Hello to all!
For my poor English ,the following was translated by software and maybe have some grammar or other mistakes .
The plans of L'ARTÉSIEN were purchased from France in last year,the ship is so beautiful and i want to make it(into a ship model) by cnc.
First I scan the drawings,then make it into 3d model or 2d Vector graph,Then NC engraving,Including 2D and 3d kits for example frames/figurehead...
My project starts from the stem and the main material is pear and jujube...
This process is almost all CNC machining, manual only assembly and polishing...
some photos of  Actually produced...
mill on double sides
The two faces are basically the same
Double sides milling of bow special parts...
The following is "no bridges"
The previous production was "have bridges" As shown below...
pre-assemble...
The figurehead ...
3d model
Although not very similar, I have tried my best...
NC machining programming and simulation
Preparation materials
It will take some time to process the finished product
By George, you've done it.  Bravo!
Dan
Fascinating to say the least.  How long did it that the CNC to make the figurehead?
Thanks Dan and Mark for your attention.
"Fascinating to say the least.  How long did it that the CNC to make the figurehead?"
Some areas that not carved by maching need secondary processing, it took me total about 18-20 hours to complete a primary processing- 0.8mm millcut/0.05mm stepover.
Thanks Jeronimo,and thanks everybody.
Maybe I will stop the buildlog for a while,I promised the request of a member to development of a private drawing of the frame and make its sculpture, including the figurehead.
This is the last update of the production of the figurehead.
After the figurehead is fixed, the support is finally removed.
Remove the fixed softener...
Finally, It's also need to be manually modified/polished and so on...
Although some busy, I still took the time to make the fifth figurehead, a little bit of regret is that some of the flaws of wood
Cn processing out of the sculpture is quite accurate, basically the same as the design,because it was not polished yet, so looks more rough.
Hi!  I am completely fascinated by what you are doing here, and will be following along with great interest.  In my opinion, the face of your figurehead - even in its rough, un-pollished state - is an improvement over the original.
  • 4 months later...
After an another project, I will write a new processing program and re - engraving the figure-head with  V type milling cutter.I also modified two errors and the face (head),more finer engraving results can be obtained by using the V type milling cutter.
Awesome figurehead HJX,
you must have a lot of experience with CNC milling and the right milling cutters thereto....:)
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work HJX.  Maybe I'm not seeing it but those carvings look perfect.
Thanks  Erebus and Terror   Nils   Mark     Gaetan Bordeleau    and   Hubac'sHistorian!
I finished second steps, because my machine is 4 axis, so many parts need to be engraved again.
In general, Maybe i can get better sculpture by using new model new processing program and the V type milling cutter.
If the eyeball is to be engraved, 0.1mm V type milling cutter is needed, but I use 0.3mm milling cut now.
The rssult of the left arm after additional carving.
Edited by hjx
HJX, the milling results are really pretty incredible! Even with just a small amount of handwork, you could finish this carving on a level that most would really labor to achieve by sculpting alone.  This is really a fascinating process that you use to make models.
I’m glad to see you are still plugging away at it, and I look forward to your progress.
Happy Holidays to you and all on MSW!
Edited by Hubac'sHistorian
