So crisp and clean! Do you pre-treat your wood?
Respectfully
Hi.
I buy the wood in plank, and I make it at home. The only treatment I do is with nitro cellulosic filler. I do not know how it is known in other countries, but it is the primer that varnishes use before applying the final varnish. It is very easy to sand with very fine sandpapers or with fine steel wool.
AMALIO
I believe that nitrocelluose is laquer resin.  It makes a good sanding sealer because it is hard.  Will check and advise if incorrect.
Ed
It is a kind of varnish with a very fast drying, so the wood does not give time to remove the pore. When it dries, it is very soft so it is very easy to polish it later. The final look is very similar to the one that gets the wax with a satin finish that I really like.
There are also tapaporos to water with similar results, but I like nitrocellulosic. Remember that it is not a product designed for the final termination, but it is a preparation prior to varnishing, but I use it as a termination.
Thank you
AMALIO
Now, people who have had questions, drop them again. There is a possibility you will get answers.
Montañes, great work.
Edited by maaaslo
Pavol stands for Paul, Pablo, Paolo etc. Please do not try to pronounce it, just call me Pav...
Amalio - thank you for sharing how you prepare your wood.  I, like I’m sure many others, find your insights valuable.
Best regards,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
All of your work is very well finished to such a high quality Amalio, not a hint of 'fuzz' on your rope or finished wood.
I very much enjoy your updates to see what can be achieved.
cheers
Pat
Every aspect of your build is impeccable.
Current build:
Finished build:
Current build(On hold):
Amelio,
Maybe in my next life my skills will come close to your work - prob not - haha - Amazing work indeed.:imNotWorthy:
Such a pleasure to follow.
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Hi dvm27
I like to put the curves before the beams to be able to match them all together with a piece of wood lined with sandpaper and made to measure with the appropriate shape. If you place the beams before there will be no possibility of doing so.
Thank you.
AMALIO
Yes it is. Wonderful work, Amalio. You keep amazing me with your sharp details, and very smooth wood surfaces
Carl
