Hello Everybody,
here is just a brief comment about my attempt of building the bulkheads around the cabins. I started with the centerpiece of the aft bulkhead. It is more difficult than the panelling of the surrounding cabin walls, because it has to look good from both sides. So it is like building them in 1:1 scale, just without "slit and cone".
Next thing will be the doors.
Matthias
Hi everybody,
I continued with the aft bulkhead, wich separates the captains cabin.
The bulkhead panels and doors were assembled and glued in place, underneath the deck beam. The doors can be opened, but for now, I leave them shut, because of the danger of being damaged. I am not shure yet, I propably leave them closed anyway.
Here are som photos of the result.1.thumb.jpg.57d1961961f06ca02a3efbf604b40ead.jpg
Matthias
Did you hand paint the black and white squares?  Sorry if this was explained elsewhere, it looks really good.
Edited by glbarlow
Regards,
Glenn
Current Build: HM Flirt
I indeed play the piano. And I don't want to stop playing... it is just increadible, what people throw away nowadays. Such lovely, valuable materials like ebony and ivory and you can pick it up from the bulky waste. I use a lot of old stuff like that at my home.
Edited by Beckmann
Matthias (hope I got your name right)- could you comment/show pics of the tools you used to make the ivory partition doors and panels?  And what glue you are using?  Beautiful stuff, I am hungry for more information, thanks Cisco
Here we go step by step:
1. The material:
I use old piano-keys, if you don't have some, just use bone. From cattle for example, Cut it into strips of about 1,5 mm thickness.
2. Sand the edge
3. Cut a mortise in the edge with your saw
About 0,5 / 0,5 mm
4. Then cut the strips into the proper width of the framings:
5. Clean them with fine 400 sand paper
5. Glue them in 3 layers together. In the middle put a small veneer strip to create a gap between the ivory strips.
6. Then make a little jig, to get the shape right and cut and dry-assemble the framing
7. Then make the fillings
8. Afterward you assemble it part by part and glue everything together
9. Finally clean and polish it with the dremel
And that's it
Matthias
Edited by Beckmann
Thank you for documenting your process Matthias.  It was different than what I was imagining and very educational.  2 questions:
1) In the first picture what did you cut the ivory keys into 1,5mm strips with?  The tablesaw?  or possibly a bandsaw?
2) What glue did you use?
thanks again, cisco
Hello everybody,
This weekend I proceeded with the building of the doors for the front bulkhead. And I finally installed the bulkhead-arrangement to the model.
The doors were built the same way as the rest of the front-panel: inside ivory, outside boxwood. For the windows I needed something more stable because of the glazing bars on both sides. After looking around a while I decided to cut a ferrero-rocher-box into peaces, they are from acryl and really thin an nice. Perhaps 0,3 mm thick. That worked quite well.
After finishing this, I took the model out of the workshop and made some photos, because some prominent visitors came around to have a look at the great cabin. I think it was Tomas Slade himself.
Matthias
Edited by Beckmann
That is some great workmanship! Beautiful.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thank you all for the likes and comments!!
After finishing the bulkheads, I continued with the deck beams, knees and fittings, wich is great fun to do. Everything comes together now, and you get an impression, how the model will look, once finished.
I have this idea of a photo from the main deck under the quarter deck with a little camera, if that is possible some day. So I painted the beams and knees from the underside, to  have it all in color, .
Here are photos from the current stage of the building:
I will clean the top side of the deck beams once they are all finished. The numbers on the knees will be covered by the planking later on.
Matthias
Edited by Beckmann
