Peta_V
Posts posted by Peta_V
Few more layers of planks but before I can continue towards the keel it is needed to build the transom. It is build from several pieces and the shaping is necessary. Unfortunately to have a smooth transition between planks and transom I had to sacrificed laser cut nails at the stern. Anyway I had an idea how to renew them, hope it will work but that I leave until the hull is fully planked. The transom looks very nice!
- greenstone, JpR62, DPK and 13 others
- 16
Hi guys,
Thanks a lot for your feedback. Planking was never job for me. I was always in hurry and that is bad. This time I try to 5x messure and than glue.... . Think it pays off. Thanks a lot for following my progress. Ship modeling never dies🍻 it is not for everybody, but for the people who got patience and love wood.,.....I'm So glad I studied EN and became member of this community. Thanks for having me guys!
- robdurant, etsinko, Ryland Craze and 2 others
- 5
- Katoom, riverboat, chris watton and 11 others
- 14
I believe it is ok. 1,5 should be enough to cover that gap but will double check that. Thanks for the comment 👍
- Elijah, Ryland Craze, JayCub and 11 others
- 14
During the night I have complete left side of the bow. I do not have an experience with the POF scratch build but from the builds I see here the Construction is somehow similar (much more simple but some elements are close I think) So a good practice to move level up
I Just dry fited few pairs of the next ribs and the shape is awesome....
And of course I could not resist and have to dry put all the prepared parts together
- JpR62, GrandpaPhil, coxswain and 7 others
- 10
I have the new version in PDF as well. 👌
1 hour ago, DPK said:
Well, I took part in the design, so I know the process. Btw, if there is anything that is unclear in the instruction, you are very welcome to tell. This kit's instruction worked out to be much clearer than the previous one's, but there is always a room for improvement.
Then huge respect and big thank for your work. You guys created truly master piece.
I agree, the instructions are OK and easy to follow so far. The only thing I found so far is wrong numbering in one paragraph in text instructions.
I believe instead of A29 should be A59 as A29 is different part used during stern construction. It is OK in photo book as well as in list of parts but one can easily figure this out. I have the text version from May 2019 so I believe up to date?
PetaV
Just now, DPK said:
I strongly hope that the taffrel piece is not glued to the hull yet
Hi, No it is not! 😮 I'm following the instructions step by step. It just fits so well without any glue or any fixing jig. Great work from designers really!!
btw are you one of them? Or did you already build AVOS? Just asking that you know the process............
thanks
PetaV
On 6/22/2019 at 1:44 AM, etsinko said:
Really great build! Very inspiring. Can't wait to start mine..
Hi Etsinko,
Thanks fot the comment. I'm sure you will enjoy the build same as I do! And I'm looking forward to your building log! 🧐
Here I made a comparison with my Royal Caroline. It is different scale of course but it shows how small "cute" AVOS going to be.
Still it will be impresive model (if I do not mess it up)
I see what you mean, loks like I glued the last timber little bit lower. But that should not be a big issue I hope. I can put there piece of plywood in case it will be necessary. Thanks for the note!
Progressing with the stern. This one was tricky to fix the correct bended shape. I love how the pear wood works together with Black wood.
- GrandpaPhil, riverboat, goetzi73 and 8 others
- 11
58 minutes ago, DPK said:
Have a look at the gap between the latrine door and the last top timber. Looks like something is misaligned.
Hmmmm..... Will double check that. I have noticed the Gap when I assembled that but I thought that it is ok. Not sure what is wrong 🤔
- Elijah and pythagoras
- 2
AVOS by Peta_V - FINISHED - Master Korabel - scale 1/72 (exclusive kit) - Russian tender
Hi, that was exactly my idea. Thanks!
