Okay, then what about this:
Mask your line, top and bottom as perfectly as your eye enables you to do - having cut sufficiently long strips of masking tape to make nearly one complete run, stem to stern.  The complicating curves at the bow and stern need to be dealt with in shorter lengths.  You will have first ripped your tape into no more than 1/8" strips, this will enable you to easily stretch and adjust your tape to move as needed, with the sheer, etc.
Once you have the line masked the way you want it, thoroughly burnish the tape with a straight piece of stiff card.  Then mask as near to the line with a wider swath of masking tape.  Then mask off everything else above and below the line with paper.
Here's the critical step:. Spray the, as yet, uncolored line with a clearcoat that matches the desired sheen of the rest of the model.  Once that's dry, airbrush in your color wih a few light coats.
If, after removing your masking, you see any areas where the clearcoat has blead under the tape - simply mask off your line in the affected areas, level the clear coat, and when the time is right in your process - spray the whole .thing one last time with that matching clear coat.
Failing all that, pour me a glass of bourbon on a slow evenning, and I'll tape off your lines to perfection.
Bob -
I have some thin white striping tape coming, which I was going to paint green and try to apply.  After your suggestions, i will add some coats of clear on top for strength.
Marc -
I have some Tamiya masking tape for curves coming, and will try to do the masking that you suggest.  Or I will gladly ply you with Maker's Mark after you have done the masking for me.
Druxey -
Failing everything else, I will cut a nice horizontal line across my forehead and slip in a layer of green jello as a boot topping.  By then my brains will have turned to goo anyway.
Later
Dan
Dan,
one trick you might try for painting the line...
Use masking tape the thickness of your final line to define where the line will be, then place another piece of masking tape (as wide as you like) either side of this. Remove the original piece from the middle and you have a nicely masked line to paint.
To prevent bleeding under the masking tape, apply a coat of clear first. This will seal the edges of the mask, thus preventing bleeding under the tape.
Hope this is helpful.
Hi again to everyone looking in -
Thanks as always for the likes and compliments, and to all who made suggestions for my boot topping problem.  I believe that it has been solved, but not without lots of backpedaling and redoing.  Here is how it went –
When the last segment closed I had the Promenade deck structure done and was working on the upper decks.  The upper hull had several coats of gloss white and the narrow green sheer stripe had been successfully applied using 1/16” green vinyl pinstriping tape which is made for the car detailing market.
The next element was the wide green boot topping.  I sourced 3/16” vinyl striping tape from the same people who made the 1/16” tape so the colors would be identical.  The vinyl is somewhat flexible and here in the midships area and at the bow I did not have any trouble laying it down along the waterline.
There were, however, several problem with the tape.  First, it was too thick, measuring out at .008.  It was not very noticeable, but in glancing light the raised edge could be clearly seen.  A bigger problem was that despite its thickness, it wasn’t really opaque, and the demarcation line where the red and white met was visible through the tape.  Not a lot, but hard to miss once you see it.  But the biggest problem was that it was going to be very difficult to do the area under the counter.
Due to the curvature of the hull the boot topping has to bend in three dimensions and, to keep the same vertical distance, has to get wider as well.  The vinyl tape could not bend to fit the curves, and the thickness would make it lumpy if it was layered to make up the added width.  I could have tried to cut and piece it in, but with the other problems I decided to scrap this product.  With some care I pulled the tape off the waterline only to find that it left green residue along the edges.  RATS !
Fortunately, it was removable with mineral spirits on a cotton swab.  And while I was at it I cleaned the entire hull, removing all my pencil marks as well.   To replace them I carefully mounted the model upside down so the keel was perfectly parallel with the work table and the stem was perfectly vertical, or as perfectly as I could make them.  Then I used and old waterline marking jig that I made about 25 years ago and kept around ever since.  A sharp point on a soft lead pencil did the actual work.
To replace the boot topping I located and ordered some striping tapes that were described as being very thin, and some Tamiya masking tape that is meant especially for curves.   While I was waiting for delivery, I tried Druxey’s suggestion of making thin paper strips.  I used the thinnest paper I have, some art quality tissue paper.  I could, with some care, cut strips with parallel clean edges.  These were misted with water to relax the fibers, then I laid out the strip on the hull without glue.   The water was enough to make a temporary bond.
The results for me were uninspired.  I could lay out the tape fairly well, and could move it around with some additional wetting, much like a water-slide decal.  But it never laid down completely on the curves, even some of the smoother ones, much less the tight curves in all three dimensions under the counter.  Maybe it was my paper.  Maybe my technique.  Whatever, it would not work for me.  It would all have to be removed and discarded, along with the work invested.  DRAT !!
But as long as I had the paper tape in place on the hull, I tried masking both above and below in preparation for spray painting the green boot topping.   The Tamiya tape had not arrived, so I cut long 1/8” wide strips of painter’s blue tape and laid it above and below the paper strips.   This, too, was not completely successful.  No matter how careful I was, I could see that there were small crinkles in the edge that would let paint bleed underneath, even after painting with a clear finish.   The masking tape would have to be discarded, along with the work invested in laying it down.  BOTHER !!
Finally the thin striping tape arrived.  It was Chinese, of course, and I had to buy 5 rolls in 5 different colors of 40’each, none of them green. But it was only .002” thick, which was promising.   I used the white tape and laid out strips about 8 inches longer than the model on a length of waxed paper.  They stuck well, but came up easily enough when tested.  They were spray painted green from a rattle can.  Repeated light coats were laid on till I was satisfied that the tape would be opaque.
After drying overnight I carefully lifted the ends of a strip and pulled it up, only to find that the dried paint was stronger than the bond to the waxed paper.  Attached to both edges of the striping tape were flaps of paint, some large and some small, but more than enough to ruin the tapes and they all had to be discarded.  GRRRRR !!
For the next set of tapes I made them a bit longer, but did not paint all the way to either end.  When I was happy with the depth of color the tape was removed while the paint was still wet using the unpainted ends.  It was immediately stuck back down on a clean section of the waxed paper and allowed to dry.
The next day the tapes were carefully set along the penciled waterline.    They were lightly pressed against the hull until I was satisfied with their placement, then burnished down.  I finally had a clean, crisp, boot topping in the right color with a tape that was barely thicker than a coat of paint, and - - - next time - - - will be easier to achieve.
 Under the counter there were still some issues.  With the tape so thin I could layer it over itself without major lumps, but it still would not bend, so a good deal of piecing in was required.
The photo looks worse than the actual model because I have already hardened the tape with clear varnish and have started to sand the overlaps smooth, which accounts for a lot of the white areas and lines that you see.  Once the sanding was finished I hand painted over the tape with green paint decanted from the rattle can.  This not only evened out the surface, I could fill in the small angles to make a smooth curving edge. The final result was, I think, more than satisfactory, even under photo magnification.  WHEW !
Now that I had the boot topping done I did a final light sanding of the lower hull which had picked up some scratches and blotches while I was working elsewhere.  After sanding and wiping it down, I masked off the boot topping with the Tamiya tape made for curves.  I have to say that I am a fan of the product.  It laid down easily, could be repositioned as needed, and went around the curve under the counter without a problem.  I burnished down the edge, then built up the rest of the masking in layers of widening strips of painter’s tape until the entire upper hull was protected.
I sprayed a clear coat along the edge of the masking, as several of you suggested, then laid the model on its side to spray the red from over and behind the masking so the paint would not be driven against the edge.  I used light coats and only did one side at a time, giving each a full day to dry.   When I removed the tape I had no bleeding under the masking.  But I did have THIS - - -
The Japanese masking tape had pulled up the American paint from all along the Chinese striping tape.  I wonder if this says anything about global geopolitics?  In any event, all of my hard-won boot topping would have to be removed and discarded.
There was only one thing I could say –
When I got back to it after a few days to clear my head the repairs went fairly quickly.  I managed to save the boot topping under the counter with minor touchups of paint, and the rest of the tape came off easily and without leaving a residue.  I was now proficient in making up the tapes and applying them, so only two days later I had restored the boot topping satisfactorily.
So I guess I learned some valuable lessons in perseverance and dealing with frustration.  But I would much rather skip that class next time.  LOL !
Be well.
Dan
Edited by shipmodel
An excellent lesson in perseverance, Dan.  It looks great and I was happy to read you got the solution you needed.   Hopefully things get a bit easier from here on out.
Dan, wonderful description of the trials and tribulations of the model shipwrights. I loved the journey (and the result).
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Perseverance + attitude + problem solving = solution  Great result Dan.
cheers
Pat
Nice save Dan.
Michael
Thank you all for the support and kind words.  Love it though I do, there is only one thing more frustrating and rewarding than ship modeling, and that is golf.  I have spent many masochistic hours chasing a little white ball around beautiful grassy fields.  And into the woods, and streams, and sand traps.  Now I do this.   What was that definition of insanity again?   :P
Dan
3 hours ago, shipmodel said:
Thank you all for the support and kind words.  Love it though I do, there is only one thing more frustrating and rewarding than ship modeling, and that is golf.  :P
Dan
Awesome work on Michelangelo-- golf is too frustrating for me, I stick to Highland Games...
Hello again to all –
A rewarding installment this time.  No major problems at all as I finished the lower hull.
While I was waiting for various deliveries during the boot topping odessey I worked on the hull details.  The first were the two stowed anchors.  These started life as Bluejacket castings, but were cut and ground to proper shape as shown in photos of the ship.  They are not inset into the hull, as on most liners, but mounted on a triangular cleat and held with the stock in the hawse pipe.
The ship’s name is a decal made on my ink-jet printer using a white decal sheet made by Testors.  Clear sheets also came in the packet, but my printer works less well on it than on the white.  You may have noticed during the last installment that the name appeared and disappeared out of sequence.  That was because several were made, tested and rejected for one reason or another.  It is not difficult to remove a bad decal with a little more water if it has not been overcoated with finish.  This is the final one.
At the stern the ship name is not done in black, but in gold.  You can also see the outlines of the two sets of stern access doors that were mentioned earlier in the build with rust streaks coming down from the corners.
The doors were simply inked on with an ultra-fine tipped marker.  In the photo they look a bit too bold, so I may yet adjust them.  The name and home port of Genova are decals.  To get them to curve around the stern I scored between each letter through the decal film but not through the paper backing.  I left a small band at the bottom to hold the letters at the right distance from each other.  With careful manipulation with a small paint brush and a toothpick each letter was adjusted around the curve.
Decals were made up for the plimsol mark.  The mark is correct for ships flying the Italian flag, but at less than 10mm overall the letters “R” and “I” which denote the country are so small as to be almost beyond the abilities of my eyes, much less my printer.  Several copies were made then varied slightly in tone before being printed out so I could select the closest match.  Once the decal was applied and had dried the edges were overpainted with a bit of red and green decanted from the rattle cans.
Decals for the depth marks had to be tiny Roman Numerals.  They are beyond my printer, so they were ordered and installed.   These were the last decals for the hull, so everyone was snugged down with setting solution and overcoated with clear varnish to secure them permanently.
A pair of 20mm diameter counter-rotating brass propellers were sourced from Europe.  A quick polishing with jeweler’s rouge on a felt cone and they were secured into the prop shaft tunnels that were tipped with brass collars.
The rudder shape was taken from the plans and cut from 2mm hardwood.  An airfoil profile was sanded into it from fore to aft.  It was notched to fit the rudder hinge on the hull and a hole for a brass pin was drilled up through the rudder and hinge and into the hull.  After a few coats of primer and final sanding it was painted to match the lower hull and installed.
The final items on the hull are the fin stabilizers.  These are small wings that take the place of the bilge keels to keep the ship from rolling.  They were first reported on a Japanese cruise liner in 1933.  As fixed wings they were not very successful, and were supplanted by gyroscopic stabilizers.  These were too large and heavy, so they in turn were supplanted by automatically adjusted fins.
It is known from newspaper reports and articles in engineering magazines that the Michelangelo had adjustable fin stabilizers, but none of my photos of the lower hull have any visible fins.  I was never able to find more details, not even how large they were.  Some fins are very small, and some very large, and some in the middle.
5a.jpg.c6abeb68d8c26d4a0f57fb93c4cae415.jpg6.jpg.2b140ca8152edaf0056948c618b5eb6d.jpg7.jpg.84503351959644b2bae8c00493f849dc.jpg
Most stick out horizontally from the hull, but some angle down perpendicular to the curved hull.  All modern ones are retractable to allow closer docking without the danger of damaging the fins.  Some slid straight into the hull, while others, like the one in the photo, folded into slots in the hull.
I found some drawings of the internal machinery of the retractable fins, and two are here just because I thought my audience would appreciate them.
I made my fins from 2mm hardwood sanded to an airfoil shape and tapered from the hull outward.  They are 5mm wide and 12mm long, which fits with the general appearance of fins in photos, and with my eyeball of what looks right for the size of the model.  They are mounted horizontally in brass sleeves inserted in the hull.
The lower hull is now complete and the model was firmly attached to its building base.  This will be replaced with a presentation base once the model is finished.  In the meanwhile, the fins were removed to safe storage and the lower hull protected in bubble wrap while work on the upper decks continues.
So it’s off to the NRG conference in Florida.  Hope to see many of you there.
Be well
Dan
Hi again –
Just a quick note.  In the last segment I was uncertain about how the stern access doors were represented.  Even though they are just 2mm x 4mm, the dark lines were visibly jarring.  Others noted this as well, and one sent me a private message with his opinion that the doors did not match the quality of the rest of the work.  He was, of course, correct.
Taking that to heart, I removed the inked lines and, after several experiments, replaced them with lines drawn with a sharp, soft pencil guided by a flexible straightedge.  Below, the before and after photos.  I think you will agree that the look of the doors has been substantially improved even if, under magnification, they are still not perfect.
2.jpg.c593c13fcf32824d526cc3e4eb2a8aaa.jpg59f0af36a353a_redonedoors.jpg.7c61207e8fc4f93c2fd035b25186bc65.jpg
On a side note, I want to thank the modeler who was brave enough to put forward a criticism of my work in a timely manner.  Although I do appreciate and cherish the compliments and likes, we are none of us perfect.  Certainly not me.  So if you do see something that you think can be improved, please, Please, do not keep it to yourself.  If I have stopped at ‘good enough’ I need my feet held to the fire until I go back and make it ‘good.’
PS - since I saw it under magnification, I removed the little green tab that sticks up from the green sheer stripe just to starboard of the doors.  Not a big change, but I felt better after doing it.
Thanks again.
Dan
Hi Dan,
great work on the stabilizer fins, and thanks for sharing the technical function drawings, very interesting machinery...
Nils
Current builds
-Lightship Elbe 1
Completed
Hi all -
It was really nice to see several of you at the NRG conference in St. Petersburg last weekend.  The conference was very enjoyable with lots of good models, informative talks and roundtable demonstrations.  And, of course, it is always great to see and chat with modelers whom I would only otherwise know as a screen name.
With the lower hull done I could start adding details to the decks.  Many of the elements have already been prepared while I was working on the hull.  The first details to be added were the margin planks around the edge of each deck and deck openings.  Here you can see this around the fantail deck, Promenade and Upper decks, and the stairway openings in the three decks.  The difference is striking when you compare those to the stairway openings in the topmost Lido deck, which have not been done yet.
The margin planks are made by carefully slicing one plank from the sheet of paper decking with a metal straightedge and sharp blade.  The ends of the strip are miter cut diagonally and softened with a misting of water before being attached with pH neutral white glue.  This is only done where the margin plank crosses the line of planking.  Where the opening is along the planking no margin plank is used, since the eye cannot distinguish their absence without significant magnification.
At the bow a margin plank was installed along the edge of the working deck to set it off from the gutters that border the bulwarks.  Another was carefully worked into a curve around the base of the Promenade deckhouse.  These planks are barely visible, but without them the deck looks unfinished and the deckhouse seems to float above the deck below.
Now I turned my attention to the machinery and fittings of the working deck at the bow.  From the plans you can see how many different kinds there are.   The side view does not have a great deal of additional information, but it shows how tall the deckhouse and other elements are.  However, many of the fine details are not shown on either plan.
To fill in the gaps I found a number of high resolution photographs which together show almost all or portions of the deck and the fittings.  Here is one of the most useful ones showing the entire layout.  It is even in color.   You can clearly see the separation between the wooden deck with the cargo winches and hatch, and the composite deck with the anchor winches and ground tackle fittings.
The first bit of detail that I started with is not shown on any of the plans, but in the photographs it is clear that there is a metal handrail across the face of the Promenade deckhouse between the several doors.  I made it from .011” wire which was straightened by rolling between two hard surfaces.  The pieces are attached with small drops of cyano fed to the wire with a toothpick as I hold it in place.  After I was satisfied with their placement, the handrails were painted with clear finish to help hold them secure.
Along the edge of the deck there is a scallop in the bulwark that is protected by a metal railing.  Photoetched 4-bar railings were sourced from Gold Medal Models and sprayed white.  On each side the railings were test fit and adjusted so one section set up just where a small fairlead had to sit, just forward of the wooden deck.  The lower two bars of each railing were carefully cut out at that location and secured with both cyano and white glue.  The 2-post fairleads, like the larger 3-post ones, were originally Bluejacket metal castings that underwent some radical surgery before being filed and sanded to final shape.
On deck, the major eye catching element is the deckhouse.  The plans only give a general idea of how it looks, so I turned to various photographs that had sufficient resolution to help.  They gave me almost all of the details, and I puzzled out the rest.
8.jpg.9e6205b359d9baac44c62c2333ff69f7.jpg8a.thumb.jpg.207987122e8b378eebaf8b710c80ebe0.jpg
Here is how it came out.  The most complicated area is at the forward end where the structure is not only curved, but angled as well.  This face leads to a winch control platform with four handwheels on stands protected by a breakwater that not only curves, but is angled forward.  Small sets of steps lead up to this platform from either side.  The sides have doors and what appear to be awnings that can be opened if desired.  The roof has a photoetched railing and a pair of ventilators made from styrene rod and tube.
At the base you can see a brown edging.  This was a feature of almost all of the structures, railings and bulwarks on the ship.    It was applied with an indelible marker and overpainted with a clear finish for protection while handling and for UV protection on the model.
Here it is installed on the centerline of the deck.  It had to be very precisely located, so slow setting white glue was used which gave me the time to adjust and readjust.  Once it was securely in place the back and wing edges were defined with margin planks.
The next major fitting was the large cargo hatch aft of the deckhouse.  Like the deckhouse, the overall size and shape were taken from the plans, but the details of the angled support pieces and the lifting mechanism were taken from photographs. (Sorry that the photo is a bit out of focus.)
Most of the other elements started life as Bluejacket castings, but were extensively modified and/or cleaned up before painting and mounting.  Here are (clockwise from upper left) the spare anchor, the large round winches, four small cargo winches, and a set of bollards.
The final elements in this area, other than the cargo boom cranes, were the breakwater wings that extend from the sides of the deckhouse towards the bulwarks.  They were built up from styrene strip with triangular buttress supports and a horizontal bar that was cut into the supports.  The cargo cranes stick up and would be in danger of being broken off during construction, so they were left off until a later time.
So here is that area with all its fittings in place, including the railing gates at the ends of the breakwater.
And for size comparison, here is the area with my patented 6-inch diameter dime.
Next, the fittings for the forward part of the working deck.  Until then . . .
Be well
Dan
Nice to see you last weekend and to see your progress, Dan. I always thought they were called 'spurnwaters', not 'breakwaters' - or is that an English English vs American English thing?
Druxey -
"Two peoples divided by a common language . . . "  W. Churchill
Dan
Hi Dan and Druxey, I am not sure if this applies to the merchant/commercial ships but in the 'grey funnel line' a breakwater was a larger structure, usually on the forecastle to 'break' larger waves/water coming over the bows etc.  A spurnwater was smaller and used to divert/control water - one place was the raised metal plates near the 'devil plates' to guide water to the scuppers.
Very nice detail Dan, this build is looking great.
cheers
Pat
Hi Pat, Druxey -
Well, whether a breakwater or not, it famously did not do its job.  I was going to tell this story later, but this seems a perfect segue - - -
On April 9, 1966 the Michelangelo left Genoa on a routine cruise to New York City with 775 passengers including German novelist Gunter Grass and the creator of Archie comics, Bob Montana.  After stops at Cannes and Gibraltar it turned into the Atlantic at its normal cruising speed of 26 knots - and directly into the path of a hurricane.
The weather worsened quickly and steadily and by the morning of Tuesday the 12th the ship was being tossed around like a toy, despite significantly reducing speed.  The ship shuddered every time the huge rollers slammed into the bow.  Terrified children screamed and clutched their parents, who were not any less scared.   Anyone trying to take comfort in any of the lounges faced injury from tables and chairs being thrown across the room.  Bob Montana recalled, “The waves looked like apartment buildings.  I was worried about how much the ship could take. The ship was not just rolling and pitching – it shuddered.  Things jumped, everything fell onto the floor.”
At around 10:00 a passenger, John Stienbach of Chicago, dared other passengers in the first class lounge to join him in his suite which had windows in the forward superstructure facing the bow.  No one took him up on his challenge, so he went alone.  Twenty minutes later the ship lifted on another huge wave and dove into the trough behind it.  Before it could lift the following wave, a huge 60-foot wall of water, crashed over the bow – tearing over the puny breakwater – and slammed into the face of the superstructure.   All of the forward facing windows were blown out in a hail of glass shards which injured, among others, the captain on the bridge some 70 feet above the deck.  John Stienbach was killed instantly.  Two others died of their injuries and 50 more were injured but survived.
Someone, possibly even Stienbach himself, took a series of photos of the bow driving into the waves.  This is not the fatal wave, but you get the sense of what it must have been like.  It is ironic that these are some of the best photos for determining the exact details of the fittings on the bow deck:
 x4.thumb.jpg.8ad9619f7038b5601423ccd558fd6869.jpgx5.thumb.jpg.d9da7aa9d1a6f1713b7237b58cf481e6.jpgx6.thumb.jpg.15258a5d517b744a7859e22fbe11d39b.jpg
The superstructure below the wheelhouse was buckled and caved-in by the force of the tons and tons of driving water.  The ship’s stem was bent backwards while metal bulwarks and over 100 feet of railing were ripped out of the deck and carried into the sea.  Damage to the interior cabins, lounges and saloons was massive. The aluminum skin of the ship was ripped open and a hole appeared in the forward bulkhead 45 feet wide and three decks in height.
The open deck at the bow had various fittings, strong enough to handle the anchors and mooring cables, torn loose or damaged.  In this photo taken from inside one of the lounges you can see how the port bulwark is damaged and the starboard bulwark has been ripped away.
Four days later, with the damage to the bow mostly hidden by a tarpaulin, she limped into New York harbor and into her pier.  After disembarking all of the injured to ambulances the shaky passengers went down the gangways and the ship went to the Bethlehem Steel shipyard in Hoboken where 115 craftsmen worked around the clock to make repairs.  In only four days the ship was ready to embark passengers again for a return trip to Italy.  Of the shipyard workers, Michelangelo’s captain would say, “They worked beyond expectancy, so quickly without giving us any problems – they just did it.”
The ship continued in the trans-Atlantic trade for another nine years until the governmental subsidies which had kept the Italian Line running dried up.  Like many other obsolete luxury liners she was considered as a hotel, as a yacht for billionaires, but was ultimately purchased as a barracks ship for the Shah of Iran in 1977.  She outlived her purchaser, but in 1991 she met her end on a breaker’s beach in Pakistan.  Sic transit gloria mundi.  So passes the glory of the world.
Dan
What I wanted to say, essentially, was that one of the most enjoyable aspects of Dan's build logs are the annecdotal glimpses into the history of the ship that he often provides.  In addition to that, Dan really scrutinizes the available photographic sources for useful details and it shines through in his work.
Edited by Hubac'sHistorian
Thanks for the story Dan, very interesting. I Sometimes have to remember the scale of this build - just to remind myself how detailed your work is.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi guys -
Glad you liked the tale of the great wave.  Sometimes it is pointed to as a piece of the reason why the liners gave way to the airlines.  For me, the story of the hubris of John Stienbach and his swift karmic punishment is another small facet of the wide, wild, wacky, woeful, and wonderful diamond that is the human experience.   Preserving these stories in three dimensions is one of the central reasons why I choose to model ships.
As for the small scale, Keith, it is all done with lots of magnification and lots of light.  Glad that the photos let you enjoy the nano-journey.
Dan
Hi all -
Here is the next step in the journey.
With the wooden decked portion of the bow deck done, I moved on to the forward area which was covered in just a composite waterproof material.  This area housed the ground tackle – the anchor machinery and the mooring equipment and lines.  Its color is quite variable.  In the first photo it looks dark brown, while in the second is a light grey, while another is a pinkish tan.  The medium grey is the most common, so that is what I went with.
1.jpg.b8bf59d66dc1af6f337543fe044679b4.jpg1a.jpg.05ecd2b1fc83c43f9ebf57986d6674ab.jpg
Some of the fittings here are familiar.  Five of the seven bollards are the same as on the cargo area of the deck, but the two which flank the anchor winches have small nipples on the forward posts.  Here is a photo from the ship, taken in NY harbor after the wave damage, and the fittings for the model with the two unusual bollards to the right.
The small mooring winch is similar to the two on the cargo deck, but the base is different.  In the photo, taken at the breakers’ yard, it is supported on a flanges and looks like it leans forward.  In fact the winch is vertical, the tilt is just to compensate for the upward sheer of the deck.  The model fitting was built up from a metal casting, a wooden base and styrene flanges.  The photo showed me that it needed some more touch-ups before final installation.
In the center of the deck is a companionway leading down into the engineering spaces under the deck.  It has a complex shape, with angled sides and an angled forward face.  There is a doorway on the aft face that is framed by protective barriers.  You can see it in the two overall photos at the beginning of the segment, and here is a close-up.  After a few initial missteps, the model piece was built up from a wooden core with my usual styrene sheathing and photoetched door.
The most complicated bits of machinery on this deck are the two anchor chain winches.  They are not detailed at all on the plans, so a great deal of information had to be gleaned from the photographs.  Unfortunately, very few showed these features from viewpoints that would have yielded a complete idea of what they looked like.  You can get the general look from the two overall photos, above, and here is a bit closer view from ahead.
After studying these and other photos, I believe I know most of the details. The machinery seems to consist of two large round winch heads that sit on a wide raised platform.  Like the base of the small winch, this platform tilts forward relative to the deck so the winch heads are vertical.  A sloping ramp leads the chain up from the hawse hole and into a covered tunnel under the winch head where it is pulled around and then fed inside a large elbow and down into the cable tier.
Along the way it is straddled by a fitting with two vertical arms that are connected by a bar with some sort of handles on each end.  I found out that these are called chain stoppers, whose purpose is to clamp onto the chain and take the strain off of the winch from the weight of the anchor.  Here is a smaller one, but the elements are the same, and it is easier to understand what is going on.  You can see how turning the handle would turn the bar with opposing threads, closing or opening the hinged arms to trap or release the chain.
So here is my latest iteration of the machinery.  Each element was built up from whatever materials came to hand, including hardwoods for the platform and ramp bases, plastic channel for the tops of the ramps, wood and metal for the winch heads, bits of plastic for the base and arms of the chain stopper, and iron wire for the threaded bar and handles.  The ramps are not yet attached to the winch platform, so the chain does not connect them.  This will be done at final installation.
There is one feature which I could not figure out.  The photos show that the hawse holes are not simple ovals with lips, but seem to have some sort of covering.  Unfortunately, this is the most detailed photo I found of the fitting.  I will keep hunting, but if nothing further is available, I will fake it as I make it.
So here is my first dry fit of all the components except the hawse holes.   I added the chain return elbows to the anchor winches and set the fittings in place.  Everything seems to fit pretty well and they tell a convincing story of how the ground tackle was laid out.
However, when compared to the photo, and although I am getting close, there are some significant issues.  The biggest is that the anchor winch heads are too close together.  I am still debating whether to cut the platform along the centerline and piece in to make it wider.  Is this too much work, and too risky, for not much gain?  Also, the chain stoppers are still a bit overlarge and clunky, especially the handles.  Is this getting too picky in a component that is barely a quarter inch across?
Final details and improvements – or not – next time.
Be well.
Dan
