Everything posted by EJ_L
She is looking very nice to me as well! I also think that you have installed the wales correctly. In all of the cross section drawings I have seen of planking layouts, the wales are the planks for that area and do not sit upon other planks. I am far from an expert on this and would be greatly interested to know if this ship was possibly built different.
- 371 replies
Trying to scale different drawings to be the same accurately can be a challenge. For myself, I have found it easier just to do the math and convert everything myself if I have a good starting point. For instance, I am working on designing a cross section of my La Couronne model. That ship was in 1:100 scale. I want to build the cross section in 1:87 so that it is a little bigger for details and easier to find proper scale figures for. To do that, I have begun to take the model dimension at 1:100 scale, convert those into 1:1 and then scale back down to 1:87. It takes time to do this but I don't have to worry about the the drawings not scaling properly. Also, there are truly only a few dimensions that I really need from the drawings, the rest is mostly reference with sizing and locations being figured from books on standard building practices.
- 244 replies
- heller
- soleil royal
CA would be my go to, you just have to make sure everything fits perfectly before gluing. However, you could also look into a slow setting epoxy glue as that would give you more work time but will hold very tight once it sets up. Typically, they are two part epoxy that you mix together. Depending upon the ration of the mix determines how fast they set up.
- 91 replies
- deagostini
- vasa
It is in the alignment. If the two drawings are the same scale, keep your keels on the same plane. With the way the stern leans outward, it cannot line up with the center line as you have it. However, if you keep your keel always on the same plane, when you look at the different view points, those images should line up. Think of it as a box. Hold your profile sheet up as though it were the front of a box. The stern image would then be a side. The bottom edges are all in the same location. Done this way, they should line up.
- 244 replies
- heller
- soleil royal
Planking is moving along fairly well. No, the planking is not the greatest job but as this is the first layer, sanding and filler will take care of the imperfections and the veneer layer will make everything look nice. It will be done correctly. It has been a while since I have planked a round up stern, most of the ship’s I have been building are square stern. Round up takes a lot more planning on the plank widths to make it right. I also layed out the gun ports and drilled the corners so I do not loose the locates during sanding. The planking around the cabins has been left off in order to allow the interior builds to continue easier. These pieces will be installed later. Now I have to repeat the process on the opposite side. Lots of work still to go.
I have not done it myself, but there are a lot of videos on youtube that show how to remove scratches from glass. I would assume that yours would not be very deep given how they were made and so, one of these techniques with the buffing compound should work. -Well, after I posted that, my page refreshed and all of those better responses popped up. Gotta love technology some days... 🙄 By the way, work on the ship prior to the whoops, was looking great!
It is good to be back. I wasn't planning on staying away for as long as I did, but every time I finished something on Soleil Royal, I kept deciding to do one more item. Then I found myself close to finishing the hull work and had to continue till it was done. Now, I can work on R.L. for a while as I am no where near ready to begin rigging.
At long last I’ve returned to this build. Spent some hours routing the wiring for the cabin lights where it needs to travel through the hull. This has allowed me to start the first planking layer. So tonight I cut the rabbet along the keel and have laid the first couple of strakes. Once I get the first layer of planking up that will allow me to cut away the oversized deck and hull supports and finish deck planking and the interior buildouts and also continue. Lots more to come as the ship starts to take shape.
So what you are saying is that you plan to keep things simple.... 😛 I may be far off base but I didn't think that the deck planks narrowed forward and aft. Obviously the hull does as they have to due to the curvature of the ship, but I was of the understanding that the strakes for the deck remained the same width across the entire length. I have seen them terminate differently with some simply stopping where they intersect the waterways and others that notch into a sort of perimeter board that follows the curves of the bow. I do not know the appropriate terminology off the top of my head.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
The rigging is coming along very well. Taking your time and planning ahead so you can understand what the various ropes are doing makes it go a lot easier and you seem to be doing that just fine. Very happy that you took up the challenge to rig her properly instead of using the plastic formed shrouds. With all of the effort you have put into the build, I think those would have detracted from it. Well done!
Skids and ladder are installed on both sides. I have also added a couple more decorations on the upper quarter galleries. With those pieces, the ship’s hull is basically complete. The only other major structures left to build are the ship’s boats and cradles which are more of a separate assembly in my opinion. I will likely be pausing on this build for a while to spend some time on the Royal Louis build. When I return, the boats and masts will be the priority.
- 961 replies
- 961 replies
I'll keep my eye out for whichever you work on. Sounds like you have some good choices.
- 122 replies
- tamiya
- King George V
Carl, I was just thinking the same thing! I don't think I ever would have thought to have run the rope while they were still attached to the sprues either. Sometimes the simplest solution is staring us right in the face. :)
Very nice and well done. Another ship off to the fleet. What is next in the shipyard?
- 122 replies
- tamiya
- King George V
Cardinal sin?... no. Black or dark brown rigging was not the actual color of the rope but was caused by the tar that was applied to the standing rigging to protect it from salt, sun and wear. The running rigging was left in it natural state as it was in constant use and the tar would have fouled the blocks and sails not to mention the mess it would have created on the sailors themselves. Seizing would have been either coated in tar or left bare in relation to the use of the rope it was bound to. As for models, black thread is common on seizing, not so much for historically accuracy, but for making details pop out more on the model. At the end of the day, what matters is if you like it as it will be on display in your home. I have done it both ways myself.
Nice work on the yards and well done on those knots! Wow! Looking forward to seeing what you do with the sails.
- 786 replies
- Royal Louis
- Finished
Thank you everyone! Working on the skids this week. I made a template out of a note card that I can transfer to the wood. Traced it out and am ready to start cutting. I plan on doing a test piece first and if everything works out, I will progress to the rest. There are five skids on each side. Two of which will frame the ladder.
- 961 replies
I've always been a fan of two builds, especially when building large or very long duration models. It gives you ways to take breaks from monotonous tasks while still enjoying the hobby. Will keep an eye out for the new log.
Beautiful work thus far! Those added and improved upon details are making her so much more than a "out of box" kit. Wish we could have been on this journey with you from the start, but there is still plenty to see so I think I will pull up a chair.
Thank you all for the words, likes and following along. Jonathan, welcome to the build! I finished with the starboard broadside today. Now, just a few details left to go and then the mast and rigging will start.
- 961 replies
As many others have said, take care of yourself and family first. The hobby, as well as all of us will be here wishing you the best and ready to either resume Licorne or follow whatever the next project is.
All of those PE parts are a pain to install I'm sure , but WOW!! They sure do make a model come to life in a breathtaking way. Well done!
- 122 replies
- tamiya
- King George V
