Wonderfully precise skilled work and a beautiful ship model in the making.  Look forward to following along and learning more from you Tiz!
Cheers,
Jason
In the shipyard:
Thanks to you for the appreciation, these are pictures of the work that dates back about ten years ago,
the exterior and interior finishing is over, the next works will be inside the hull
Edited by matiz
errorr
I am sure the cutter would work fine on boxwood (or the common replacement, Castello) but I wonder about the milling speed for a single cutter bit.  What milling speed was used?
Ed
Ed
Hi, EdT, my milling machine has a variable speed engine from 5000 to 22000 rpm, I use pear wood, generally for hardwoods such as pear and boxwood, the speed may be even lower, for softwoods, the speed must be maximum:)
Hi Matiz,
thats a beautiful model you are doing, I love those lines.....:)
Nils
Current builds
-Lightship Elbe 1
Completed
What a truly beautiful piece of work. Thanks for sharing it!
regards, IAn
