Thanks to everyone for their kind comments and thanks for the likes.  Chuck, repetition like this is the reason I hate rigging.  Remco, considering your avatar, that is a true compliment.  I brought my first completed carriage with cannon to my local club meeting last Saturday so Kurt is referring to the pictures which will follow.
Toni
Member IPMS
                           Utrecht-1742
The cannon were addressed next.  My original intention was to cast my own cannon.  But after looking at the dimensions of the cannon available through Syren, I decided to cheat and use his instead.  Maybe someday...  I also purchased Chuck's monograms to apply to the cannon barrels. I bored the barrels to the correct diameter and then blackened them in Birchwood Casey. Specifically, they were cleaned in isopropanol and blackened for approximately thirty seconds. They were then rinsed in water and wiped dry.  The process was repeated five times.  Finally, they were rubbed down with a paper towel.  The monogram was applied with CA; Titebond did not hold.  The monogram was "painted" with archival marker.  Now it is time to mount the cannon barrel.
Toni
Member IPMS
                           Utrecht-1742
Hi Toni;
Thank you for sharing the pictures of the cannon,  and all the rest of your log.
I made the cannon for my current project at a scale of 1:64.  I then decided that I just had to build it at 1:48. So my cannon were consigned to the 'might use one day on something' box.  But having seen the cannons you have made,  and some of the others' work on here making them,  I think that I would have re-made them anyway,  as they just are not up to the standard that can be achieved.
Keep up the good work.
Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
just perfect, very nice!
Cheers, Daniel
Cheers,
Daniel
In dockyard: HM Colonial Schooner for Port Jackson (scratch), HM Armed Vessel Bounty, HM Cutter Sherbourne
Next builds: HMS Victor 1797 & Gannet 1814 Cruiser class sloops, ship and brig rigged (scratch)
Thank you Druxey, Mark and David.
The gun rigging is next.  I chose to show only the breeching and the gun tackles.  With the open deck, the train tackle just did not look right.  The first step was to make the correct rope.  The breeching is 4" in circumference and the tackle line is 1.5"  In TFFM, the tackle is shown as a left hand laid line.  So I made a bunch of it using three strands of 100 weight crochet thread.  Something did not seem right so looked in all my sources and they all stated right hand laid (or stated that all rope was right hand laid unless stated otherwise).  There are not exactly a lot of 18th century ships still afloat so I decided to use the Victory as my model.  Her cannon are rigged with right-hand laid tackles and left hand breeching.  So I remade all the tackle rope...correctly this time.  The breeching is made with three strands of 50 weight thread.  Did I mention that the ropewalk handle broke off in my hand in the middle of all this? I like to secure knots with Titebond.  In order to do that I use a water based stain by Minwax, Woodsheen, in manor oak.
The blocks are made by laminating the pieces together and then carving in notch for the strop.  One block has a strop with one loop and the other has two loops.  The strop is served with some ancient thread I found in my sewing machine.  The pictures show the sequence of "splicing" and serving the strop.  I tried but was unable to actually splice the rope this size.  First, the line was served, leaving extra unserved material on either end.  The two ends were mated and glued together.  When dry, they were thinned down to decrease the bulk and stiffness.  The rest of the strop was served by hand.  Finally it was given to the block.  Not perfect, but it was the best I could do.
The ring bolts for the breeching and tackle were temporarily attached to the hull.  On Victory, the breeching is secured to the bolt with a loose knot which looks like a pretzel. It is then secured to itself.  I duplicated that here.  The second picture gives a good view of the knot.
There is a hook on each of the tackle blocks.  The ring is at a 90o angle to the hook.  The tackle is frapped.  I wondered how neat and tight this frapping would be in reality.  Back to the Victory pictures.  They are relatively neat but not very tight, so that is how I depicted them.  I have not decided what to do with the end.
Toni
Member IPMS
                           Utrecht-1742
Those are very acceptable looking strops, Toni. Is there enough length to hook both ends of the frapped side tackle, though? If the gun is run out, those tackle would be cast off ready for action.
Thanks for your concern, Druxey.  There is enough length on the tackle to hook both ends without it looking taut.  The hooks are possibly a little too long.
Toni
Member IPMS
                           Utrecht-1742
Hey Toni! This is a very nice build you have! Those cannons look very good! I did notice that the cannon in this picture has one of the metal fasteners loose.
It's on the left. I wish I could have met you at the meeting. I hope I can another time! Also, thanks for the journals :)!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Sharp eyes, Elijah.  Thank you Johann.
I was able to finish up one of the cannon today.  Only seven more to go!
Toni
Member IPMS
                           Utrecht-1742
Nice gun rigging Toni!
-Elijah
Current build(s):
Completed build(s):
Member of:
The rest of the cannon have been rigged and mounted!
Toni
Member IPMS
                           Utrecht-1742
Nice work and a great model,  Toni.  I like the idea of the lids on the stove being in brass;  think I'll do this myself,  even if they will hardly be visible.
All the best,
Mark P
Jose, Tom, Elijah, Greg and Mark thank you for your comments.  Druxey, if I had to rig one more cannon I think I would have gone postal.  Truthfully, if this were a larger ship I would probably have done only one or two cannon with all the trimmings.
Toni
Member IPMS
                           Utrecht-1742
Thanks Tom.  This kind of repetition is why I hate rigging.  Greg, at one point there was even a lazy seaman in one of the hammocks.  But robin opened my eyes to how cheesy it looked and I sent him packing.
Toni
Member IPMS
                           Utrecht-1742
Nothing is cheesy about your ship, Toni.   The cannons, though tedious, look great.
G'day Toni
Brilliant work on the "big guns" mate. They look superb on the deck!
Just curious thought, what was the thickness of the ribs? They look so authentic!
Haveagreatone
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Fantastic work Toni, too bad I cannot see it up close.  I think you did a wonderful job in getting everything rigged and placed properly I commend your patience.
David B
Thanks Albert, Mark and David.  And thanks for the likes.  Greg, what do you mean by the ribs?
Toni
Member IPMS
                           Utrecht-1742
