Really nice Mark.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hi Mark
Wonderful clean work.
Regarding Franks question: I did put a simple chimney into the opening of the binnacle but when I just tried to see it below the overhang of the poop It was just barely visible and only because the rigging is not yet in place...
Cheers
Peter
Update - poop deck on & planked.  The cap rails were added & the carronades were finally finished & set in place with all the rigging:blink:.  The carronades are shown in the retracted position thus the lack of slack in the breech ropes.  The railings will be added later - if not, I would surely knock them loose.     Need to add a few more things & then on to the pointy end of the ship:D.
current build - HMS Vanguard - Model Shipways
update - finished up the poop deck by adding some bitts, a few timberheads, stern brackets, the skylight, & a bunch of eyebolts.  I used liquid window maker for the skylight windows.
Next, the bow railings & timberheads were installed.  The cap rails, railings, & timberheads were all laser cut to shape and fit nicely - basically just had to assemble, paint them & glue them on & cut 4 short sections out for the last 4 cannons.
Thanks for looking in:).
Hi - added the rest of the cannons to the deck plus the chimney & gratings.
Before finishing off this area, I thought I would move to the bow deck area & work on the head rails.  First thing I had to do was chisel out the top of the wales so the gratings would sit on the supports properly.  after a lot of filing to the head rail slots in the supports, they were glued in place along with the upper cheek rail.
Then, the middle & lower head rails were shaped & glued in place - this took almost a whole day to get them even on both sides:wacko:.  Finally, the gratings were added.  Got a bunch more to do yet in that area.
Hi Mark
She's looking great.
The damaged grating at the bow... well, welcome to the club!
(I somehow fiddled some 1x1mm strips into the place of the broken parts.)
Cheers
Peter
Well,1 step forward & 2 steps back.  While working on the bow, I managed to break a few strips of the bow grating:angry:.  I managed to splice in some small HO scale strips & after some paint touch up it looks ok at arm`s length.
Continuing on, I finished up one side of the head rails.  I had to cut a groove in the rails for the covering strips to lay flat, but other than that it was just a lot of filing & sanding to get everything lined up.  Now I have to do it all over again on the other side:wacko:.
You are doing an Amazing job Mark  -  and a superb rescue of the  frontal grating  - she is seriously  looking Superb.
OC.
Current builds
Completed works.
Looking superb Mark, and yes, great save with the grating.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
She is really looking the business, I'm just a few steps behind on the same build so your log is a great help ... keep up the fab work..
HMAV Bounty 'Billings' completed
HMS Cheerful - Syren-Chuck' completed :)
Steam Pinnace 199 'Billings bashed' - completed
HMS Ledbury F30 --White Ensign -completed 😎
HMS Vanguard 'Victory models'-- completed :)
Bismarck Amati 1/200 --complete  👍
HMS WARRIOR Billings just started
I'm just working from the stern to the bow, and doing the jolly boats at the monument--The hammocks are just placed in for now.
