I was finally able to go through your log Mike.  Your model is amazing.  The work is clean and neat and precise.  If you can get your hands on some apple use Fiebings and you will love the result
David B
Mike,
very very nice progress. Your model is looking fantastic.
Why don't you use simple oil color? I've made different tests as preparation for my build and happy with the results. It's important to use a good quality color (Schminke, Lucas ar two German brands for example). Than you can work with very thin layers of color
Edited by AnobiumPunctatum
Regards Christian
Mike,
Nice model....enjoying your build log.
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
Thanks everybody for likes and comments!
The transom is slowly progressing, but due to pre-christmas chaos I am not sure I will finish it this year.. :)
The honest answer is "because I am really bad in painting and know nothing about different types of paint". Most of the models where I saw really nice wales used wood dye, so I decided to go this way. There are enough variations even with dyes, if I will start trying various paints - I will end up overcomplicating it and getting crazy with dozens of test pieces spread around my apartment :)
You mean your little corner! Actually, it isn't yours anymore since your daughter took possession :)
You can use either acrylic, or oil based often diluted with white spirit. Acrylic dries fast without a retardent, oil based needs a longer time to cure. both have their ad- and disadvantages. A matter of practice and I presume preference ...Im getting a go at acrylic, since I've not worked with it before. I've worked with oil, gouache, water colour, the model oil paints. So far I do like the acrylic, but it has it's limitations, as does any type of paint. You should take into account that wooden boat building is not just about the wood, metal fittings, and cordage, but paint and stains too probably pains to you ;) You'l find a way!
IT is so much easier ...
Carl
My daughter has her own table, but we build on mine, it is larger and all tools are closer :)
Will try acrylic as well! :) I guess in depends on the desired look. I do not want to imitate ebony 1:1, I actually like when black wales are a little bit fuzzy, in this case the grain raised by water based dye is a feature, not a bug. Acrylic will hide the grain? Will see. Scrap wood experiments are a way to go!
It probably will hide it, as it won't go deep in the wood as stain does. You'll might need a few thin layers to get the proper darkness
Carl
The log is not abandoned, just a very slow building due to an upcoming Christmas and everything related to it.
Notches lined up:
Whoopsie, forgot that wings are at an angle. Argh, redoing this piece again from scratch.
Two curved things are in place, one to go and then I can fair it nice and flush:
Edited by Mike Y
Semi-offtopic: got a bit distracted from the build with an idea of doing some small-scale woodworking (jewerly boxes, that kind of stuff). Part of the plan is to also build a nice display case for the Cromwell. The model looks quite nice even when not finished, plus in the case it would be better protected from dust. Plus it is better to build a case while you have an itch to do it :)
Ordered few boards of some basic hardwoods - walnut, cherry, maple. While the wood dealer is milling them to desired dimensions, took some small piece of scrap to practice with milling my own wood. This was a walnut from the edge of a trunk, with a bit of sapwood.
Everything is sooo out of scale :( My tools are tiny. So I can only build tiny boxes.
The piece I got was not square and not symmetrical. Obviously, I do not have a jointer, so squared it on a table saw.
Of course, the saw is too small, so finished squaring with a plane. Which was also super small. That felt, hm, awkward for sure! :D:rolleyes:
Resawing this piece into planks on Proxxon bandsaw was just pathetic. Super slow even on a max speed and the sound was disgusting. The bandsaw was definitely not up to the task.
But after passing it through planer the wood turned out to be beautiful. Very deep walnut pores and grain, but guess that is a feature?
That contrast of sapwood and heartwood is striking, something I can use on some box to create a nice effect if matching the boards correctly.
Walnut on stained white oak.. I turning into a wood junkie...
Edited by Mike Y
Hmmm, normally we would say slightly oversized, with these tools it's largely undersized ;). Nice work on the wood, wth those tools
Carl
Mike
Too bad you are half a world away as I'd offer up time with my tools in my play room.
I completely understand and appreciate the feeling of discovering the beauty hidden inside ordinary wood.
Alan O'Neill
How can one not be a wood junky, Mike?   I've done some jewelry boxes also my Admiral...   a few "big boy" tools are good to have.  But not too many as they get in the way.
Wanted a featherboard for the table saw. Magswitch looked really good: https://www.amazon.com/Magswitch-Table-Feather-Universal-Model/dp/B001DSZ7EC
But I forgot that my table top is aluminum, not iron. So magnets are not working on it :(
So I bought this attachment, because I really liked the material (and it also includes all the hardware, bolts and knobs)
https://www.amazon.com/Magswitch-Vertical-Featherboard-Attachment/dp/B006SJH0SW
It was, obviously, too large for my saw, so I shortened it a bit, cutting off a long middle section and gluing the remaining parts with epoxy, reinforced with a wooden block inside the featherboard:
After squaring and shortening the bolts, it was a perfect fit and it works like a charm:
Edited by Mike Y
A good looking modification Mike. You can probably use the other piece and build a top finger board to hold down the work as well.
Michael
Finally finished the transom.
Last set of notches (aka "macro is brutal")
Horizontal piece also got some of them, on a weird angles:
Glued in, treenailed and masked for fairing:
Fairing was easy, because the smooth curve of the transom allowed to use the plane:
Faired. I made one mistake, one joint is too shallow, so can't fair this junction properly - the wood is too thin and will fall off :(
Too late and painful to fix, decided to leave it as is. Eventually this will become a part of the quarter gallery, so it will be less visible:
Put the oil on it (that was fun, so many surfaces to carefully oil and so many are crossing each other). Can't wait for it to dry, sorry for reflexes due to wet oil! :)
Note that due to a different grain orientation, oil resulted in different colours for different groups of timbers. Light "along the grain", medium dark "diagonal grain" and very dark "cross grain". It is all made literally made of the same piece of wood, I promise! Wood is magic :)
Not everything aligned as it should, but I started with a not very symmetrical transom, at least haven't made it worse. Will pay much more attention to the proper alignment in the next build!
Now I am taking a short break - will shift attention to the jewellery box I promised to admiral, and then will come back to this log with a display case for the model. The model is far from being complete, but it does not stop from displaying it properly, and will definitely help to keep the dust off.
Edited by Mike Y
Beautiful work, Mike.  I agree, the macro is not our friend. Everything from here is just fabulous.
Nice work Mike, I have to agree with Druxey, and although the journey is long it is full of rich lessons for the future.
Michael
Thanks for the nice comments and likes! :)
Finished a draft version of the display case sketch. Would appreciate the critics, it would be cheaper to correct the design issues now than later!
Basic characteristics: 100cm wide, 80cm high and 30cm deep (40' wide, 31' high, 12' deep). Plexiglas (3mm thick) would be used instead of glass (for safety and weight reasons). No glass on the back side, it would be mounted to the wall and the background would be a white wall.
Made out of the same swiss pear as the model. The frame would be made out of square pear stock 2x2cm (13/16').
Here is the overview first:
Front:
(yes, I love scarf joints :D)
Isometric:
(Please ignore the joints in the back, I had no energy to draw them properly, but they be a mirrored copy of the front joints).
The load bearing part is hidden by the "skirt", and is made out of thick plywood bolted to the wall with Big Strong Bolts. Any sort of electrical stuff would be hidden in that cavities as well.
Plywood is covered by the pear "skirt" with a model description carved on it (or inlayed).
The top part of the case would be attached to the wall as well, with hidden screws, but will not take any weight.
Tricky part is the the way it would be opened. Since I will keep model in it and get it out every time I want to work on it, the opening mechanism should be easy to use (multiple times per week). Also, due to asymmetrical nature of the model, I want guests to be able to get it out easily to see the other side.
So the front window is detachable and is held by strong magnets. That means that front frame is split into two parts - one is 1cm thick and hold everything together, and another is also 1cm thick and holds the front glass.
Front frame joints look like this (a bit complicated, but it is a sort of decorative joint, I want it to look nice)
Or a multi-colored version of the same joint, each color is a different wood piece:
There would be a groove inside front part of the front frame, to provide an additional support for the top glass and its frame, since otherwise it would be only supported from sides and will sag over time.
Would appreciate corrections if I forgot to over-think something in this design! :) Is the plexiglas thick enough? I accounted for the wood movement, grooves for the glass are deeper to allow wood to shrink and breathe a bit.
Is the base construction strong enough?
Edited by Mike Y
Looks like you'll be getting some awesome practise in with you're milling machine!
I understand the front framed plexiglass panel being held by magnets so it can be removed easily.
I suspect the plexiglass will keep the wood frame from warping.
Possibly a thin felt gasket glued on the inside edge to keep the dust out?
I confess I like your design.
You could employ a more traditional floating base... a open backed box that slips over the strong support that is bolted to the wall.
That way if someone looks underneath they see a finished face.
A set of strong magnets (or screws) could secure the "box" to the "support".
Edited by AON
Alan O'Neill
I like it. A great way to show off your woodworking and joinery skills. The case should compliment the model.
John
