3 hours ago, CDW said:
I wonder if the hull is coated with some kind of radar avoidance coating?
I would be willing to bet money on it. May have some optical properties as well.
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
2 hours ago, CDW said:
In time, will likely build that model, too
You mean you haven't started it yet?:D If you do half as well as you did on the Independence then they will make an impressive pair.
https://www.amazon.com/Trumpeter-Freedom-LCS1-Littoral-Combat/dp/B005SZ5CIW
https://www.hobbylinc.com/trumpeter-uss-freedom-lcs-1-lottoral-combat-ship-plastic-model-military-ship-1:350-scale-4549?source=froogle&gclid=Cj0KCQjwnZXbBRC8ARIsABEYg6CpAf7E4zJ9N12j7MjnsnzQeed6JcFebN9EDLREl4v2iCcSMlGuyv8aAqKpEALw_wcB
https://www.amazon.com/Bronco-BNCN5028-Worth-LCS-3-MODEL/dp/B00B7ZD5Q8/ref=pd_lpo_vtph_21_bs_t_1?_encoding=UTF8&psc=1&refRID=DBTVCJ2CD10VCY43MMSV
I agree, I don't really know which design I like better, but the Freedom does look impressive underway. At 47 knots though I suspect it is quite the ride.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
It is the white balance WB setting, change from indoor (tungsten) to Daylight,   in Daylight the tungsten setting creates a blueish cast to the light;  in contrast the Daylight setting will cause a yellowish or orangeish cast when used indoors.
Jack
Current buildUS Constellation
Just shows you how hard it may be to see her in the early morning ocean/land mist as she closes in on the coast!:D (My imagination runs away sometimes)
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
On the top left hand side of my camera (looking at it from the back of the camera) there is a wheel with a mark of "WB" on it, along with other marks. Is that the mark that should be set to WB? It was set on a different mark.
CDW - Could be? But on my cameras, it's on the SET FUNCTION button (or FUNC SET).  On yours trying selecting it and see if you get a screen with various LIGHTING settings - you are probably on AWB (Automatic White Balance) which sometimes doesn't work well when you switch between indoor and outdoor especially when you take the camera off of AUTO mode and select one of the other modes, e.g. AV (Aperature Preferred/Priority), TV (Shutter Preferred) or P (Programmed), etc. On mine when I take it off of AUTO, I manually select the Lighting mode (WB).  I'm using a Canon PowerShot SX130.
Jack
Yes mate  - on the wheel marked WB you should be able to set it to WB  then another menu should show or you select,  in that there should be a menu of Auto, Tungsten, Daylight, Cloudy, Shade, Fluorescent,    Auto is normaly ok for most things except strong internal lighting from strip lights.
Hope this helps.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
she's a really sweet looking model............nicely done  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Great job CDW
Have you started the Freedom yet? :huh::stunned::D
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Excellent work.
OC.
Current builds
Completed works.
She turned out rather well Mr Bunny
I see you've got HMS Daring destroyer on your wish list ... I would have liked to see you build the former namesake, also a Daring class destroyer ...
(you might add Finished to your title... just a suggestion)
Edited by cog
Carl
  • 10 months later...
On 8/31/2018 at 3:37 PM, CDW said:
soon 🙂
CDW, is there any chance that you would be interested in selling this model? My husband worked at Austal in Mobile Alabama and during his employment had the pleasure of working on this ship. I would love to have it for him as a gift. Let me know, my email is caseymoore0715@gmail.com Thank you.
Nice build! Great painting. Mind if I ask how did you paint the bridge windows? Did you hand brush them with dark paint and then go back and touch up the frames with haze gray?
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
I replied to your query via email.
Thanks
CDW
Craig,
1st class on the build. Mobile is one of the cities that build the ships at Austal. They turn the things out on an assembly line not quite as fast as Ford and the model T but pretty quick. Went to a couple of launchings.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
4 minutes ago, John Allen said:
Craig,
My son in law says they built one of these LCS ships in New Hampshire as well.
I have a friend who retired from the Portsmouth Naval shipyard......if I see him,  I'll ask about that.   should be an interesting discussion  ;)   I didn't notice it,  but you finished it on my birthday ;)   kinda special.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 2 months later...
  • 6 months later...
Dear CDW,
Hello.  I created an account on this forum, solely so I could log on and thank you for creating this thread.
Having recently returned to modelling, I intend to build a catalogue of models of ships I have "worked on" and LCS-2 will be my first.  Your kind attention in detailing each step and giving small tips, including your various frustrations and successes has been a really useful resource for where I can locate certain parts and adopt good technique.  In particular, your attention to detailing the aluminium (shall we say "ageing"?) process on the hull is, rather fantastic.  Many others have incorrectly added a "rust" effect.
May I ask - did you prime this model prior to painting?  Rattle can?  And is the Valejo air paint you used an acrylic base?
BTW - As a former keen photographer, I'm guessing that you tried to take those photos outdoors within a hot and slightly humid environment, having rested the camera indoors, within an air conditioned environment.  Assuming this is correct (and I apologise in advance for assuming) you should be aware that camera lenses do not like being dragged from cold / conditioned to hot and more humid.  It is best to leave the camera in a bag (shut) outdoors for 10 minutes, ajar for 10 minutes, then open for 10 minutes and then cleaning the lens (just in case) with a lens cloth, before lining up your shots.
Many thanks again, P_A
