On 10/3/2019 at 2:46 AM, mugje said:
Bowsprit constructed, stained, painted and dryfitted. At first some things look a bit daunting, but just step by step it becomes the end result.
With a david plane I taper the dowel and with a cordless drill the final step...making it round and smooth.
On 10/8/2019 at 3:31 AM, mugje said:
All the yards, gaffs and booms constructed and painted 🙂
Rigging starts from now!🌞
Cleverly done.  I was referred here by Lazy Saint and I am enjoying the many innovations of all of the people on this site.  I have not worked with small pieces of wood like this.  Wood is fun because you can do so many things with it. And you are obviously having fun. I am going to follow you and I know I will learn many tricks.
Thank you! That's nice to hear :)
20 hours ago, Norway said:
Everything looks very good mugje.... :)
Have did you serve the rope for the stay that goes from the mouse and round the masts to the loop?
Do you need a machine for this or can it be done manually by hand?
I did not serve rope. Only a small part around the mouse. It's not authentic, but I did not have enough knowledge to do it correct like in real
practice. But I have learned a lot from other logs and have an idea now what needs to be served.
With the next ship I will go further with perfecting the rigging and serve the line. And I would buy a serving machine, like Chuck Passaro's one.
That looks much easier and more enjoyable.
Okay! So I finished the ship :D
I didn't take pictures of the last stage. Was a bit busy and worked for very short bouts on the ship.
The end was a bit difficult because I wanted to finish it, so there were sometimes moments that I rushed through the
build. That needs some attention for the next time...that I take the time and patience to give everything the attention
that is deserves, but that is just a part of the learning curve.
I enjoyed this build a lot and learned a ton in the process. Offcourse skills wise with the wood etc, but even more mentally.
For me it was difficult to actually finish something that takes this amount of time, so i'm very proud of that.
And i'm very proud of the end result! I builded it right out of the box with almost no modifications. The most important thing for
me was to actually finish it! :D  And in the future there will be more modification/adventure ;)
Very fine work  she looks Stunning  well done.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Mugje , you should be right proud of her. She is a beauty.
Edited by Bossman
Current build: Model Shipways “Confederacy “
Completed builds:
Mamoli “Royal Louis“
Mantua “Royal Caroline”
Scratch 1/4 scale gondola “Philadelphia”
Scratch “Hannah” from Hahn plans.
12 hours ago, Norway said:
Look wonderful mugje 😊 . Great work and the model looks like a millon dollar. Are these the Amati display mounting colums? What dimensions are they? And what baseplate?
The base plate that I used
https://www.cornwallmodelboats.co.uk/acatalog/Occre-Model-Boat-Fittings-19102-Display-Stand-130x265mm-OC19102.html#SID=1691
And the colums are from Amati indeed
https://www.cornwallmodelboats.co.uk/acatalog/5690-35-Turned-Brass-Column-35mm-A5690_35.html#SID=1579
I used two of the same dimensions, but filed one slot deeper so the ships keel lays in the correct angle.
At first I thought it was a good idea to use 2 different dimensions, so one shorter colum...but that looked horrible haha, because the thickness is
also reduced with the smaller height.
Beautiful!  Congratulations on your completion 😊
