This is just my sheer ignorance in the metal work world. I was bending some 1/16" brass strip into a U shape, or more accurately a 3 sided square. In this application each side was about 1/8". I was using a needlenose plier and a small hammer to try to get decent 90 degree bends. The result was fair but could have been better.
So what I am wondering is if there are some type of shaping forms that I can use to hammer brass strips on. Some square rods, circular, and maybe even triangular - probably a set with various sizes. I have plenty of brass rods & tubes but I doubt beating brass on brass is going to work.
I'm sure there is something out there but I don't know what to look for. Let me know how you guys do it.
Mike,
Anneal the brass first.  Heat to red hot and let cool.  It'll soften it and make it easier to bend.   As for forms.. check around places like Amazon for small anvils. For a cheaper method, check around Home Depot and Lowe's in the hardware department.  They sell steel stock that might be usable.
Mike,
I strongly suggest you invest in a pair of quality parallel grip pliers with straight (not tapered) sides. For the brass work below, I annealed the brass as Mark suggested, scored the strip where I wanted the bend, inserted into the plier at 90* to the side, bent, and gave it a small tap with a hammer.
I seem to recall that you can find the pliers for about $20. I use them constantly when working with metal.
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
I just give it a light going over with the steel brush wheel I'm my Dremel
Best,
John
Member:
Model Ship World
Sounds like just the ticket John.  Beautiful metalwork!  Thanks for sharing.
The other thing that has caught my eye is something they call a forming bezel. They come in various shapes - round, square, triangle.
I've found both the pliers and the bezels on Amazon.
If pieces need to be "re-hardened" how would it be done.  I'm thinking of pieces that need to be bent, but then need to hold some weight or pressure.
Richard
Richard
Member: The Nautical Research Guild
Richard
I discovered that the only method open to the non-commercial metal worker was to work-harden the brass.
http://uvsmgshipmodelguild.wikispaces.com/Copper+Tempering
Joel,
Quenching in oil or water wouldn't re-harden the brass?   I'm just curious as I've not done any metalsmithing to speak of.
Joel,
No.  It's a long and complicated process.  You can even quench the hot metal and it will stay soft and workable.  Google it if you like.
Joel, Mark, et al,
Scroll down in this forum and you will see a thread called re-hardening brass. The basic answer is: one can't.
I'm having a bit of a hard time imagining when you would need to do it. Under almost all circumstances where I'm worried about strength, I'm sure to silver solder my bands, eye-bolts, or whatever. There's a small learning curve but I now find it easier than soft soldering.
Best,
John
Joel,
Here's the pic.s and links
http://www.micromark.com/parallel-jaw-plier-flat-nose-with-straight-jaws,11523.html
Edited by Landlocked123
Member:
Model Ship World
Hey John - you mentioned scoring the pieces at the bend. What do you use for that?
Mark - I'm working on some metal work for the mast. Took your advice and heated up the strips first. WOW! What a difference. The strip is amazingly pliable now.
Hi Mike,
It's not really a score as much as a scratch to mark the location and angle of the bends. I use a Starrett pocket scriber, but an X-acto knife would work as well as.
Best,
John
Member:
Model Ship World
There was a discussion about the characteristics of copper, bronze and brass in 2013. See http://modelshipworld.com/index.php?/topic/2102-copper-bronze-and-brass-how-to-treat-them/#entry50895. Wefalck in particular made some good points.
Tony
Check out Ken Forans book on building in brass. Everything you need to know about brass. Schiffer books. No financial connection just a good book.  Bill
Bill, in Idaho
Completed Mamoli Halifax and Billings Viking ship in 2015
Next  Model Shipways Syren
I second that! Own the book myself, and found it to be a good investment. Bill's right!  :)
GEORGE
Me too. I have the book also. Bill's right :)
Jack
Current buildUS Constellation
Ordered this morning......
John or nayone - hope you might still be following this. I have one more technique question for you . Let's say I have a strip in the parallel pliers coming out the side and I want to bend it 90 degrees. If I just push the strip with a finger, that bend/corner comes out a little rounded. How do you get a nice sharp corner?
That's where having a vise or anvil would come in handy!  :)
GEORGE
That raises the same question. Whether the material is gripped in a vise, anvil or parallel pliers  - what do you use to bend/push the part that is sticking out? When I just push with my finger the corner has some roundness to it.  I suppose with an anvil you could hammer it?
Mike, you are going to have some rounding when you bend anything. Even the excellent work that John showed above the corners are rounded. As you suggested you could pound the corners square, but that would tend to cut the inside corner through unless you were extremely careful. You could also make it larger and file the excess material off to give a more square look. Lastly the only real square way would be to butt and solder two flat surfaces together at 90 degrees. If you solder from the inside of the corner, you could get a square outside.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
Bill - I suspect I am being a bit anal about the corners. Like we always say - the average person looking at my build would never notice. I guess it's the ship-o-holic in me. Heaven help me if I took your last suggestion and started soldering flat parts for all my metal work.  :o
Hi Mike,
I suppose it would be possible to use a fine sanding drum in a Dremel to square off the rounded edge on the outside. But I'm good with getting them as the look in the pictures. But I do take an extra step. I line up the place where I want to bend square to the jaws, I then bent with my fingers, but then, while holding the pliers tightly I put the tips down on the bench and use a very small hammer to tighten the bend. I don't know if this makes sense so I will try to post a picture in the next few days.
Best,
John
Member:
Model Ship World
