Looking great.  I like your work on the winch and the butte, very nice.  Not sure about the cat-head location, but that's probably just because I'm so used to seeing it in a different location on mine!
Enjoying watching your progress, thanks for sharing.
Thank you very much for the kinds words and the Likes. I took a 4-week break from modeling the AVS to prepare my next project, the H.M. Brig Badger POB in 1:48 scale. Drawn the bulkheads and some parts in Corel Draw to have them lasercut soon. Now it is time to return to the AVS. Installed all iron bands on the bowsprit.
Edited by captain_hook
Completed Build:
Armed Virginia Sloop 1/48 by Model Shipways / Gallery
HM Cutter Sherbourne 1/64 by Caldercraft / Gallery
Added the stop chocks. This completes the boom except for the heel lashing and the footropes which will be done with the rest of the rigging later. Next is installing the guns. I think about a way to store some cannonballs. Maybe I add some sort of rack or sheet beside each gun storing 5 cannonballs.
Completed Build:
Beautiful ! -very nice work and nice pictures !  Late to the party but look forward to following along 😊
Edited by gerty
Current Build: Willie L. Bennett - Model Shipways
Future Interests:  Friendship Sloop - BlueJacket Ship Crafters
                            Cape Cod Catboat - BlueJacket Ship Crafters
Thank you very much. I glued the guns in place. First I drilled a hole through the front axle, pinned that with a short 0,7mm nail (so that the nail is only about 0,5mm longer than the bottom of the front wheels) and positioned the gun in place. Pressed it down until the nail in the axle marked a spot on deck and drilled a hole into the spot through the deck. Then glued a longer pin into the axle and that into the predrilled hole on deck. Positioned until it has the correct angle. Epoxy gives a lot of time for correcting the angle. Next is gluing the eyebolds.
Completed Build:
I finished the channels (donˋt know if that is the correct english word for ‚Rüste‘ - the sheet, where the chain plates are fitted on). Also installed all eyebolts on deck. All that is left (before rigging) is finishing the guns, gluing all the deck items and installing the mast.
Completed Build:
As I wait for some rope and fittings from Syren Company to arrive, I thought about adding a shot garland to each cannon. Since the 3-pounder cannonball has a diameter of about 6,5cm AFAIK 1,5mm steel balls may be a little oversized but a smaller diameter would be too small to recognize. The garland stores 6 balls each and is made of 1,5mm square stripes with addition to 1x3mm stripes glued to each sides. Then the space for the balls (9mm) is enclosed by 1,5mm square stripe pieces. Sanded both sides so the garland is only 2 mm thick in the end, then sanded a 30 degrees slope on each side and rounded the edges. Have to paint them red and installed them next weekend.
Completed Build:
Added a ramrod to every cannon. It is made of a piece of 1/16‘‘ square stripes drawn through a 1,6mm hole drilled in a piece of stainless steel. Then tighten in a dremel and brough to shape with a needle file.
Completed Build:
Nice touch with the ram rod. You don’t see little details added like that very often. Good job.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
Are we gonna see the other two cannons soon ? BTW She looks so good I'm gonna give upon mine. It's embarrassing. :)
Dwight
current build : Fair America by Model Shipways
Completed Build : 18th Century Armed Longboat by Model Shipways Armed Virginia Sloop by Model Shipways
Under the bench : Syren by Model Shipways ,, Rattlesnake by Model Shipways
Thank you for the nice words and the likes. Rigging the guns is time-consuming, but at least I made all the gun tackles. I used syren 1/8‘‘ single and double blocks and 0.45mm rope for the tackles as well as 3mm blacked brass hooks. Will make the rope coils tomorrow if I find the time. Have to bring the breech lines to shape as well.
Completed Build:
As I slowly move towards rigging, I thought about adding some last details to the hull before adding the mast. The supplied ship‘s wheel is made of britannia casting and I decided not to use it. So I made a 8-spoke 23mm ship‘s wheel scratch build made of castello. It is a shame that it will be almost covered by the binnacle.
Completed Build:
Superb new detail. Perfect as usual 😉
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Incredible!
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
Thank you very much for the nice words and the likes. Been working on the mast today, added wooden clamps and redone the mars so that it stays parallel to the deck. For now all parts are only dry-fitted.
Completed Build:
Impressive to say the least!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Thank you for the nice feedback and the likes. The ship‘s wheel has been completed and all deck items are now glued in place. Time to start prepairing the rigging and completing the mast. I have to finish the base too.
Completed Build:
Before I will get to the final chapter - the rigging - I have thought some time about a more realistic launchway and have made a start already. Next step will be gluing the launchway onto the board, cover the sides with the prepared birch strips and cover the painted area with grey gravel (1,2 - 1,8 mm).
Completed Build:
The gravel is glued with with white glu dilluted with water (50-50). I first brushed a thin coat, then strewed the gravel onto the base. Used a brush to cover the gravel with dilluted glu to fix it permanently. It has to dry at least for several hours. Then I can  move on to the second part, the carriage.
Completed Build:
