Just done a rough  sketch of the lid/pully device assembly  - The idea is to use a piece of  stock wood,  then I will add a small piece of square stock at the end (slightly wider)  then I will drill a hole in the center just wide enough to take some rope (same thickness as I used on the lids) the rope will be glued in the when set I will drill a small hole through the hull, then push and glue the assembly - to allow a certain amount sticking out, then when set the rope will be joined to the rope on the lid.
Only have to do this Ten times.
Heres my diagram  -
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
7 minutes ago, popeye the sailor said:
where are the rope that open them?  on most early ships, the ropes are tied along the spar deck railings  {then I got a brain storm........look at the instructions}    they are tied to poles that jut out from the hull above them.  even though you choose to have the ports closed......you'll still need to rig them.   I do find it odd though.......do the sailors hang from the railings to open the ports?   strange design :blink:
On the actual ship - the beams sticking out are hollow and they  have a pulley  at the end, the rope comes up from the lid  past over the pulley then through the beam  and into the inside of the hull, where it would be pulled/let go to open/close the lids.
OC.
Current builds
Completed works.
We all love a plan, looking good, but strange lid port set up
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Indeed mate,  but guess pirates like to keep things quick and simple - hence the single rope.:piratetongueor4:
OC.
Current builds
Completed works.
Maybe since the 1:1 ship is a fictional movie prop, not an historical sailing vessel replica, certain artistic liberties are taken to simplify the construction of it yet still look authentic to a certain degree for the average person/movie enthusiast. In that case, functional gun ports would not be an issue that would warrant excessive spending to achieve.
Let's face it, the average person is not well informed at all on early sailing vessels. A reasonable facsimile is good enough for a Disney pirate flick. Johnny Depp as Jack Sparrow is ample evidence of that.
lol - point taken
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
38 minutes ago, Wallace said:
By the time you get to the 10th one you should be good at it :)
Indeed - its like a never ending cycle where we are always improving and never fully satisfied.
OC.
Current builds
Completed works.
It may be a simple design but, it looks like a maintenance nightmare. Storms and gunfire probably made replacing these a constant chore. Still, they will make for a cool detail that is not often seen on models.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Here is a close up pick of the actual ship  off the net  - shows the lid devices.
OC.
Current builds
Completed works.
Indeed, there are several things that make us modelers scratch our heads... the capstan with the main mast coming out of the center of it comes to mind.   Ah... movie magic.... ;)
But I must admit, I enjoyed the whole Pirates of the Caribbean series as much or more than anything else I have seen for a long time. Very entertaining, light hearted, and the musical scores were great!
6 hours ago, Wallace said:
Johnny Depp as Jack Sparrow certainly was a "loveable" pirate.
Yep,    alas he wont be cast in future films  - not sure why?
OC.
Current builds
Completed works.
So - the work begins on the lid lifting devices  consisting of a piece of 1x1mm  with a piece glued onto the end, then a fine drill in the center of the end, and some rope(thread) glued into this,   two done  16 to go.
OC.
Current builds
Completed works.
Right then  - four assembled and fitted.
OC.
Current builds
Completed works.
33 minutes ago, Wallace said:
We had a word for something like this back when I was a youngster - "finnicky". It is a word I probably haven't used since then but it sprang instantly to mind when I saw this :)
Its certainly best doing it in small sections  to break up the  repetition,   I have the remaining five built and drilled  waiting on the ropes to be glued in place  - tomorrow.
Then the same for the opposite side.
OC.
Current builds
Completed works.
Doing both sides!!!!!!!?
Very nice OC. will you shape the rope in a roundish way with pva?
Carl
Just tying it where the rope and the loop meet.
OC.
Current builds
Completed works.
More work today  - painting the first of the lid lifting tackle  - then I fitted the remaining five  - next off  tie them and add a bit of paint.
Then it will be on to the other side.
OC.
Current builds
Completed works.
Good day all,      Thank You sincerely  for all the  likes it certainly helps,     anyway  back on the pearl today  - nothing of  any significant interest,  I constructed the  nine rope lifting beams for the other side - just a length of 1x1mm  with a small block glued onto the ends, just need them to set now before drilling a hole in the ends.
No pics as  its just the same as previous pics.
OC.
Current builds
Completed works.
27 minutes ago, Wallace said:
It is just as nice to read about your progress as it is to see the images O.C. Because of the very cold weather here I too will be ensconced in the shipyard throughout the day.
Thank you for your kind words wallace.:cheers:
OC.
Current builds
Completed works.
More work today  -  I cleaned up the lifting beams  then drilled a hole in the center/top of each, then I cut nine lengths of rope and stiffened the ends with some pva, then I glued the ropes in place as before.
Just a couple of pics -
OC.
Current builds
Completed works.
6 minutes ago, cog said:
small steps will get you there. I'm always surprised at the smaller the item the more work it needs ...
Indeed,  also an element of monotony  doesn't help.
OC.
Current builds
Completed works.
Thought you were a big fan of those ... you do them so extraodinairy well ;) Now you've got patience as virtue too :D
Carl
Wait till I get started on the standing rigging  and  shrouds  - that will test my patience...........and everyone elses.😧:o
OC.
Current builds
Completed works.
Keep on plug'n OC, I also like to see the little things taking shape.  Just have fun.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Thank you for looking in piet,    your words of encouragement help no end.
OC.
Current builds
Completed works.
i had the same issue of inserting all the sheaths above the gunports, and then securing the lanyards, it took me weeks, then i did them all again, because i i got better it showed up on the earlier ones, hence i vowed never to do another first rate again
and then what happens, Chris Watton, is designing new ships, so maybe there will be another one in the distant future, after the St Nectan
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Mind you - not far to go now,  after I fit those and attach the ropes/paint them,   I can then move onto the anchors - im looking forward to doing the anchors.
OC.
Current builds
Completed works.
ooooooooooooh i forgot i have lots of anchors to do, at least 6
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
