Did you give the bug proper last rights?
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Yep I said  #########$$$$$$$$$.........Out of hear  your history.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Maybe just call the bug bit "battle damage"... and paint a fly on the side of the cockpit for the kill.
He's long gone now   - spray day number two  latter today with any luck   - just need those rain gods to have a day off  and  no wind  - also no  flying things please.
OC.
Current builds
Completed works.
3 minutes ago, Old Collingwood said:
He's long gone now
Probably looking for someone else to do his camo paint job. You were a little rough!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
My next project should be  a fly carrying truck  - but guess there will be enough room for nats and midges as well.
OC.
Current builds
Completed works.
I get that problem out in the garage.   to combat it,  I run a number of fans.........try to get'em before they get too close ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Right  - I got the chance to  lay another coat of Green  over the wing and fuselage,  then  let them dry aided by the hairdryer  - I then put them aside to harden,   I also  put a coat of primer on the other wing and stabs.
Then this afternoon I decided it was time to remove the tape and reveal  my paint work   -  Not good  I am not happy,    contribution of factors  lack of man shed or building area,  wrong  tape   (I should have invested correctly by getting Tamiya Tape)    Also  using  Tamiya  rattle cans  out doors in between  rain showers  and wind and bugs  - is not ideal  as I had to very quickly throw the paint  down to beat the elements.
The finish has left a couple of areas of miss match paint  - some scratches   and a hard ridge where the black/camo  demarcation line is.
Seriously  dont want to have to paint my other kits this way  as its just not  the way to go.😞
OC.
Current builds
Completed works.
Can you post some photos of what you've got...maybe there are some things you can do to salvage your work.
I never realized you were in a single room apartment, so I now appreciate your predicament. As for painting, acrylics seem to maybe be your only viable alternative indoors.
Do you have a fine grade sanding sponge? Tamiya sells a pack of sanding sponges that go from medium to fine. A very fine sanding sponge can knock down that ridge without wrecking your paint.
Thanks Craig,     here are the pics   - not sure about the best option for touching up the paintwork  as I dont want to have to re mask  the areas so I can spray the affected areas,   I could  de cant some paint  out of the  sprays into a small  glass  by spraying a liitle  - then brush over  the areas  but as thin as possible (not sure if the difference will show between spraying and  hand brushing)   I have some 800 wet and dry  - some well used pieces that I could try  but have nothing finer.
Here's  the pics  -
OC.
Current builds
Completed works.
Hmmm...800 might be too coarse. You could maybe try it in the most inconspicuous areas first just to see if will help. If you do, make sure to do it very lightly, wet. Water provides some lubrication and helps avoid scratching.
But I'm not sure what you can do to eliminate those scratches short of remasking and repainting. Brushing will show up for sure, but maybe not to an intolerable degree.
I am not even going to pretend to be any kind of expert, but to me your camo job looks pretty good in the pictures. What I think I would do would be to mask off the Camo portion and re-shoot the black. Another thing I have found in doing my Huey, or should I say redoing, is that Windex, (Window cleaner with ammonia) and a stiff paintbrush or even toothbrush are your friend. I have stripped paint that I have not been happy with so many times now that I have lost count, in order to try and get it right without covering the detail with paint that is too thick. Just a couple of days ago I stripped the entire cabin interior back to almost bare plastic and applied a new coat of gray and that paint had been on for weeks. As long as you are working with Acrylics you should be able to do this. No fun but it has saved the Huey from the scrap heap a few times now.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
The wing will hide some of the scratch on the left side of the fuse for sure and I would not worry about that little bit of over spray in the green.
Some thinned out black would hide most well  enough I think CD that would be my fix then a future clear before decals to hide it.
Thank you for the help all  - really appreciate it   your intervention stopped me from binning it,    I  decided to attack the black first  - I  thought I had brought the eqv  tin acrylic as the Tamiya rattle can,  so I used my softest/widest brush  watered the paint very sightly  with  distilled  water  (just a few brush drops into the tin)   then proceeded  to apply some thin layers all over the black  - wide brush  with thin layers dried between each  seems to have helped a bit.
On the side where the scratches was  under the cockpit  that still needs a little light sanding  - I will attempt that  tomorrow when the paint has fully hardened.
Here is a pic showing the better of the two sides after the touch up.
OC.
Current builds
Completed works.
10 minutes ago, CDW said:
Hey, that looks great from here. Nice job.
Thanks  Craig,     its  still looks worse close up  (but dont all our builds under close inspection).
OC.
Current builds
Completed works.
So,    what I need to do  tomorrow  - is  to  work on that front area of Black under the cockpit (just a bit of light sanding)  then a  few more  thin coats of semi gloss Black,    after this has set  I will work tidy-ing  up the  canopy frame where it meets the fuselage and also some of the glazing framework.
Then a bit of a tidy up of the  front nose cone glazing, and then I may consider Blacking out the two  front nose side windows  - as I have seen this done (will cover up where the plastic has hazed.
OC.
Current builds
Completed works.
An old trick might help... use a bit tooth paste on your finger and try rubbing it out.  Use the abrasive type of tooth pastes.   I had to do that on my -53 and worked out fine.   A little touch up after the rubbing out and all was fine.
Thanks Mark.
OC.
Current builds
Completed works.
Im a bit worried about pressing to hard in case the windows push inside the  fuselage  as they were not very  well glued in.
But I have some gloss clear top coat  - could brush that in to give them some  shine.
OC.
Edited by Old Collingwood
Current builds
Completed works.
The gloss coat might work better then for cleaning up the remaining scratches.
I'll  give it a go  "nothing ventured - nothing gained"
OC.
Current builds
Completed works.
Quite a bit more work today  - six hours at the table  correcting the  paint finish - this consisted  off  wet soapy  sanding with fine wet and dry  thats had its bite taken off by rubbing on slightly coarser  wet and dry,  than I worked on the  the left side front area  - first I masked off a small area just forward of where the wing joins the fuselage, then with my widest  brush  I applied a  few thin coats  force drying and light sanding between coats, then I moved a section at a time towards the tail  - masking where needed.
When I reached the tail I masked a new curve and continued my Black paintwork  six hours later I gave the paintwork a light  buff with a cloth  and  finished for the day.
Here's the pics  - including a dry fit with the one wing that still needs a bit of touch up.
OC.
Current builds
Completed works.
2 minutes ago, cog said:
Not doin' to bad old chap ... actually very nicely done mate
Thank you for the kind words Carl,    its an adventure  high's and lows  trying to get a clean paint finish down,   building her  was the easy bit.
OC.
Current builds
Completed works.
Usually is with the plastic parts, until you get to the PE or painting it all seems to flow easily
Carl
I think  what it is  - when the model is un painted stage it can get quite a bit of rough treatment - filing this/sanding that  without worrying about marring the paint finish, I have to say the way I have had to put the paint on has caused most of the problems.
OC.
Current builds
Completed works.
looking very nice indeed considering the limitations you have with the hobby, very well done OC
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
