Hi - the sanding block has worked for all the flat and convex bits, but I'm struggling with the concave curves at the stern. I'll take your advice, though, and put up some photos on my pages and see what other people suggest.
I've never come across Billings paints (and my son works in a model shop!) - I'll probably just use a Tamiya gloss black.
Forgot to mention, I get my Billings paints of ebay (surprise,surprise)
I have a good selection of Billing's paints........they cover nice and have a really hard finish.  I'm not too happy with the way they are bottled though......some I have opened went bad {dried or gelled}....mainly due to the caps.......the ones that have those stupid plastic cones in them.  after shaking them,  I end up having to wipe the cap out,  before the paint gets into the inner lip.  have you had any problems with this?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
No I've had no problems, but the ones I have are just pots with screw caps and I haven't had them long enough to dry out.
ohhhhh,  your using acrylic.......I have the enamels!  ;)  the bottles are different too.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Alright people, I need to ask for help as I'm stuck. Below you will see a picture of the instructions for the guardrail (Part F663 being 0,8mm brass wire).
I am trying to set up to solder the bits together, the problem I'm having is that everything I use to hold the parts in place acts as a heat sink, I have ordered a soldering board but I don't think this will resolve the issue.  I am using a gas powered soldering iron with the blow torch attachment, so I have plenty of heat, it's just that it is being soaked away from where I need it.
I need to resolve this issue as the Bridge structure is made the same way. All help gratefully accepted.
Glad to see you solved your soldering problem Stuart. The guard rails are looking good.
I'm surprised that the kit didn't supply stanchions with pre drilled holes.......I use them all the time.    would have saved you a boat load of grief.   you did a great job of it though....looks very nice  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi All,
Final installment of the guardrail saga.  As you can see I've finally put the rails in place, a tip if your heading for this bit, do as the instructions say and do the guardrails in two parts.  Making it would have been easier, and installation a breeze.  Having said that if it was easy it would be boring :D
It's a pleasure to see your super work as usual - the bridge looks fantastic! I regret, though, that I have another plea for help. Although I haven't been updating my page I have a reasonable hull now, but as I struggle with the chain plates I'm slowly messing it back up again. I notice you say you'd pinned them - can I ask how you did that, given how narrow they are, and what did you use for pins? I've tried glueing them, but it looks terrible and then springs off...
Hi matey,
Sad to say "been there, done that" which is why I ended up pinning them. If I remember correctly I used a 0.8mm drill, in a pin vice ( I think that is the correct name), which if you are very careful (and lucky) just fits.  I will admit with a few of the plates, I did break out through the side, but you can carefully bend the plate back into shape.  I also ordered brass pins (nails) from Cornwall model ships.  Finally when I pinned them I also re-glued them with super glue, which got them to stay in place.
The advantage of the hull being black is that it hides an awful lot of sins once it is touched up.
Unfortunately I did not find a quick way of doing this task, but as I keep on discovering, be patient, if you try to rush you muck it up.
Hope this is of some use.
Good luck and stick with it.  :)
Thanks once again: I'm off to the garage to try this. Foolishly I started this job on the starboard side, which is the one I'm planning to display, and I fear even substantial amounts of paint aren't going to cover the mess I've made. It's a shame the Warrior never fought a battle, as I could have done a post-engagement version!
Making an excellent job of this kit Stuart. Is the brass on the deck a visual design or is there a physical purpose for this? I've never seen a design like that on a deck. It looks good, keep up the neat tidy work.
Regards, Scott
Completed builds:
Awaiting construction:
Thanks to one of the lads on here who has visited the Warrior.  A picture is better than a thousand words. But I must add the brass runners really do give a nice look to the deck.
Very nice work Stuart,
also an excellent painting Job, love that model....
Nils
Current builds
-Lightship Elbe 1
Completed
  • 2 months later...
I've been out of the country a fair bit recently, but I have finally got the final parts of the stern decoration in place. There is still quite a bit of tidying up to do, but while I have been waiting for the filler to set I started on the upper deck cannons.
A belated Merry Christmas and Happy New year to all.
Evening all,
Thought I had better give an update as it's been a while.  I'm now in the process of mounting the boat davits and the gun port lids to the port side.  As part of the lid mounting I made a jig to hold the lids in place whilst the glue dries, and it's worked fine.
Hi All,
Decided to take a break from the small stuff and complete the stand.  I decided to use a cap tally for the name plate as my freehand painting would not be up to the job, and I'm really pleased with the result.  Just the main anchors to go and I can start on the masts  :D
looking really sweet Stewart
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 2 months later...
Hi all,
Thanks to the usual people for the comments, they are always appreciated.  With reference to my last post and the "Only the anchors to go comment", I missed two little things ( ships boats). As per usual I completely underestimated how long these were going to take, after all they are only small... what a mug :huh:  they are taking for ever, anyway here's the progress
