Hi all,
I have started work on the Cutter for my model of HMS Vulture (link in my signature below for those who haven't seen her) and decided to make a separate Build Log of the project.
Some time ago I purchased the Timbering Set for this model from Admiralty Models. Timber in the set was cut by HobbyMill who are no longer in production, so I don't know if the Set is still available. EDIT - It's not.
The "kit" includes a resin plug to which the frames are temporarily fixed until the boat takes shape. There are NO plans or instructions included - this "kit" is even more in the way of Scratchbuilding than the ship itself is. Here's a pic of the "kit" :
There are 5 packs of timber (not sure of the type) ranging in thickness from 0.031" to 0.1" for things like the Keel, Transom, Gunwale and Thwarts. There are also 2 packs of Holly - one is 0.031" x 0.031" for the Frames, the other is a sheet of 0.015" thick for the Planking. All the timber has been milled to HobbyMill's exacting standards and looks to be of excellent quality. There also seems to be a lot more timber than I'll need - probably enough to make TWO Cutters if I don't waste any :) .
:cheers:  Danny
Cheers, Danny
Danny, just pulled up my chair to watch your build
Jack
Current buildUS Constellation
Looks challenging ... I'll enjoy this with your prowess ... no need for a chair .. I'll watch over your shoulder
Edited by cog
Carl
I'll be watching too!
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Alright!  I've got to pull up a stool too, while it's still pretty close to ring-side!
GEORGE
Welcome guys :) .
I remarked earlier on that there were no Instructions for making this boat.
Thanks go to David Antscherl who emailed me the complete set :) . He'd pulled the Instructions from the Admiralty Models site when the Timbering set was no longer available.
I don't know how I'd have got on without them - there are 19 pages of beautifully written instructions, complete with pics and plans. I expected nothing less :D .
:cheers:  Danny
Cheers, Danny
Good morning Dan,
I really am looking forward to this. As you know I think your work is stunning and there is no reason to think this will not be yet another masterpiece.
Regards,
Russell
Thanks Russell.
First job is to get the Plug ready. This comes in 3 pieces, two hull halves and a removable piece in the middle to enable it to be removed from the framing later on. I drilled two 1.2mm holes through all three pieces whilst holding the whole thing together in the vise. Then I inserted two lengths of brass wire to keep everything in line :
I gave the plug a light sand to remove any lumps and bumps. Due no doubt to some limitations in the casting process the grooves for the frames weren't perfect, so I used a narrow chisel blade to scrape them out :
:cheers:  Danny
Cheers, Danny
the plug alone looks like it would be quite handy.   is there any places where they might be available?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Dan,
I'll follow you log with great interest. Do you also build the other boats?
Regards Christian
I had the pleasure of taking Admiraltys course on building the cutter. There is enough wood for two models. As I recall, there was a problem with the top height of the plug. It wasn't too big a deal but easier to fix now than later. Enjoy!
Toni
Member IPMS
                           Utrecht-1742
Danny,
I started the cutter, and get back to it when ever I come to a stopping point on the Echo Section.  It's small, so when I'm in the mountains I can take it with me.  Not power tools necessary.   I'm sure you'll have yours completed by the time I turn around.  That will help me a great deal when it comes time to get the frames in.
Maury
Thanks for dropping by Greg, Popeye, Christian, Toni and Maury.
Perhaps Admiralty Models may still have some?
I might build a 2nd Cutter for the fun of it as a separate model, but I'm only going to fit one onto Vulture.
Anything more specific about the problem Toni? I'd like to know before going much further, as I'm about to put the backbone into the plug.
:cheers:  Danny
Cheers, Danny
Keel
The Keel assembly consists of 6 parts - the Keel itself, the Stem, the Apron, the Sternpost, the Sternpost Knee and the Transom.
A rabbet is cut in the length of the keel. I used an Xacto knife and a straight-edge to cut this. The Xacto was also used to cut the rabbets into the stem. I managed to cut both of them without actually breaking either off-cut (just to see if I could :D ) :
The Apron is 2" scale inches wider than the stem. This was cut with the scroll saw :
The Sternpost is also rabbeted, and the cutout for the rudder pintle and strap have been cut in :
The keel assembly :
After some minor cleaning up the Transom is glued on :
I found a problem with the length of the plug and the plans - the plug is 5mm too long! I had to adjust the length of the keel to suit. This is now a 18'9" cutter instead of 18' :) .
:cheers:  Danny
Cheers, Danny
I think it would need to be 1:48 scale Greg as it's being made for the Vulture.  ;)
GEORGE
There is one completed cutter using this admirality-plug, in the log of Remco.
I can't remember of any issues with the plug from that log.
Jan
Edited by amateur
Here is the link to my cutter.  Clinker planking was new for me.  David's suggestion was to plank without frames on the plug and add them later.
Maury
http://modelshipworld.com/index.php/topic/7678-18-cutter-by-maurys-scale-148-small/?hl=%2Bcutter+%2Bmaury
As I recall, the height of the sheer was incorrect.  When I get back home later this week I will look at my plug.  Greg should also remember the problem.  I would check the height of the plug against the plans.
Toni
Member IPMS
                           Utrecht-1742
The plug is not wrong: the upper edge is the top of the removable wash boards, not the top of the sheer strake. Marking the plug out first will take care of this.
The resin plug issues are pretty typical for most resin cast kits. The molds are soft and rubbery, so the dimensions can vary by small fractions. Every rolling stock kit I've ever worked on had a lot of cleanup, truing and squaring. Check against accurate plans, said the novice to the masters. :o:)
Request permission to watch one of the masters. :D
Ken
Started: MS Bounty Longboat,
Danny,
Does you plug have faint plank markings on it?  Mine had them on one side only, which I carefully copied to the other side.
Maury
Thank you for commenting Greg (yep, 1:48 scale), George, Jan, Maury, Toni, Druxey and Ken.
You're doing a very good job on your Cutter Maury. I have your Build Log open as I'm working on mine - you've already saved me a couple of times :D . Yes, my plug has the planking marks. Instead of marking the other side I'm cutting two planks at a time - the 2nd should follow the line of the 1st.
Druxey - my plug was a whole 5mm longer than the plans - I had to modify my keel to suit as I didn't want to muck up the lines.
Ken - permission granted :D .
:cheers:  Danny
Cheers, Danny
Planking
As suggested in the instructions I've planked the hull of the cutter without the ribs - they'll go in later as most of them would come off the planking when the hull is removed from the plug. This pic was taken with a couple of runs left to do. I'm using Tamiya masking tape to hold the planks in position while they dry :
The cutter removed from the plug. It came out very easily :) :
Some pics of the outside. The planks need a "rolling" bevel both fore and aft to fit to the stem and transom :
There was very little excess glue inside the hull. These pics were taken before I started any cleanup :
You can see a couple of wedges in the bow which I inserted to ensure a tight fit to the plug. Isopropyl alcohol made removal of them easy :
:cheers:  Danny
Cheers, Danny
Couldn't ask for any more perfect planking on a boat so small.  Very nice!!
GEORGE
You make that look so easy, Danny   And it came out looking great!
