Wow.. this is even beyond penquins.  Fantastic display.
Thank you Grant, Keith, and Mark for the kind words.  It's been an interesting journey going from my son's innocuous comment last May of, "Hey dad, you should do a junk ship in a bottle" to this!
Much appreciation to all the talented MSW people that followed along the way and offered likes, encouragement, comments, and suggestions - @Landlubber Mike, @John Fox III, @Ian_Grant, @BANYAN,  @GrandpaPhil, @ccoyle, @Roger Pellett, @Snug Harbor Johnny, @Louie da fly, @Charter33, @Alva004, @Prowler901, @Knocklouder, @French Mr Bean, @Aoi, @shadowcaster, @Siggi52, @Baker, @Paul Le Wol, @Harvey Golden, @robdurant, @modeller_masa.
Not only do you make the final product better, you also add to the enjoyment of the work.
What a delightful update to come home to Glen; I go away for a few days and then see this.  That is an outstanding presentation of a great build; impressive - you have set a high standard for your next build.  I have really enjoyed following this build mate.
cheers
Pat
On 9/8/2022 at 9:59 PM, Louie da fly said:
Wonderful work, mate!
Thank you Steven and Pat.  It's great to have both of y'all from down under following along and providing your insight!!
 Glen, are you diving right into your next project or is a small break in order?
Hey Keith - Literally minutes after posting the finished pics of Zheng He to the gallery I took off to southern California for a quick dirt bike riding trip.  Just got back last night.  So I guess that was a small break, right?
Actually, I've got an idea for the next SIB project but need to play around with some things to see if I think it will really work or if it's just a dumb idea.
Greetings to all:
My vacations have been shorter than expected because they have advanced a medical test.
Glen, I am speechless before your creative capacity...totally transgressive for a classical mentality as is my case...but your finish and presentation is SPECTACULAR...in capital letters.
It has been a pleasure to follow you and learn other finishing approaches.
I take my hat off to your mastery.
All the best.
Found this thread searching for something else, and got sucked into reading it top to bottom. Including the info about scurvy, castration, sea monsters and penguins 😁. Amazing work, and really entertaining.
Could you please describe how you get the waves on the blue resin? Or point to a link where I can see? I have been thinking about using doming resin, not sure if it'd work though
Current build
HMB Endeavour SIB (Documenting on msw) slow going
Completed builds:
Hannah by Amati SIB
Generic 2 mast schooner SIB
Wyoming 6 mast schooner SIB (Documented on msw)
 Pirate ship from Asterix and the Great Crossing SIB (Documented on msw)
Shelfed for now
Ineos Britannia SIB (Documenting on msw)
  • 3 months later...
@O.B.one
Hey O.B. one, I apologize for the late response.  I just noticed your comment and question.  Thanks for the kind words on the project.
To answer your question about the waves, it's a 2-step process,  First, I pour the resin in the bottle and let it dry.  I will set the bottle aside with a small desk fan in front to speed up the drying process and try to prevent any fogging of the bottle.  Even with the fan it can takes several days for the resin to fully harden depending on how thick it is.
Once the resin is dry, I use acrylic paint mixed with gel gloss medium for the actual waves.  Once I get the color of the paint to match the resin, I take a long Q-tip and dab it on top of the resin, then swirl it around a bit.  Once dry the acrylic paint is dry, I'll hit the top edges of the waves with just a touch of white paint.  If you go to my Independence build log ( Independence) and look at post 131/132 you can see a couple of better pics of the water than you see on this log.
I know there are a lot of methods for making water and waves inside the bottle but this method has worked well for me.  I like the look of the resin/acrylic paint better than the clay or putty water you often see.
Again, I'm really sorry I did not see this sooner.  Hope this info helps.
