As a result of further improvement of the "E" type cruiser project, in 1921 Watts created the project of the Spanish cruiser "F". Its hull and power plant almost completely repeated the British prototype, but the arrangement of the mechanisms was not echelon, but linear, which allowed to give the ships a more harmonious silhouette with two wide smoke pipes, grouped in the middle part.
The turbines and boilers were unified with the Churruka-class destroyers, which, in turn, were created on the basis of the British Scott-class leaders. Thus, the F-class cruisers were slightly superior in power (design - 83,000 hp) to their British E-class predecessors, being slightly faster. The armor remained virtually unchanged: the 76-mm main belt occupied about 40% of the hull length, covering only the engine and boiler rooms, with the belt thickness decreasing at the ends.
The armament was significantly improved. The main caliber artillery consisted of eight 152 mm Vickers guns and was placed in five mounts located in the centerline of the ship. The two end mounts were single-gun, and the other three (both elevated and the middle) were twin. Thus, all guns could participate in a broadside. The powerful artillery was supplemented by a branched and perfect for its time fire control system, including the main command and rangefinder post and two additional posts. The anti-aircraft armament was also strengthened and included four 102 mm guns, the torpedo armament remained unchanged: four triple-tube devices, unified with the Churruka destroyers.
interesting build methode Valeriy,
nice clean work
Nils
Current builds
-Lightship Elbe 1
Completed
- "Zeesboot"  heritage wooden fishing small craft around 1870, POB  clinker scratch build scale 1:24
- Pilot Schooner # 5 ELBE  ex Wanderbird, scale 1:50 scratchbuild
- Mississippi Sterwheelsteamer built as christmapresent for grandson modified kit build
- Chebec "Eagle of Algier" 1753--scale 1:48-POB-(scratchbuild)
Not bad progress seeing as the log was only started 3 days ago!!!! I assume you started the build before you started the log Valeriy.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Valeriy,
since these models are static models, why do you line the hull with fiberglass and epoxy resin?
Is it to make sure the wood does not warp or expand? Is it to increase the solidity and resilience of the hull to shocks?
Have you considered just brushing epoxy resin on top of the wood and skipping the fiber glass?
I would welcome your opinions and recipes.
Yves
8 hours ago, yvesvidal said:
...I would welcome your opinions and recipes.
Yves
Yves, the need to cover the hull of the model with fiberglass and epoxy resin of static models is the result of the experience of previous generations of ship modelers.
1) If you leave the hull unprotected, then, as a result of the effects of moisture and temperature changes on the wood, the contours of the wooden slats of the sheathing will appear through the layer of paint
2) For hardened epoxy resin, fiberglass plays the role of steel reinforcement in reinforced concrete structures. Without fiberglass, the hardened epoxy resin will gradually crack and peel off from the hull.
6 hours ago, Nearshore said:
Hi Valeriy,
I look forward to following your progress. You are truly a master of your craft. Thank you for sharing your progress and technics with us.
Nearshore
Hi, Nearshor! I admire your woodwork and I hope I don't disappoint you either. :)
40 minutes ago, wefalck said:
I admire your tenacy in such difficult times 👍🏻
 Amen to  that, Eberhard.
