Peta_V
Posts posted by Peta_V
@Gregoryit is color 868
@Mirabell61 thank you Nils. I love the tone of the pear in contrast with black as well!
- Elijah and Mirabell61
- 2
- Mirabell61, JayCub, lmagna and 17 others
- 20
- Jolley Roger, Edwardkenway, JayCub and 7 others
- 10
- Dubz, lmagna, paulsutcliffe and 7 others
- 10
Bowsprit is now secured in place so I was able to do some testing rigging. I decided to make my own ropes. I rig the jib tack and jib tack guy. I have to say that I'm happy how that turned out.
I have also experimented little bit with the pictures and the setup of taking the picture. So hopefuly There are more details visible. Still it is camera from my mobile phone so no miracles there.
- Edwardkenway, Papa, Dubz and 13 others
- 16
42 minutes ago, Mirabell61 said:
beautiful planking and treenailing job,
a great looking model
Nils
Thanks Nils but the treenails are not my job. It is pre-cut by laser from manufacturer 👍
- Mirabell61 and Fernando E
- 2
Continue with almost invisible details. I have added Iron pins to rudder hinges and simulate iron belts on boat davits using coper tape.
I decided to finaly glue the coamings to the deck. Some holes in the deck were slightly larger then the coming and There was visible space between deck and the coaming. I have used the pieces of the scrap deck wood to fill those holes.
Before
- greenstone, Dutchman, Ekis and 16 others
- 19
Hi Jim,
Very nice! Good to see some progress! 👏
I think you should do the planking of the latrines first before fitting transom. It is easier to sand against the plywood support and get smooth transition. But if it is glued already you will manage to plank it as well.
As the hull is coming closer to finish I have to work on all very small remaining details. This time Just Iron work.
Traveller (it is so small that my poor camera couldn't catch any more details)
Some more eyelets for sanding rigging. With the thimble for bobstay and 2 on each side for bowsprit shrouds.
- Galley Slave, Fernando E, Dubz and 16 others
- 19
- greenstone, Fernando E, hexnut and 12 others
- 15
- greenstone, yvesvidal, Fernando E and 13 others
- 16
@kirill4 Hi mate,
- yes those 4 coils on the photo are ropes supplied with the kit
- the one I tested on the tiller tackles was thread Gutermann 100%PES in colour 868. I have used several sizes and shades to make ropes on Royal Caroline and was very happy with the result.
- I have already found the source where to order. I have order Gutermann MARA 220 in shade 868 (I really like this colour for running rigging). I think this size should be thin enough to create nice thin rope from 3 threads. The delivery time is longer 2-3weeks as they do not have it in stock but that should be fine as there are plenty wood work on AVOS still to do.
- thanks for the links, these are some lovely looking ships
- This is example of my own ropes using Gutermann thread. 868 shade is used for deadeyes lanyard. It is little bit more brown in reality.
Hi @ccoyle
Could you do me a favour and drop the link to your Sherbourne built (if available) I'm finding inspiration for the tackles
Thanks a lot!
Thanks a lot @Gregory, will try that!
Did I say that binnacle house was small? Here is the first gun assembled. The square on the pad is 1cm. Even it is very small it is very very detailed. My plan was to fully rig it with tackles (not included in the kit). Not sure if it will be possible but will try what I can do!
I have received those testing blocks with hooks Just for this purpose. I think it could work. Blocks are only 2mm. Will see.
- Fernando E, hexnut, muratx and 8 others
- 11
8 minutes ago, Gregory said:
Are you referring to coils looped over belaying pins or coils on the deck ( or both ).. I don't have access to my photos right now, and I'm sure others will join in..
My method is to get the rope saturated with a very thin white glue mixture, and create a coil/bundle resembling photos I have found. I have a jig I use that I will show you later.
Once the glue dries, there is still some flexibility, it behaves sort of like wire; and I proceed to set it up on the boat, keeping it in place with more white glue that isn't visible.
Hi Gregory,
now I'm most curious about coils hanging from belaying pins or cleats but I guess both will be used on the model (once rigging guns for example). I would appreciate your pictures once you have some time to spent
thanks a lot.
This is my biggest trouble with supplied ropes. Each diameter has different colour. The 0,2 and 0.3 have greenish tone. I would be happy with 0,4 but 0,5 is too White to my taste. I do not want the ship looks like X-mas tree after all the hours I have spent on it.
As I said I still have to find some good material to work with!
- BLACK VIKING and lmagna
- 2
3 hours ago, kirill4 said:
Good day ,
Peta,
Very good, accurate, precise and " sharp" work You did!
Watch it with pleasure...but the "ropes" , you used ... :(...they somehow drops out from the entire style of the model...
Agree with Dubz, could it be replaced for (?self made ropes as option?), with more realistic looks?
there are a few very simple rope making mashines on the market I saw, but the ropes which You made by yourself will looks much, much better, than just ordinary ,unprocessed threads You used now...
Hi Kirill4,
thank you very much for your comment. I got your point, I'm still trying to figure out the rigging (material). I got my rope walk, serving machine etc.. (you can check my Royal Caroline if you want....
in AVOS case, there are more things to consider
- the picture really does not show how does it look like in the reality (it looks much better). And as I said the quality of the rope supplied with the kit is really high, I just do not like the colour.
- my biggest issue is the scale. This rope has diameter 0.3 (in the kit). the thread I use is little bit thinner but if I make rope 1x3 from it it becomes to thick. If it is black rope I do not have problem, I have thinner threads so I can make thinner ropes. Unfortunately I haven't found source in my country where they sell thinner thread in the colour I would like to use (they sell only black or white). Anyway I have found some abroad so I'm going to order and create the "real rope". I doubt this is the final solution.
for all my followers,
could you please advice what is the good way to make a coil from rope? I found some tutorials but it is not what I would like to use. Thanks a lot!
PetaV
- Ryland Craze, JpR62, lmagna and 6 others
- 9
AVOS by Peta_V - FINISHED - Master Korabel - scale 1/72 (exclusive kit) - Russian tender
Testing time....... I have created test battle station to work on the artillery rigging. I have chosen this picture as a reference and will do the tackles like this.
This is my interpretation in the scale. The breeching rope is easy. For tackles I use 2x 2mm single blocks with hook strap. The brass eyelets will be replaced by nicer ones on the ship. I run the rope several times through the eyes for tackle hooks and secure in the middle of the tackle. This partialy hides the blocks which is good and I think this is not very common on the models. I like it lot. What do you think?
