Schooner Germania (Nova) by KeithAug - FINISHED - Scale 1:36 - 1908 / 2011
Loved your poem on the Planker's Lament! Here is a response, Keith:
It takes a while to figure out
That you will need to spile.
A plank can only bend so far
But not the second mile.
It will bend and twist all right
But edge bends just a bit,
Then it's time to spile that plank
So that the thing will fit.
Link to comment
Share on other sites
1 hour ago, druxey said:
Here is a response
There speaks the voice of experience.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Planker's Progress 5 - Day 10.
I got to the point on the  underside of the bow where the planks were very flat where they intersected.
I needed to change strategy so I introduced a "keel" plank with the intention that further planks would be butted against it.
I also inserted a small block at the top of the rudder which will be sanded to give the hull in this area it'd final shape.
The problem I was having with planking (as recorded in Planker's lament) was to the right of the inserted block. Here the curvature is acute and the planks were being distorted more than was good for them.
 I pressed on rather than rethinking and ended up cutting out a section 3 planks wide by 6 inches long and redoing it. I must remember that rework is slow - much better to do it right first time.
In the next photo you can see that the extent to which taper planking has filled out midships relative to the bow and stern. As I proceed I will have to start sorting out the aft end of the keel where stealers will obviously be necessary.
I finished day 10 with a planking count.
So I make that 9.6 planks a day - good job I am not on piece work- obviously some way still to go.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
17 minutes ago, Jim Lad said:
Been away up the coast for a few days
Hi John - I do understand "up the coast".
A number of years ago my son was on a parent funded "elective" (university work experience vacation). He and a group of friends hired a car in Sydney having booked a sailing week in the Whitsunday Islands. Being the inhabitants of a small island they had no idea of how far they had to drive!!!!!
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
:) catches a lot of 'visitors' out those distances involved.
Nice job on the planking Keith, the run is very 'pleasing' as Eberhard says, it is obvious your fairing efforts are paying dividends now as planking is very symmetrical.
cheers
Pat
Link to comment
Keith, any way you can be talked into leaving that hull natural? Besides the beauty, I'm thinking of your safety - I know a few bars where wood workers hang out where if someone says they intend to paint 100 year old real mahogany, they're going to be lucky to make it out with only tarring and feathering ;)
Link to comment
Vossie,
My mother told me not to frequent bars like that.
Eberhard, John, Pat thank you for your appreciation - I hope the more difficult remaining part continues to please.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Well I've just found this beautiful build and I'll definitely be tagging along.
As for "up the coast" as a fellow New South Welshman I'd say still in NSW but north of Sydney.
As Banyan said, the distances involved here catch a lot of people out. I was hiring a car in the airport at Cairns one day and the German couple in front of me were hiring a car to drive to Sydney to catch their flight home in two days. The hire car guy looked at me with a look that said "Do you they know it's 2431K's"
Edited by Bedford
Link to comment
Hello Bedford - nice to be in contact again. Hope I don't disappoint.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Keith, your planking is looking terrific - so tight edge to edge.  And a good call on the keel plank.  The beautiful form of the hull belies the complexities in planking it.
Gary
Completed Scratch Builds
Link to comment
Further to the above comment I needed to accurately cut some planks to a taper of specific width and length (the measurements are taken from the hull). I do have a rip mitre gauge for the saw but I thought I would share the following method which I find easier and quicker.
I set up the saw to cut the plank to the maximum width of taper needed. I then cut the plank to width. Having done this I then cut the plank to the length of taper needed. As I usually need 2 tapers (one for each side) I stick 2 planks together using double sided tape.
Without changing the width of cut on the saw I then slot out the end of a piece of scrap.
Having done this I create a notch using a hand saw.
I then place the plank against the notch and use a push stick to apply side pressure to hold it in place while pushing the plank into the blade using the notched stick.
I end up with 4 tapers - 2 correctly sized and 2 slightly smaller (because of the blade width).
I know stealers are not supposed to come to a sharp point but I find they work fine on this type of hull.
And so I proceed to plank.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thank you Gary, I hope it continues.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Nicely done, mole grips as a clamp ! The hull must be bigger than I thought😁
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Link to comment
Paul
Actually the clothes peg (which has rubber pads) was the first clamp. Unfortunately the spring was weak and the mole grips just happened to be handy. They are the middle size of a set of 3.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Knowing your work I don't see how you could
Link to comment
Planker's Progress 5 - Day 14.
So its 14 days since I started.
No dramas in the last couple of days but I didn't get a lot of time in the workshop.
As I start to progress up the keel I need to sort out the cut away for the screw. In the corner it has a tight curve. I took a strip of mahogany .2" thick and used the side of a 5mm end mill to thin it down - thus creating the required corner radius - see next photo.
I cut the thinned section off just behind the radius before gluing it on to the horizontal surface. A piece plank was then used to clad the vertical section before sanding back to match the keel profile. I will round off the sharp edges when I do the final hull sanding.
I continued up the keel filling the back of the keel with stealers as I went. At the present time I have virtually filled the excess and the planks are now running true and virtually parallel with the deck. 116 planks have been laid.
You can see the wedge planks in the next photo if you look hard.
I took stock and measured the remaining area to be planked at the front and back of the keel. I will now complete the next section of planking using taper planks with a 2:1 taper. Fortunately the hull is now short enough to take single plank lengths.
I also need to start thinking about how to plank the "bulb" of the keel where once again the changes in radius are pronounced.
Bedford - thanks for the vote of confidence - I ,may need to draw on it when I get to planking the bulb.
Vossie / Druxey - I would actually call it a Mole "WRENCH" but what's in a name.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
7 hours ago, druxey said:
Vossie: we say 'Mole grips', you say '"Vise grips'. Two countries separated by a common language!
I've also heard them called "channel locks".  A bit imprecise as true "channel locks" are totally different tool.
Link to comment
Me being me and the keel bulb being at the bottom of the boat, out of direct view, I'd laminate some planks and carve the bulb.
Link to comment
Bedford - That is how I did it last time so it is an option. It would just be sort of neat to be able to plank it. I may chicken out though.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Nice job on the planking!  It’s looking good!
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
8 hours ago, wefalck said:
I kind of thought that a solid, shaped piece of mahogany would look nice too.
Eberhard - yes I agree, when the planking gets too difficult i'll lop off the remaining un-planked area and revert to carving - I just like the challenge of seeing how far I can get with the planking.
Thank you Phil.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Planker's Progress 6 - Day 17.
It is 3 days since my last update and progress continues at a modest rate. Those of you who are getting board will be pleased to hear that I am nearer the finish than the start.
As I approach the keel bulb I have to start thinking ahead. Some time back I said I would have to sort out the unrealistically sharp keel.
I started by lopping of the tip and cutting a piece of mahogany which was a bit thicker and had the extension to hold the bottom bearing of the rudder.DSC08750.thumb.JPG.f8c68a1a2c457d9aee846ae71b372ab3.JPG
I progressed up the keel towards the bulb - gradually finding the planking more difficult at the rounded front end. I started to find the planks were too stiff to wrap around the bulb and had to resort to heat bending.
fullsizeoutput_19fe.thumb.jpeg.b6ec3f6accda617c8d692d2c05f58f74.jpegfullsizeoutput_1a04.thumb.jpeg.76732abfc479c1d23c8359e0d9e7e646.jpeg
Eventually even this wasn't working and the next step was to use narrower planks - .055" thick by .090" wide while also continuing with the heat bending. Using the narrower planks slowed progress somewhat as two and half  planks were now required where previously one had been used. The narrower planks were not tapered as by now I had eliminated the excess planking area at the rear of the keel. I should have explained earlier that I was chamfering all the plank edges to eliminate any plank to plank gaps.
fullsizeoutput_1a16.thumb.jpeg.fac74bd3a3c432f317ccaea4b753389d.jpegfullsizeoutput_1a13.thumb.jpeg.c064048209ebbb1f83edd34c52a98b47.jpeg
Having got this far my last job for today was to see how the remaining planks would fit. I put a few off cuts in place and satisfied myself that I was up to the task before retiring to the comfort of my armchair to enjoy the smell of the fish pie wafting in from the kitchen.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
That's looking very ship-shape Keith; I think the yard's master-shipwright would have considerable difficulty finding fault with that effort.   The run of the planks looks spot-on so your planning and adjusting have served you well.
cheers
Pat
Edited by BANYAN
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
