Safe journeys Bob.
GEORGE
Thanks guys for the comments and "likes".
Mike, after seeing yours, I'll be happy to have mine come out as well.
Had the pleasure of spending some time with Chuck, and seeing his work, and I'm eager to get back at it.
Bob
Back at it after a travel break. I've done the stern frames and the framing of the stern ports. Fitting and placing those sills and lintels was a fussy business, even using the stern drawing as a template, as suggested by Chuck.
Now the fun begins. Time to start the planking.
Bob
Looking great, I am at the same stage--- it took me three attempts to get the stern correct--- my problem???   I never read the excellent instructions that Chuck had written until the third time I did it ha ha ha
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
Great work Bob.
Those stern ports looked like they would be a little, as you put it "fussy", but they look perfect.
Enjoy your planking. :)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks so much Ian, Rusty and all of the "likes". I'm sure that I must have done at least 3 of each of the sills and lintels in an effort to get all the angles and bevels to a passable state.
Bob
Some progress to report. I completed the prep for planking by adding the square tuck stern piece and fillers and then painting the ports. I opened my last ever bottle of Pollyscale ATSF red for the ports.
I then did the first layer of the wales, which was pretty straightforward. Now, it's on to the topside planking.
Bob
Bob,
your build sequences look clear, straight foreward and very well executed. You`ve got a real "gem" of a cutter on your slipway...
Would it be worth a thought to do the hull below the wales in lapstrake planking ? (like Lee had Chosen for his cutter "Alert" )
Nils
Current builds
-Lightship Elbe 1
Completed
Laying that first wale may have been 'straightforward' (for you) but it gives us a great mind's eye view of what she'll look like.  Beautifully neat, mate.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Thanks so much Nils, Augie, Dirk and Joe for the nice comments and also all of the "likes".
Nils, the prototype for Chuck's design does not have lapstrake planking and I'm going to stay with that.
Joe, I only wish that I had stocked up on the paint. I don't have many bottles left.
Bob
Nils,
Cheerful was NOT clinker planked.  I know that its a simple thing to just think that all cutters were planked that way (like Alert).  But its simply not true.  This class of cutters was carvel planked.   Just as the contemporary model of Surly shows.   I suppose that folks could clinker plank the cutter but it would be historically incorrect.
Chuck
Planking is now underway. I have completed the port side topside planking ( to the point of rough sanding). The caulking is simulated by pencil on one side and end of each plank. Since I've never been able to accurately plank between ports by adding individual planks, I use a method of building up units of planking , which allows me to get perfectly straight edges and correct sizing to obtain the 1/64" rebates around the ports. Where required, the planks are pre-bent to shape before gluing up the unit.
Now it's on to the starboard side to repeat the process.
Bob
Your planking looks great Bob!  Thanks much for sharing your methods with us.
GEORGE
Well done Bob. Your method works really well and looks great.
Rusty
Thanks so much Jay, George, Grant, Rusty and Augie for the nice comments and thanks also to all of the "likes". Every once in a while, being unable to do something leads to a good idea.  ;)  :)
Bob
Bob - Everything looks great! I did the area between the ports like you did, using built up planking. Works great as long as the pieces are pre-bent where necessary. I'm looking forward to your getting ahead of me. It will help me as I plod along while learning from you.
Mike
Edited by Stuntflyer
Current build - Sloop Speedwell 1752 (POF)
Completed builds - 18 Century Longboat (POB) , HM Cutter Cheerful  1806 (POB), HMS Winchelsea 1764 (POB)
I can only echo all of the above Bob, very nicely done mate.
Definitely a system to remember.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Thanks so much Mike, Christian, Mobbsie and the "likes". Mike, I was thinking just the opposite -- I'd like you to stay ahead of me so that I can learn from you.
Bob
Bob, your gun ports look fantastic! Next time I have to do gun ports I will use your technique!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
