HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 64 donations so far out of 49,000 members - C'mon guys!) ×
Keith, only you could make a rubber dingy look handsome.
10 hours ago, TBlack said:
Ever try rowing one of those things? No fun,
Yes many times - usually on route to pub when the motivation was high and then back from the pub when senses were dulled. But i was much younger then!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Reminds me of our trips to the Carribean, e.g. the BVI and USVI. Took the dinghy to on-shore bars and restaurants and after some drinks (the bartenders took a 1 pint plastic beaker and went up and down the shelves until it was 3/4 full - the rest was topped up with orange juice - a concoction called 'Force 12') we had to find our anchored boat in the dark. They all look the same, the hired boats. Eventually, we tied some towels to the rail, to look a bit more distinct ...
Eberhard - A good plan but not fool proof. We once had so find the yacht after a thick mist descended but drink made us brave and we were lucky.
I too remember all those beach bars and lethal cocktails, even more lethal the day after I recall.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Going around at night in a dinghy, one can also have strange encounters: we were motoring back out to the boat in a moon-lit night in the usual condition of constrained perception, when suddenly there was a big splash. We first thought that we hit something, but when we switched on the torch, we saw a baby barracuda flapping on the floor of the dinghy. It had jumped out of the water and landed in the dinghy.
I never did get to do the USVI. The BVI's were very nice but we found the sailing a bit limited with all the islands being quite close together. Our preferred sailing grounds in the Caribbean were from Martinique down to Grenada where the wind was invariably easterly force 4 to 5, occasionally 6 (on the beam). The crew and I did this for many years until retirement took its toll on some of the crews finances and it was then back to oilskins and heavy clothing for our final years around the Scottish Isles. Very pretty but usually miserably cold, wet and at times very windy. All now in the past i'm afraid as most of the crew are lacking in fitness and confidence. We do however meet up occasionally for a trip on the Norfolk Broads.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
1 hour ago, wefalck said:
only down to Mustique
Ah! Basils Bar. Our last Caribbean trip. We spent the afternoon in the bar watching the Germany V Argentina cup final - 13 July 2014. Seems like a long time ago now.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you all for your comments.
The dinghy sits on a metal frame constructed from .032" and .040" brass sheet.
I started with a drawing before cutting off the required widths of brass strip from sheet. The strips in the next photo sit above the sketch. The front and rear frames are of differing shapes to accept the changes of shape in the dinghy hull. The frames are circa 1.3" x 0.8'. The legs are .040" thick and the cross pieces 0.31" thick. The diagonal braces are made from .040" wire.
The pieces were cut accurately to length and the "V" was bent to the correct angle. .040" holes were drilled to accept the bracing rods.
I made a jig to ensure the soldering of the upright to the base strips was at 90 deg. The jig was just slots in a piece of 1/4" ply with intersections drilled out to give access for soldering.
The "V" strip was then soldered in place with the base held against a piece of steel to act as a heat sink.
Finally the bracing rods were soldered in place and the supports were then cleaned and polished.
Finally the frames were glued and pinned to the deck.
The garden is still dominating my time so progress is somewhat limited I am afraid.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Take your time Keith. I am enjoying viewing this little marvel - the longer time allows for a prolonged visual feast.
cheers
Pat
 Keith, I was looking at your latest photos and I saw color in the 7th and 8th photos and it took me a second to remember, it's the flags in their cubby. So many treasured post and pleasant memories.
Thank you Pat and Keith.
 A bit of time was spent on the dinghy over the weekend.
I started with a few coats of thin enamel paint with sanding between coats.
Then I did a bit of masking and applied black paint to rowlocks and oar clips and shades of grey to the bumpers, deck and solid bottom.
Anti- slip strips were required for the deck - made from sail repair tape blackened with permanent marker.
Grab handles were needed on the sides and I made a drilling jig out of a piece of aluminium tube to get the attachment holes correctly spaced.
Fabric reinforcing was cut from sail tape.
This was also coloured and applied.
The handles themselves were made from flattened .031" wire. These were attached and painted black.
A further bit of anti-slip matting was attached to the locker and the oars were glued permanently in place. 3 black inflation valves were also added.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
2 hours ago, ccoyle said:
but perhaps just a little out of place alongside all that shiny teak and brass!
Chris - I have to agree. I had to work hard to convince myself to include it. Thank you Eberhard.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
5 hours ago, ccoyle said:
Indeed -- but perhaps just a little out of place alongside all that shiny teak and brass! 😉
Perhaps you could mount it in a towed position behind the ship?
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
That looks so convincingly realistic Keith; it looks like the real deal.
cheers
Pat
Keith,
My apologies for being way late to the party on this. I just spent the last couple of days going through all 63 pages of this magnificent build. Man have I been missing out! What a beautiful model you have going on here.
You are definitely a master of your craft and I feel so insignificant now. :imNotWorthy: I know I am jumping late, but I'm definitely on for the remainder of the journey.
-Brian
Current Builds:        Completed Builds:
Planning my next adventure.        HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways        Mississippi River Towboat Caroline N.
fantastic work Keith,
a real treat for the eyes...
Nils
Current builds
-Lightship Elbe 1
Completed
No apologies needed Brian - I'm glad you made it before the end.
Eberhard, Chris, Druey, Greg, Pat, John, Bean and Nils - thank you all for visiting and leaving comments. Thanks to everyone for the likes and visits.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
If you recall I hadn't finished the aft "swimming step on the launch". I made the bits a few weeks ago so it was a quick assembly job.
The real thing.
I took a few liberties with the deck wood (as well as the engine and wheel - as mentioned previously).
I still need to do the lashings and a mooring lines.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
What a gem of a model Keith, all that finely detailed brass work really adds to its presentation.
cheers
Pat
Pretty darn convincing model when looking at the photo of the big boat and comparing.
One would swear that the launch doesn't have a bottom, it looks like you're looking right through the launch to Germania's deck. What a neat effect.
Edited by Keith Black
