9 hours ago, Old Collingwood said:
discovered I need four sets of hands for each knot.
That's why you come equipped with ten fingers,ten toes, and.....TEETH! :huh::D
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Teeth is a sore point  - but my fingers are doing fine collecting super glue nicely - when I smooth some of the threads where I have tied them off.:huh:
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
More work today  - I finished off the foremast shrouds - then lashed them underneath the trestletrees to tighhen them up,    then I cut away the temp tentioning rope.
Next job was to work on the masttop  -  first I studied the smaller deadeyes I have (wood stock)  I needed to find away to attach these  - "Ah Ha"  I have some fuse wire in different rate (thicknesses)   -  so I rapped the fuse wire around the deadeye  and twisted the ends with pliers, I then pushed the end through a pre drilled hole in the deck of the masttop then added a dab of ca  - so six deadeyes where fitted using the same system, and it was finished off with a railing.
A few pics  with one showing the tops dry fitted.
OC.
Edited by Old Collingwood
Current builds
Completed works.
OC.
use yer gums ... you must be accumulating finger bushels ... diminishing loose dgits by the pair
Carl
Gidday O.C.
She sure is looking good.
You are making a fine job and progressing well.
Keep maintaining this standard and she will something to be proud of.
I can empathise with your 'sticky fingers' I sometimes end up with my fingers stuck to my head.
(Another poor attempt at humour).
Wishing you and your family all the best.
Mark.
6 hours ago, Wallace said:
The shrouds look good O.C. I am thinking that the builders critical eye will pick up any height difference in the shrouds, from where I am sitting they look just fine.
Thank you so much.
OC.
Current builds
Completed works.
5 hours ago, pontiachedmark said:
Gidday O.C.
Mark.
Thank you kindly mark.
OC.
Current builds
Completed works.
Evening all  - more progress with the foremast,  firstly I painted the lower deadeyes and ropes,   then I did the same to the tops  - after this was dry  I worked on fitting the futtock shrouds, these were fine black tread treated with thin pva to stiffen and de -fuzz the rope,  I then wrapped then around the base of the deadeyes - twisted them and added a dab of ca, this was repeated till all six were done.
Next job was to create a sherpole on each upper section of the shrouds - I did this by using the same thickness of thread as used in the shrouds, I glued this with ca behind the shrouds, then when set I glued down the tops into position on the mast.
 A short coffee break then I set about attaching the futtock shrouds to the sherpole - this was done with a couple of tie overs then a dab of ca to lock them inlpace, I finished this off by trimming some ends.
I then decided to test the action and position of the lifting tackle/blocks  by routing the lifting rope up through the shrouds and the  gaps in the tops, just about right I think.
So heres a few pics including test fitting the lifting gear  for the lower spar.
OC.
Current builds
Completed works.
2 minutes ago, cog said:
It really makes a huge difference, compared to the plastic rigging from the kit
Yep it is taking A lot more time and concentration  but I think its paying off,    its also a geat way to learn more about seamanship   and nautical terms  (before building the pearl if somone had mentioned a Lift - I would have thought  - people getting in it to go up or down)
OC.
Current builds
Completed works.
Not to mention the face thing ...
Sad faces  -  Deadeyes?
OC.
Current builds
Completed works.
The rigging is coming along very well. Taking your time and planning ahead so you can understand what the various ropes are doing makes it go a lot easier and you seem to be doing that just fine. Very happy that you took up the challenge to rig her properly instead of using the plastic formed shrouds. With all of the effort you have put into the build, I think those would have detracted from it. Well done!
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Thank you sincerley EJ.
OC.
Current builds
Completed works.
More progress today  -  next was the pre-molded topmast/topgallant,   I decided to have a go at replacing the topmast section for a piece of wood dowel,   first I cut off the mastcap assembly - then after cleaning it up a bit, I drilled a hole  to take the thicker end of the topmast, then I shapped it so it was narrower towards the top, then again I drilled a hole into the top mastcap - after I glued both sections between the wood topmast with ca.
I decided to use the plastic topgallant  but smeared it with ca and cleaned the exsess off  - this helps to strengthen the plastic, I then force dried it with the venerable hairdryer  and finished it off by painting and weathering.
I then worked on - and fitted both sets of lifting blocks  in the same maner as before.
Just the one pic today  of the unpainted wood topmast fitted.
OC.
Current builds
Completed works.
1 hour ago, marktiedens said:
Very wise to replace those plastic masts with wood.
Thats what I thought mark - with the tention off all that standing rigging, I have even braced the inside of the main mast sections where they were two part sections.
OC.
Current builds
Completed works.
So I got my second wind  - so I glued inplace the upper/topgallant mast  - got it ligned up, then  I constructed the front upper stay,   first I  built the bowsprit block attachment - this forms a triangler rig,  then I lashed the top of the upper mast secured it with ca  and ran the stay through the bowsprit block, it will be tentioned and lashed when I attach the four side stays down to the deadeyes.
Three more pics.
OC.
Current builds
Completed works.
10 minutes ago, Wallace said:
You are making well planned and even better executed progress O.C. It is a joy to watch her coming together sir.
Thank you wallace  - Im actually enjoying the rigging  (not so much the shrouds).
OC.
Current builds
Completed works.
11 minutes ago, CDW said:
I agree whole heartedly. It's a lot of fun seeing the Black Pearl come alive with detail like this. You'll have one-of-a-kind when you're done with her.
Thank you so much for saying that mate  - getting compliments like this is just so inspiring, and puts a smile on this pirates face :dancetl6:
OC.
Current builds
Completed works.
Right then plan for tomorrow  - Im going to try some knitting  - only joking,     I am "wait  for it - wait for it"    going to  build/paint/weather  and fit the anchors  as the cables are there  so is the cathead.
OC.
Current builds
Completed works.
Very nice progress OC, even starting with wood!  Wooden masts, real rope shrouds - - hmmm - before we know it you'l be building a wooden ship from scratch.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Thank you Piet,    its amazing what can be done with an already very well constructed kit - it makes detailing it so much easier.
OC.
Current builds
Completed works.
Probably already explained this  - a cure for fraying threads used for our ropes - spread watered  down pva into the thread between yor fingers, it smooths the thread yet it still reamins  flexible.
OC.
Current builds
Completed works.
Gidday OC.
Don't sell yourself short. Plenty of ugly ships have been made from "well constructed kits".
As I have stated, keep up the work to this standard and you will have something to be proud of.
All the best to you and your family.
Mark.
10 hours ago, pontiachedmark said:
Gidday OC.
Mark.
Thank you sincerely mark.
OC.
Current builds
Completed works.
Anchors,    so today I assembled the two kit anchors  each comes in four sections,  first thing I had to do was round off the shank  as it had a square section, I then did abit of  smoothing to hard edges  then I glued the arm to the shank,  the stock was in two sections  this was wrapped around the shank and glued,   the stock had molded on lashing ropes  - instead I sanded it all flat  and lashed it myself using fine black thread.
Next off  painting/weathering.
Just the two pics.
OC.
Current builds
Completed works.
catching up on your progress OC,  and I must say...your doing a splendid job!   don't be too concerned if the dead eyes and lanyards are a tiny bit off........it looks more natural.  having them all the same length is merely for appearance purposes only ;)   figured someone would have told you this......it pleases me to break the news to ya  :D   here's another little tip for ya.........if you were to touch the woolings on the masts {those wrappings on the first mast steps} fore,  main and mizzen,  it will enhance her a bit more.   you can either use a color close to the standing rigging,  or a flat brown,  thinned down a bit....kinda like a wash.  it's a bit more detail.......it's up to you if you want to do it.........you've done a really great job with the weathering along the entire model.   the dead eyes on the tops came out nice as well........the smaller size is some really good thinking.
keep up the stellar work......she's look'in superb!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
