3 minutes ago, CDW said:
I am sorry to say, but a complete deal, extractions and dentures, would run around $3000 and up depending on the number of teeth that needed extraction and the quality of the denture appliances. Sometimes, there are dental clinics, even dental colleges, who offer discount prices. It requires a specialty to sedate the patient. A standard dentist cannot do it. That's one reason it's so much more expensive.
Puts me out of the equation then.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Anyway  - despite how painful me mouth might be  I aint bowing out yet  got too much to do  - got the pearl to finish for the admiral,  got that film about Nelson/Trafalgar I am still pushing to see it made for a good friend,   and I am also involved in trying to create a taxi worthy Sea Harrier jet  for another friend.
Oh and dont foreget my project in honour of my late farther.
Busy busy.
OC.
Current builds
Completed works.
So later  - I will finish the main mast ratlines, give it a coat of paint then fit the futtock shrouds to the top  before fitting it to the mast.
OC.
Current builds
Completed works.
If unfinished projects is now the gauge for longevity, then I am pretty certain I am destined to live forever!
Add the taxes they charge me each year that they would miss if I'm gone and I am almost certain the Government will keep my body functioning as long as it is less expensive than letting me die, even if I only exist as a vegetable. I am almost certain that I am the sole source of revenue for some program or another out there!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
You need to start building on here  lou  - life is to short  we want to see  your work...........no excuses.
OC.
Current builds
Completed works.
Oh I have no shortage of excuses!
The latest is a doozie, I will probably be able to milk it for a few months at least.
But then if I was making headway on my own builds then I would have less time to follow the fantastic builds you guys are doing and I am so jealous of. Right now I am content on watching my betters produce works of quality that I am following in spirit rather than trying to match in person. Hopefully things will settle down by the end of summer or sooner and some other crisis will not appear from nowhere and distract my building desires further.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Not something to like, American gents, do not try to compare the US system to the British. What works at your side of the pond, often doesn't on this side, same goes for legal actions.
OC did you smoke or still do? I had the same problem as you had due to smoking, and had my teeth pulled as it was the only way to get rid of the recidivist abcesses I had. Lost a lot of my jaw's bone structure as well because I postponed it to long. Do not wait to long
Carl
Not really trying to compare, at least not in my case. Other than to say that our "new" system is not really any good for the majority of people, especially those at the lower income level that it is supposedly designed for. Now days instead of not being covered, all to much of the coverage offered is ineffective as it does not cover the things it should. This is especially true with the dental coverage available both through Government and private sources.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Nope never smoked carl,   just spent to much time in my past with a sweet tooth   and paying for it now.
OC.
Current builds
Completed works.
Evening all,   so I decided to to have a go at the rest of the ratlines on the mainmast - I completed them  and also attached the futtock shrouds to  the masttop deadeyes,  I then fixed the masttop inlpace and tied the futtock shrouds to the shrouds.
Just the one pic.
OC.
Current builds
Completed works.
5 hours ago, zappto said:
Beautifull work! I did read that inflamation can intoxicate all body ! You should get your dental treatment !
Thank you sincerely.
OC.
Current builds
Completed works.
Good day all,   some more good progress  on the pearl  - I worked on the foremast yard placement ropes/blocks, these were lashed to the forecastle bulwarks - then connected to the yard blocks  and tied/glued back down to the bulwarks.
I took her outside for a few pics -
OC.
Current builds
Completed works.
11 minutes ago, CDW said:
Very nice. She is very much looking the part of the infamous scourge of the seas, the Black Pearl.
Thank you mate.
OC.
Current builds
Completed works.
1 hour ago, Canute said:
Looking good, OC.
And hope you're feeling better.
Thank you kindly,  still have a sore mouth  but trying to take my mind off it.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Good day all  another good day  - I decided to make the footropes on the lower foreyard, I know they have one support in the middle each side, and as I wanted this to be straight and hang down correctly,  so I tried some fine fuse wire  - I wrapped this arround the yard then twisted it together in tight twists and left the two end loose,  I then attached som fine thread around the opposing side of the yard,  then twisted the ends of the fuse wire around the thread  and tied the ends and dabbed some ca to lock it.
I made sure it had some sag and touched up the fuse wire  - I think it looks ok.
OC.
Current builds
Completed works.
I have also been working on the main - foremast upper stay, I constructed the two double blocks and lashed them in the center  - then I lashed the stay around the foremast tops  and fitted the blocks,   It will be swung around and attached to the rest of the stay when the mainmast upper section is made and fitted.
OC.
Current builds
Completed works.
29 minutes ago, cog said:
not to shabby a job for a first time mate. rather nice actualy
Thanks mate,  I thought the foot ropes was going to be a right pain, but the fuse wire came to the rescue.
OC.
Current builds
Completed works.
1 hour ago, Wallace said:
Wow, she looks nice in natural light too OC. Really very well done, she is a thing of beauty sir.
Thank you wallace.
OC.
Current builds
Completed works.
Looking fantastic OC!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Cheers,
Thank you kindly Piet.
OC.
Current builds
Completed works.
12 hours ago, pontiachedmark said:
Gidday O.C.
I had faith in you overcoming your temporary malaise.
She sure is looking good.
I also hope your dental situation improves.
Wishing you and your family all the best.
Mark.
Thank you sincerely mark,   yep mouth is on the mend slowly.
OC.
Current builds
Completed works.
Nothing much really  - just  making another yard including the lift blocks and foot rope supports made form fuse wire.
OC.
Current builds
Completed works.
OC.
Nice work, OC.
Where do you acquire your fuse wire? I love keeping stuff like that fuse wire on hand...it always comes in handy for modeling projects.
I often strip all the wires out of old appliances and computers to later strip away the insulation and use the stranded wire inside for similar things as you are doing here.
5 minutes ago, CDW said:
Nice work, OC.
We have a household store over here called Wilko  down the tool section they have plugs - extention leeds  and little cards of fuse wire that comes in three ratings, I use the thinest  think its 3amp.
OC.
Current builds
Completed works.
