed works.
Hi all,   more work again today  she is getting closer and closer to completion,   anyway I cut the mid section of railing into two sections, the first one fitted in a nice short straight line between the 4inch gun mount shroud and the platform,  the next section continued on from the platform and forward, this section needed bending in two opposing directions, then glueing into place.
I did this for both sides  then turned my attention to the rear access hull ladder,  this has a platform at both ends and after assembling I fitted in the stowed position.
OC.
Current builds
Completed works.
Evening all,    its getting closer to being finished - today I fitted the rear  hull ladder to the other side, and built and fitted the two night lifeboys,  I also constructed the front flagstaff and stand.
Oh  I also fixed down the superstructures.
Just needs a bit ot touch up and the four sections of railing alsong the front  - then its finished  minus the Oerlikon guns.
I took a few pics in the kitchen - hence why the lighting is different (still with my cam phone as my dslr lens is too long)
OC.
Current builds
Completed works.
very nice work.........looks better and better with more railings added to her  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you denis,   not far to go now.
OC.
Current builds
Completed works.
7 minutes ago, BANYAN said:
You may think it slow but some very nice progress there OC
cheers
Pat
Thank you sincerley pat,  I thought I would never see the day finishing her  - only taken me three years.
OC.
Current builds
Completed works.
