Hi there,
all you steam-paddle-boat lovers
since I was a teen I had an eye on this lovely boat.  It is the long time already out of production vintage Billing Boats kit named "HJEJLEN" Golden Plover, German : Goldregenpfeifer.
A few days ago I could hardly believe my luck in finding this offered complete kit-built boat, on Ebay, a bit damaged, together with a suit-taylored glass case, so I invested a drive to the seller in the region of Bremen area, and picked it up.
After thorough inspection back home I determined the minimum of parts and components required to restore and overhaul the charming old lady. I shall show the sequences of recovery and restoration in the next weeks to come, here in this tread.
As this will be no complete new build, but certainly worth an shorter thread on this forum, as I`m sure that there is interest for this model by the one or other fellow member.
Credit goes to the late father of the seller who built this steamer many years ago. It is known to be the oldest live steam, still cruising boat with passengers in the waters of Silkeborg in Denmark
Nils
name giver birdie, Hjejlen, Golden plover, Goldregenpfeifer
Current builds
-Lightship Elbe 1
Completed
Count me  in to follow along, Nils.
I will follow this very closely. I have the complete kit in my stash, so it will be nice to get ll the knowledge I can.
/Lars Peter
Current build: Amerigo Vespucci 1:84 (Panart)
Current build: BB Mary Ann 1:33
Finished: BB Jylland 1:100
Finished: Church ship Danmark 1:75 (restoration project)
Welcome to this topic Mark and Lars/Peter, and B.E.
and many thanks for your kind comments.
Also thanks to the "likes"
For this kit I`m missing the 2 bullseyes for sidewise in the front section of the hull, and the golden plover figurehead for the upper bow post. Alternative parts are now ordered. The stand looks quite flimsy, so I decided to make pedestals from brass / wooden candle holders with a shaped outcuts for the keel to fit into. Small M3 screws hold these pedestals  firmly to the keel. they will fit directly to the baseplate of the glass casing.
The two ( meanwhile come loose) paddle wheels were glued to the hull. Now both paddle wheels have become an brass axis between outside spashguards segments and the hull. I am intending to place crew and passengers on board, like I did wth the Bohuslän steamer. Its not easy to find the right scale figures, and there are so many non occupied benches. I placed the benches on the upper aft deck, turned around, now back to back 180°, so that the passengers will face the water side of the rivers and lakes for a better view. The roof of the front well also requires some additional holding posts, as the current ones are quite flimsy, and therefore the roof quite instable
Also the ships boat is not in correct scale, so there will be an alternative boat fitted under the davits....
Nils
this is the "old" stand
the wood / brass new pedestals
New pedestals fitted to the keel (they had to be low in hight, due to the limited glass case hight )
the new brass axis for the paddle wheels, also to make them turnable
crew and passenger figures, prior to painting job
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Hi Druxey,
thank you for your word
jes, thats true and whenever I saw an old unbuilt  kit of this one being offered (very rarely) the prices were so extraordinary high, but my mind still went pregnant with this thought  (someday the time may come ! )
Cheers, Nils
wish my hand would be more steady for the paint job on appr. 50 passengers...., but the hairstyles, shoes and other details will get touch-ups
Current builds
-Lightship Elbe 1
Completed
Thank you Yves,
I experienced the same feeling,...... , now that the chance came, I just could`nt let it go by...
Nils
Current builds
-Lightship Elbe 1
Completed
After paint job, now passengers and 6 head-crew boarded, ready for river- and lake cruise at Silkeborg
Nils
on port side the paddle scoops were mounted, facing to the wrong side. I dd`nt want to disassemble  the paddle wheel, as the failure is not so obvious to be seen anyhow
Current builds
-Lightship Elbe 1
Completed
Hi Roger,
unfortunately no, They do turn on the new established axis, but have no interacting cinematic for feathering the scoops. I cant tell if the original Billing kit provided this option.
Nils
Roger, guess this is what you meant for feathering the scoops.....
Current builds
-Lightship Elbe 1
Completed
Progress on Restoration report :
- all passengers seated, crew on their positions
- Bulleyes sdewise in front section
- roof in front well area has additional stabilizing posts
- Bulleyes at sides of boiler room
- Rigging of stern white-light lantern
- Base-plate, steam ironed- down the self adhesive veneer, in order to flatten out the gentle bulbs that came there over the years
_ fitted the removeable pedestals with dowels to the baseplate ( the model can be taken off the baseplate easily)
- alternative figurehead
still missing:
steam horn, 1 larger lifeboat, 2 life-raft containers to go next to the lifeboat on port side
Nils
stern lantern
note: passengers sitting back to back on the long benches
additional bulleyes in the boiler room sides
bulleyes in the front side portions
passengers sitting in the beroofed front well area, additional posts for the roof stability
alternatve figurehead for the bowpost (Golden Plover, instead of lost Hjejlen figure )
Current builds
-Lightship Elbe 1
Completed
17 minutes ago, Mirabell61 said:
Nils, there is something wrong with these seating passengers. Either they all have short legs, or the benches are way too high or they are not at the proper scale for this boat.
It is disturbing on an otherwise beautiful model.
Are these little people, Chinese toys? Since you live in Europe, you should look for PREISER figures at 1/48 scale. They are by far the best quality.
Yves
Edited by yvesvidal
Hi Yves,
thanks for your comment, I´ve been expecting a comment on the seated people zise. Usualy Preiser is my first choise, here unfortunately neigther 1:48 nor 1:50 scaled seated figures were not offered or not on stock. I can live with the substituted figures  I finaly chose in scale 1:43 resp. 1:45, and was after receipt disappointed that even these were a bit too small in comparism to 1:50 regular Preiser ones. (if they had been available )
Nils
Current builds
-Lightship Elbe 1
Completed
Yeah Yves,
The bench-legs  should have been shortened, now its too late, would be a too great surgery. Earlier one of the benches came loose and dropped onto the carpet, no problem with that, but I did`nt pick it up immediately, and you can guess what hapened, I forgot that it was still laying on the carpet and under a nasty cracking noise, that was it....... It took me some hours to mend that bench, so I`ll leave my fingers off it in the future. :o :angry:
The ships boat is in a scale that suits the figures in a better way.  It takes some painting and rigging under the davits by means of double sheave block tackles. Together with the 2 liferafts the capacity will be adequate
Nils
this is the 14 mm dowel I made the connection pedestal / baseplate from, it works well
the ships boat is a 123 mm long Kutter from Aeronaut in scale 1:50 together with 2 oars
Current builds
-Lightship Elbe 1
Completed
really great find Nils :)   Billings had some nice looking models in their early days.  I know what you mean about the figures........it can be a daunting task to find them in the scale your working on.  your doing a superb job bringing her back up to speed  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you very much Denis,
and also thanks to all the "likes"
I`m enjoying the restoration, which is now nearly completed, and I am wishing those fellow members who are also holding an old "Hjejlen" Billing boats kit , encoraging them to push out a build log..... if possible
Nils
Current builds
-Lightship Elbe 1
Completed
restoration progress....
Ships boat under davits, with oars and grapnel anchor...
Nils
2 oars and grapnel
Current builds
-Lightship Elbe 1
Completed
Progress status....
after achieving a tall and narrow  white book shelf yesterday on Ebay, I removed the books from the lower portion on of the  "Eagle of Algier`s" sideboard.
The "Hjejlen" now fits into the free space compartment with it`s glass case, as if it were made for this.
I have now 7 glass cased models in my working office, the 8th one "Gorch Fock" 3 mast barque and in lack of space, had to move upstairs to it`s new mooring place for display....
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for your kind comment Yves,
much appreciated
Nils
Current builds
-Lightship Elbe 1
Completed
Nice collection Nils!
Completed.... Charles W. Morgan,Sea Horse,USS Constitution,Virginia 1819,San Fransisco II, AL HMS Bounty 1:48
L'Herminione 1:96
Spanish Frigate,22 cannons 18th C. 1:35 scale.Scratch-built (Hull only)
Cutter Cheefull 1806 1:48 (with modifications)
Current Project: Orca (This is a 35" replica of the Orca boat from the movie Jaws)
Many thanks for your word captain !
much appreciated
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you very much Christian,
yes, it was my aim to model different types of ships and scales. The Zeesboot in scale 1:24 is momentarily my current work in progress still waiting for deck-planking, rigging and sails
Nils
Current builds
-Lightship Elbe 1
Completed
great collection Nils........the Hjejlen,  a very nice addition :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
after adding the steam whisle today, the restoration is now complete, and I shall add the Hjejlen to the Gallery.
Nils
Current builds
-Lightship Elbe 1
Completed
