Mosquito B Mk IV - FINISHED - Revell - My next non-ship project
11 hours ago, Edwardkenway said:
To be honest I may or may not of let go on purpose, to see if he would go up!! For research purposes only of course 😉😁
Excellent disclaimer.
OC:
Nice looking work.  I hope I can do half as good when I grow up.
Link to comment
Share on other sites
OC:
Hey,  im still growing up  - at heart  25,   in body feel about 80  actual age  not telling   lol.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
OC.
Same here, but body is way beyond factory warranty.  Some days I feel as frisky as a pup and then in a matter of hours, I'm the oldest guy in the world.
Link to comment
We try our best though mate  -  laughter and good banter is a good remedy  and I cant think of a better place than here,
OC.
Current builds
Completed works.
Link to comment
Looks fantastic OC.  That's turning out really nice.
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Thank you mike,   still some way to go.
OC.
Current builds
Completed works.
Link to comment
taken in the late 60's early 70's
late time i build a fly thing
Its all part of Kev's journey, bit like going to the dark side, but with the lights on
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
HMS Indefatigable 1794 by Kevin - Vanguard Models - 1:64 - Feb 2023
HMHS Britannic by Kevin
SD 14  - Marcle Models - 1/70 - March 2022 -  Bluebell - Flower Class - Revel - 1/72   U552 German U Boat - Trumpeter - 1/48  Amerigo Vespucci     1/84 - Panart-   HMS Enterprise  -CAF -  1/48
Finished
St-Nectan-Mountfleet-models-steam-trawler-1/32 - Completed June 2020
HMS Victory - Caldercraft/Jotika - 1/72 - Finished   Dorade renamed Dora by Kevin - Amati - 1/20 - Completed March 2021
Stage Coach 1848 - Artesania Latina - 1/10 -Finished Lady Eleanor by Kevin - FINISHED - Vanguard Models - 1/64 - Fifie fishing boat
Link to comment
Some nice models there Kevin.
OC.
Current builds
Completed works.
Link to comment
OC.
all gone to the dust monster many years ago, infact in 2006 when mum cleaned the loft out there was a large Airfix spitfire, which had just totally fallen apart, i could have just boxed it up and rebuilt it again
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
Makes you wonder if newer models with newer glues/paints etc  will last longer.
OC.
Current builds
Completed works.
Link to comment
OC.
i doubt it,
All the best
Kevin :omg:
KEEP IT REAL!
On the build table
Finished
Link to comment
I havn't done a lot to day  - made up the stabs  and cleaned up the seams  - that's it.
OC.
Current builds
Completed works.
Link to comment
Cool..  you had a dogfight on ceiling.
Link to comment
Good day all,   more work on mossie,  -  I  assembled the other wing  starting by fitting the flaps together, at  the same time I painted and placed the wing radiator in place,  then after cleaning the seams up - the wing was  joined together with the flaps trapped inside.
I also cleaned up and painted both engine nacelles.
OC.
Current builds
Completed works.
Link to comment
HI all,
I had a battle on today  - trying to manipulate the engine/undercarriage nacelle to fit the wing (its a notorious  bad fit)   I had to dry fit - dry fit  - dry fit  etc etc etc  and  file/sand away  till I managed to get it to fit requiring just the smallest amount of filling.
Firstly I glued the front end  and aided by the hairdryer  and some gentle pressure it  glued down, then I pushed down the back end and secured with a seam of fine glue.
The idea with the hairdryer  is to make the glue mimick  a heat gun  by where the glue sets quicker by being hot, and cools quickly as set.
OC.
Current builds
Completed works.
Link to comment
19 minutes ago, CDW said:
Your sanding and filing nailed it. Beautiful fit.
Thank you craig,   I understand the Revell Mossie kit is renowned for being a bit of a pig to fit in some areas  namely the  Engine/undercarriage nacelles, and  at the same time  the joins with a little care are bang on.
OC
Current builds
Completed works.
Link to comment
OC
That's because you are a modeler, OC. Assemblers don't want to take the time to make things fit, modelers do.
Link to comment
Thanks mate.
OC.
Current builds
Completed works.
Link to comment
It may be a pig, but from here, it's coming out looking great.
Link to comment
Thank you kindly Mark,    forgot to say  I have also been working on some of the panel lines.
OC.
Current builds
Completed works.
Link to comment
Masked up ready for primer,  also a little scribing of panel lines  I also drilled to make a couple of  additional vents below the exhaust manifolds  (that reminds me they need masking).
OC.
Current builds
Completed works.
Link to comment
Question  -  any ideas how I can make my prop spinners  more pointy  and less  rounded,  as the kit ones  do not form enough of a point.
OC.
Current builds
Completed works.
Link to comment
Is it just a matter of the shape of the cone or are the spinners too short? If it's just the shape of the cone, you should be able to reshape them somewhat more like the originals. you'll just have to take care not to file away too much material. If they are too short, it is a different problem/solution, and they will need to be built out with putty or something similar perhaps.
Link to comment
They are the right circumference  just not quite pointed enough  they  are kind of like a ball shape.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
Right I had a go at the spinners  just  by using a sanding stick and working around  towards the tip.
OC.
Current builds
Completed works.
Link to comment
If the weather is good tomorrow  I will prime the tail planes/right wing/spinners   and  do a  couple of coats of Green  on the masked areas, then I will pop them in a box with a lid  to let the smell go off a bit before taking them indoors.
OC.
Current builds
Completed works.
Link to comment
Hi all,    so when I spoke last I was waiting on good weather so i could get out and do some spraying  -  its that frustrating time as I had some chores to do first  then our  twice weekly shopping deliveries to the house,  then I got the time to  step out the back to try  some spraying  -  "Rain"  not heavy just that  drizzly stuff, but  I had nothing else on mossie to  do till this painting was done,  I kept  my eye on the weather till later in the afternoon I spotted a dryer spell  but with a little bit of wind  - so I went for it,   I have one of those  12 inch long  plastic storage boxes with a hinged lid,  I took the parts with me in it  - got out the wing  first  and sprayed the Green  - It went down very well  until I noticed a flying thing  nat or something had landed on the  wet paint,  I put this in the box  and did the same to the main fuselage  - that went down the same but with no thing's  stuck to it,    I put them both in the box closed the lid  and was able to take them in the house without a worry over paint fumes.
Later after a couple of hours I was able to inspect the damage off the insect - I was able to scrape it gently off  - but it will need a small section of  primer then another  coat all over the Green areas  - the fuselage will get a second coat of green also  as I did the same with the Grey.
No pics though.
OC.
Current builds
Completed works.
Link to comment
I just took some pics showing the painted parts in the box  and  the box.
OC.
Current builds
Completed works.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
