Hi
So I'm going to go ahead and start a build log of the Winchelsea, It will based off Chuck's designs with a few modifications of my own.
My main reason for building her is because she was once captained by Pellew and I intend in the future to build another of his ships,
a 1:48 fully framed model of the 44 gun Razee Indefatigable and it would be great to have both models together in the same scale.
I will not be planking in AYC as I have a goodly stock of Castello Boxwood and prefer it on a model of this size, also stem/stern framing
and keel will be of Swiss Pear with other wood highlights, maybe I will use the cedar on things that wont be seen easily and use the fruitwood
gel stain that Chuck has discovered to blend it with the boxwood to minimize usage.
I did purchase the Bulkheads and starter packages from Chuck and will certainly be buying his cast resin set when they are available.
The first job I have started while waiting for planking to dry on Pegasus is to make a new build board for this "BIG" ship, it will be approx
38" long without rigging and will need good support while framing, planking and finishing, so I decided to go and buy another 'cheap'
5foot workbench from Harbor Freight for $100 and modify it to suit. First it was put together and lift casters added so that I can quickly move
and spin the bench whichever way I need it. Second was to add 4-foot T-tracks and a nice large 1/2" MDF buildboad to the top. Third was to
install the keel and bulkhead former holders ready for the backbone. The 4 drawers are great for holding parts/tools and the bottom shelf for
materials which keeps an entire build together on one table instead of being spread about my workshop.
Here is looking forward to an interesting build and I should start on the bulkheads later this week.
ben
Hi Ben, Welcome aboard and It'll be great to watch your build.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks David and Rusty,
I decided to make up both the AYC and my own Pear/Box knee of the head to look at the difference in color and grain appearance and I have decided to go ahead with my decision to make the framing in Pear.
ben
Edited by Trussben
Hi Ben,
Great to see you making progress!
Rusty
nice workbench... just went looking for a similar one here in NZ as my wife has kicked me off the dining room table... exact same bench here is $400..... might have to continue looking  😣
Ships in Drydock for build. De Agostini HMS Victory, BB Dannebrog, Artesania Latina Cutty Sark and Endeavour longboat.
Thanks for all the likes.
Rusty - I have been at home for a few weeks so have managed to spend some time in the shop, that will soon come to an end but I hope to get the port framing completed before I go back on the road.
Erik - sorry to hear the benches are so expensive, you could try and make one, instead of drawers just make 2-3 shelves instead, wouldn’t be too hard I think.
ben
Port layout and upper/lower cill framing complete, no issues were encountered with this process, and I have begun installing the port sides.
Next up will be adding the stern framing and I’m also cooking up something special to add to this model which will change the original design somewhat but hopefully it will add to the whole.
ben
Edited by Trussben
Looking good Ben. Can't wait to see what's cooking in the kitchen!
Rusty
I’ve begun lining up the stern framing and adjusting everything before glueing using the patterns and plans supplied by Chuck, everything is lining up nicely and looks real good.
ben
That is looking very, very good.   😀  Your careful planning and lining up at this stage will pay off so much later when you get to the later chapters.
Here is what I have cooked up for my Winchelsea build to add a little difference to it.
I intend to add a frame reveal to the model, much like Chuck's one on his Confederacy or David's one on the Comet.
Midships is the obvious place to put a reveal so as to simplify the design work and make construction easier, so I have decided to make mine between the bulkheads of station frames G thru 5, Also it will be just below the wales to allow for two strakes of lower planking above and several below it.
It will be quite a large reveal so as to show the first and second futtock frame joints, I will have to construct a shadow box behind it to be painted flat black and the simulated frames will be made of swiss pear.
According to "Steel" and the "Shipbuilders repository" table of scantlings, a 32gun frigate of the time would have had 11 1/2" wide second futtock framing, molded 9" with a room and space of 27 3/4", I intend to simplify this a little with 11" wide framing with 3" between them, and it works out that I can fit 23-24 frames in the reveal.
I will finish the design side of this soon and start building it when I have completed construction of the stern framing.
ben
Edited by Trussben
Love the Idea Ben.  Cant wait to see how it all turns out.  I am sure it will look fantastic.
Chuck
Thanks All,
After manipulation of the NMM plans in Autocad I have now also completed the design of the hull framing parts and where their joints will be.
I need to make a load of these and construct the shadow box, I’m not going to make actual chocked joints - just simulate them and highlight with black monofilament line treenails.
This could take a while.
ben
Edited by Trussben
This sounds really interesting.  The frame reveal was one it the first things that caught my eye when I was looking at the Confederacy.
I will definitely continue to watch.  I think it will be well worth the time and effort as it adds a lot to the model.
Great stuff, good luck Ben.
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Thanks Chuck/Mike and all the likes.
Here is the shadow box installed and spray painted flat black, I’m currently cutting the frames out of Swiss Pear sheet that I milled down to 11” thick, maybe get that done and this completed in the next few weeks.
ben
Edited by Trussben
Very nice Ben!
Rusty
