Beautiful work on the beakhead and foredeck planking, Augie, the tree nails look great too! :) You're making excellent progress on your Confederacy Sir B)
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
I like the Hobbylite stuff myself better than the Elmer's. With the Elmer's I feel that it leaves a residue on the surfaces around what you're filling unless you are perfect at only applying it to just the hole. Just my two cents...
Very well done, Augie! Your Confederacy is moving along very smoothly!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
BEN-   yup, thanks to you (and indirectly Rusty), put in some support up there.  Think I'll play with the beakhead planking before I hit the gunports.  Got a couple of days of 'real life' rearing it's ugly head coming up.
  Sorry for the Go Back, but what support are you guys talking about? just some scrap to support the fwd edge of the false deck behind bulkhead G or what? Thanks,
Lou
Edited by ASAT
That's exactly it Lou.  Just to make that forward edge solid.  The stern edge rests pretty solidly on the existing structure.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Looks like Jeff's wood is serving you well....looks good as usual...
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Augie, where did you get the Hobbylite?  Is it a colored filler?
John
Haven't gotten to Jeff's wood yet John.  There will still be a lot of ME basswood on board.
Yes, the Hobbylite comes in either white or a wood color.  Available around here in most hobby stores.  One nice feature is that you can just add water and get any consistency you want.  And if you let it dry out in the jar you can always reconstitute it with water.  You can also add a few drops of an acrylic paint and get any color you want.  Best thing since sliced bread ......oh, wait, that was the pencil sander :D  :D
Augie
Previous Builds :
OK, thanks Augie.  You must have found the best Basswood in the box, mine didn't look that good.  that Hobbylite, loods like good stuff.  I'll have to look for some.  Hobby shops are hard to find around RV parks.  And then there's the sander.  You're gonna force me to have to get one aren't you.....
John
sander.... sander..... sander.....
err wait, in my case it's
Jim Saw... Jim Saw....Jim Saw....
Edited by cookster
Wes Cook
Current Build: USF Constitution (Model Shipways)
USF Essex (Scratch build)
MS Syren (build log lost, need to rebuild)
Future Builds: MS Confederacy
You can get hobbylite from Tower Hobbies if you can't find a hobby store near you.  Really really great stuff!
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Work on framing the gun ports on the main gun deck has begun.
A temporary batten was used to check the position of the laser drawn lines on the bulkheads.  Only minor adjustment was needed to yield a nice sheer line.  Lines were scribed on the bulkheads and the battens removed.
A paper cannon was made using a copy of the 12 lb. cannon from the plans mounted on a 1/16" thick strip to simulate the actual deck.  This was used to check the height of the cannon above the sills.  This photo, using tape to demark the port lines, shows where we are:
Satisfied with this positioning, I proceeded to install the laser cut sills, port and starboard:
The sills were roughly faired with the bulkheads.
Now that the sills are in, the lintels should go fairly quickly.  I will simply be using a 3/8" spacer to set them in position.  Then come the uprights.
SJORS - in anticipation of your comment, yes.......the paper cannon fires 12 lb. cotton balls.  The final versions will handle good old American iron.  :D  :P  :D  :pirate41:
Augie
Previous Builds :
Looks great....Before you add the lintels...make sure you fill any cracks between the sills and the bulkheads.  Its easier to do that now.  Sand them smooth as if preparing them for paint now.  the lintels will make it harder as your space is limited even with a good sanding stick.  With the lintels...its not as crucial to fill the gaps so precisely as it will be on the underside and not seen.  But that doesnt mean you shouldnt give it a shot.
Chuck
Okay....I looked at the unexpected serious answer from John,  then I looked at my comment. My neurons were apparently not firing when I typed that!!!
It should have read: I`m trying to imagine how large the cotton cannon balls would have to be in order to be 12 pounds!! :blink::D
Andy is thinking more along the same lines I was!
Sherry
Every goodbye is the birth of a memory...
Current Build: San Felipe
Finished Builds: Mayflower Build Log
Gallery: Mayflower
I suspected that might be happening :) .  But John was right....  12 pounder is 4.4", 18 pounder just over 5".
Augie
Previous Builds :
You might be surprised to find out that cotton is 'heavier' then you think.  If you take all the air out and measure the true density it's about 1.55g/cc.  So if a gallon of water weighs approximately 8 pounds, a gallon of compressed cotton would weigh about 12 !
OK, a gallon of solid iron would weigh about 66 pounds.
And now ........ on with the lintels!!!!!
Augie
Previous Builds :
your progress is looking real good Augie........ I think it's the basement workshop that inspires you :P  :P
frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Nice of you to say that Augie ....... but , I'll tell you, that's one thing I miss here in Calif,...... a BASEMENT !!........ When I lived back in Ct. we fixed up our basement and I'll tell you it was put to good use... Ah, those good ole days!!
                         USRC "ALERT"
Why is that Frank.  Are basements illegal in California?  I've heard almost everything out there is potentially hazardous to your health :D  :D:P  :D  :D
Augie
Previous Builds :
I like how you used the paper mock cannon!  I would not have thought of that.
Looking good sir.. lookin good.
-Adam
Current Builds
Completed Builds
I'm sure I'll eventually have time to read through your build log, Augie - for now, let me only say - excellent work!
hamilton
