Hi all
Many thanks.
Glad too  be nearing the end of the deck framing......always a time consuming job.
Looking forward to all those little mini projects.....pumps...forward bits...capstan etc
Planning for yhe next model as well....can almost see the finishing line after 2 years.!!
Cheers....mick
HI ALL
DECK BEAMS ARE FINALLY FINISHED!!!
STARTED WORK ON THE WATERWAYS FROM HOLLY ,  FORWARD BITS FROM REDWOOD FOR A BIT OF CONTRAST.
HATCH FRAMES MADE FROM BOXWOOD......GRATINGS YET TOO BE MADE
TIMBERS CUT FROM STEAMED PEAR FOR INNER PLANKING AND HOLLY FOR THE DECKS.
THATS ALL FOR NOW..
CHEERS....MICK
Looking awesome, nice work on the framing
Regards
Paul
Edited by paulsutcliffe
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Well worth the wait, Mick. Will be patient for the next one ...
Carl
HI ALL
DECK HAS NOW BEEN PLANKED
UNFORTUNATELY I DRILLED THE HOLES IN ONE PLANK IN THE WRONG PLACE!!!!! DOH!!!
OUT CAME THE ISO....THANKFULLY IT CAME OUT QUITE EASILY....PHEW!
I CAN NOW MOVE FORWARD AND START MAKING THE DECK FITTINGS.....ONCE IVE SANDED THE DECK SMOOTH
THE CLAMPS I MADE EARLIER PROVED TO HAVE A FEW ISSUES WITH THEM.......SO THE BOXWOOD WAS REPLACED WITH ALUMINIUM....PROBABLY DOWN TO ME USING 3MM THREAD RATHER THAN THE UNF THREAD.
THATS ALL FOR NOW FOLKS
CHEERS...MICK
HI GARY
THANKS FOR LOOKING IN....TURNING INTO A MARATHON THIS BUILD!!
I RECKON THOSE CLAMPS COST LESS THAN A £1 EACH TO MAKE.....AS LONG AS THE HOLES ARE CAREFULLY DRILLED THEY ARE PRETTY SIMPLE TO MAKE.
3/8" X 1/4" ALUMINIUM BAR
3MM BRASS ALLTHREAD
3MM BRASS THUMB NUTS
3.2MM DRILL
2.5MM DRILL
M3 TAP
PLENTY OF ELBOW GREASE.......JOB DONE.
CHEERS....MICK
HI ALL
SINCE I WAS OFF WORK LAST WEEK...AND THE WEATHER WAS ESPECIALLY LOUSY.....PLENTY OF TIME FOR SHIP BUILDING.
BEEN BUSY MAKING LADDERS,COAMING FOR THE CHIMNEY......TURNED FROM A PIECE OF BUFFALO HORN,AND STARTED WORK ON THE CAPSTAN.
PHOTOS ENCLOSED AS USUAL.....SOME PARTS ARE ONLY IN A PRELIMINARY STATE AND WILL NEED TO BE REFINED BEFORE FINAL FITTING.
THE GALLEY CHIMNEY WILL NEED SOME TLC AS WELL SEEMS TO HAVE GOT BASHED ABOUT!!
CHEERS.....MICK
Nice details Mick. "Bashing about" happens when there are labourers around ;)
Carl
Really nice work Mick.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
HI ALL
SOME MINOR WORKS HAVE OCCURRED RECENTLY ALTHOUGH NOT AS MUCH AS I WOULD HAVE LIKED.
SHIPS PUMPS ARE DONE......WOODEN PARTS FROM STEAMED PEAR , HANDLE BRACKET FROM BLACKEND BRASS AS IS DISCHARGE PIPE AND STRAPPING BANDS FROM BLACK PAPER.
ALL TEN EQUALLY SPACED HOLES HAVE BEEN DRILLED......THEY NOW NEED SQUARING OFF.
IVE ENCLOSED PHOTOS OFF THE SET UP FOR DRILLING WHICH IS A LITTLE HEATH ROBINSON BUT IT WORKS.
ONCE THE CAPSTAN IS FINISHED IT WILL BE TIME TO START PLANKING INBOARD...IN STEAMED PEAR.
THE PHOTOS SHOW SOME DRAWINGS OF A CAPSTAN AND SHIPS PUMP FROM AOTS ENDEAVOUR WHICH IS OF THE SAME TIME PERIOD AND I USED AS A PRIMARY REFERENCE.
CHEERS FOR NOW....MICK
The more impressive the result. Pumps are looking good too
Carl
Hi carl
A bit of improvisation goes a long way.......need to make a new baseboard with a few more functions for the roatary table to bolt to.....other than that its worked quite well.
The pumps are version 3......frustrating little buggers to get right!
Oh well its of too work we go......
Cheers for now
Mick
He, ho ... he, ho ...
Couldn't you make a baseboard with a cross cutout so you can slide the rotary table in different positions ... just a thought popping up ...
Carl
great minds think a like ... ;)
looking good mate
cheers
Carl
You might need to make a few more clamps, mate. can't imagine you have enough of them ...
quite a nice job on the planking, treenails look good too
Carl
