before continuing with the construction of the interior I thought it would be better to complete the planking of the hull of the starboard side: the side of the left will leave in carpentry.
I drew with a pencil the locations of the strakes
I started the laying of the first strips
Hi, Giampieroricci. I just find your fantastic building log today. You are so skillful and seem to know everything of model ship building. I can get lots of tips with your log. Please look at my building log and give some advice. Thank you again.
Lee
Hi Giampieroricci,
I've take the time to look through your complete build log. It's a real interesting log and a nice representation of the "French shool of shipmodelling".
I'll follow your log next year with great interest
Regards Christian
Nice planking, the ebony work is very nice.
Michael
super build Giampieroricci,
the hull, framing and planking  Looks excellent, beautiful lines
Nils
Current builds
-Lightship Elbe 1
Completed
I've just found your log, Giampiero. That is terrific work, especially the tricky job of matching the run of strakes above and below the waterline. Very, very nice!
After removing all the nails with the card I started to make a first rough finish with 120 sandpaper to remove excess glue and smoothing the side.
There is still a lot of work, especially in the critical points of the curves more, also I have yet to finish the nailing in the last strakes, remained suspended:
While I carry on the long job of nailing the last strakes, I proceeded to make holes of hawses: their axis is parallel to the keel and have a slight downward inclination, to favor maneuvers hawsers:
I also started the construction of the spur;
To give more strength to the union between ebony and peer I thought to use a plug interlocking between the two species:
Just stunning work, Gianpero.  The carving work is magnificent.
Thank you very much, Mark!
What a beautiful planking job Giampiero!
What are you using to simulate the caulking between the planks?
Oh, and a happy birthday of course ! :cheers:
I'm desolate!  I read just now your question........
To simulate the caulking I used a thin piece of black cardboard 0.3mm
Edited by giampieroricci
I started the construction of the dolphins bow; For these details, very mangy and difficult to achieve, I chose boxwood.
They are made in two pieces joined to scull. After the first attempts, miserably failed  trying to figure out how and where to make that scull, I think I've reached a good compromise: I preferred to keep me abundant at the beginning and gradually refine until the right size;
Bonding:
after a first roughing
tests positioning:
All this is simply superb!!!!
J
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
This is really an excellent result, I'm going to print out your sequence and use it as a tutorial for my Brick!!
Ottimo lavoro!
Fam
Joint building:
   Brick de 24, 1/48, jointly with Jack Aubrey (POB from Ancre plans)
Works in progress:
   USS Constitution Cross Section, 1:93 (POF bashed from Mamoli kit)
Completed models:
   Santìsima Trinidad, 1/90 (POB heavily modified DeAgostini kit)
   Genoan Pinco, 1/50 (POB bashed from Euromodel plans - my current avatar)
   Viking Knarr, 1/72 (POF from Dusek kit)
