Very impressive work Antony. Looking forward to some more updates.
Cheers............Fernando :cheers:
Current Builds - Colonial Brig Perseverance 1807 by Fernando E - Modellers Shipyard - 1:48 scale
Previous Builds -
S Lucia by Fernando E - Panart - Scale 1:30
Sloop Norfolk 1798 by Fernando E - Modellers Shipyard - Scale 1:36
Hi.
Thanks for your kind comments.
Second deck is now under way and the method of marking and positioning the deck beams is real easy and full proof.  Making easy work for each deck.
Will post pictures mid week with details on how the deck build is going.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Hi Antony, the model is coming along very well and your workmanship shows in the clean execution so far.  Nice solution for the deck beams on the bandsaw.
Michael
Hi.
Another update..
Tree nailing the deck and adding the gratings.
Drives me nut's treenailing..
All cut off and sanded.
Spent a little time this week marking out the beam positions for the second deck.
This deck was much easer than the first deck as I did not have any thinking and planning to do..
Hanging knees are glued to the deck beam at this stage. Nothing of this deck is fixed to the hull.
Knees have been pined and retested for fit.
Will be fixing the beams and the Lodging knees next.
and tomorrow I will fit the Carlings.  and if time and fitting go well then I will also add the Ledges (already made).
Thanks for looking in.
Regards Antony.
Completed Mayflower
Nice work Antony.
BTW what did you use for the tree nails?
Cheers...........Fernando :cheers:
Previous Builds -
Hi Fernando.
Cheap cocktail sticks soaked in dark stain for 3 mins then thoroughly dried. Hole was drilled with 0.6 drill bit.
Then glued in place. Dried for a couple of hours then Cut with small side cutters then sanded.
BTW The scale of this model is 1/26.
Will be using Tulip wood for this deck as I like the hint of green in the wood.
Regards Antony.
Completed Mayflower
Hi Again.
Thanks for stopping by. and the kind comments.
Had a good 2 days on the deck... Now finished.
Carlings and Ledges in place. Not glued at this stage..
Close up of the woodwork.  Messy as not yet sanded or fixed.
Big jump to Completed Gundeck. just the trimming to do.
looking at the underside of the Gundeck.
Waterways in place
As it is right now.
Will trim the deck tonight and install the hatch surrounds.
Next is the Main deck. This has a step at the 3/4 of the way towards the stern. Also there are a lot of furniture bits on the main deck.
I think 2 weeks might see it through. But we will see.
Regards Antony.
Completed Mayflower
A very interesting build Antony - and amazingly quick.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi.
Thanks Keith. Yes this is going together very quickly as there has been a lot of planning on how things will be constructed. Also lots of the timber has been pre milled ready for use.
Another update.
Lots of little bits made since the last post.
And main deck is complete. Was done in the two weeks as most of the timber was already prepared and milled.
The whipstaff steering was a new thing I have not encountered before.
Two pumps of this ship. The other one is on the other side of the ship and will not be visible.
Only 4 of these on each side of the ship.
The rigging for the guns ready made up.
Rudder and tiller arm. Copper will be blackened after making the opposite set of hinges (The ones that fit onto the ship).
Whipstaff area. This will also be blackened when finished.
I have lost count on the number of different timber types I have used so far. I like to mix the woods types to give a better contrast.
The next step will be to plank the exterior of the ship.  This will mean removing the ship from its jig and laying it onto a flat surface and clamping it as not to let it warp while doing the external planking.
I will use 3 different types of timber on the exterior planking.. Walnut, Ash, and Cherry.
Regards Antony.
Completed Mayflower
Beautiful grain on the rudder - the rest is pretty amazing as well.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Hi Antony, beautiful work and I like the wood your using.
At the rate your going you should be finished in a few days!😉
Cheers....... Fernando 🍻
Previous Builds -
Very nice to focus on the inner workings of the ship, it is usually mostly hidden. great vision and craftsmanship you have! Thanks for the lesson.
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Just catching up on your build Antony,
excellentwork !!
Nils
Current builds
-Lightship Elbe 1
Completed
Great work and craftsmanship. I love these models with detailed interior.
Very inspirational and beautiful. Thank you for sharing with us.
Best regards,
Doris
Doris
Current build:
HMS Royal Katherine 1664 from card
Hi Antony
My name is Nick Dawe, I am Head of Academy of Engineering and Advanced Manufacturing at City College Plymouth.  With regards to the Mayflower, I wonder if you might be able to give me a call on 01752 305810.
Nick
HI.
After a extensive break from model building.. Im'e back :)
Hi Nick. Yes I will contact you tomorrow .
No photos today … But I will post some tomorrow afternoon.
Started the external planking with Ash stripes  6mm X 1.5mm Yes small for the scale But the effect is nice. I started from the garboard plank and working up slowly.
At the gunwale I will use walnut strips up to the main deck handrail then I will use Mahogany strips. Should look Nice... (NO PAINTING...)
All the decks up to the Main deck are completed and will need the small bits adding on model compression. Cannons are made and Rigged ready for installation.
That's it till tomorrow.
Regards Antony.
Completed Mayflower
Hi Antony
Welcome back and I'm looking forward to some more photos.
Previous Builds -
Hi.
The photos as promised..
The planking is glued and as yet no work has been done to finish it off.
I will just sand and clear seal it after completing the tree nailing. (With 4 coats of clear Danish Oil)
The Stern area with lots of stealers 1 length had 4 stealers in it ..
Another shot looking forward/
The Bow area.
The internal works to date. Stern to Bow.
Another shot Bow to Stern.
A closeup of the stern area.
A Shot of the lower stern area (Transom)
As you can see I use miniature self tapping screws to hold the planks in place then they are removed ready for tree nailing. The screws are quite long as it helps to hold them in place while fitting them.
The holes are predrilled and so far I have has NO splits in the planking. Its NOT the screw head that holds the planking in place.. Its the thread.
Lots on Ebay listed as Micro self tapping screws. from 1mm upwards.
Will show more progress as the planking continues upwards.
Regards Antony.
Completed Mayflower
It's great to see you back, Anthony.  And the progress on the Mayflower looks good.   The idea of thin screws for holding the planking for gluing is a great idea.
Hi.
Another update.  Lots of work done this time.
The hedgehog. There is nothing more to be said about that picture.
Treenails in but not cleaned up at this stage.
Again treenails are in but not sanded at this stage.
Started on the beak. And timbers onto the side of the ship.
Gunports laid on top of the planking. With cling film to stop excess glue getting onto the ship. The get the correct curvature doing it this way. And they are way oversized at the moment.
Started on the upper transom (Not shown the pictures as it is drying at this time.)
All going well and will start constructing the rest of the decks next week.
Thanks for the likes. And comments.
Regards Antony.
Completed Mayflower
Hi Antony
Really coming along and already looking beautiful.
Previous Builds -
Hi.
Another update on the build.
The stern section. The Tudor Rose is a wood carving from E-Bay.. More timbers to be added to this area later on.
The Beak area. as you can see in progress at the moment.
Ladders are not glued yet as I have more work to do in the deck first.
Not 16 century and a tad small... OK he is 5' 1" high.. Easy solved.
Not a lot to say.. Sorry but that's me.
Regards Antony.
Completed Mayflower
Great work so far. Enjoy your detailing!
Antony,
great work, I`m enjoying your build, the idea for building a half-model is realy special to look at... appl.gif.b6d3a2ca07c7cb649fd4c7ca2ede3ac7.gif
Nils
Current builds
-Lightship Elbe 1
Completed
