Everything posted by gjdale
Congratulations on finishing a fine model - she looks superb on that display base - what a great idea!
- 366 replies
- granado
- caldercraft
Congratulations Danny! No surprise to me, but nice to see you get the recognition you so thoroughly deserve.
Congratulations on completing a truly fine model Vince. You can be justifiably very proud of your achievement.
- 593 replies
- royal william
- euromodels
For Landlubber Mike, Paul Budzik, who is an occasional contributor on this forum, has his own website and has produced a number of very useful videos about airbrushes (and other aspects of modelling), how they work, how to use them, and which one is right for you. The videos are really well done and worth a look. Here’s a link to his site: http://www.paulbudzik.com/tools-techniques/Airbrushing/airbrushing_for_modelers.html
Great to see you back working on your fine model Mike.
- 969 replies
- hahn
- oliver cromwell
Nice to see you back Bob - it’s always a delight to follow your builds,
- 78 replies
- medway longboat
- Syren Ship Model Company
Congratulations - that looks like a real find! All that extra tooling is probably worth more than the lathe itself - what a bonus!
- 525 replies
- cutty sark
- mantua
Congratulations on another fine build B.E. Your logs are always a pleasure to follow and I look forward to your next project.
- 574 replies
- cheerful
It’s all been said already Ed, so I’ll just add another voice to the throng. Thank you for an inspirational journey - this truly is a masterpiece of modelling.
- 3,618 replies
- young america
- clipper
There are tabs there Jim - they just don't show well in the photos. I may re-visit these anyway before I glue the frames to the keel. Thanks for the close scrutiny - it's nice to have a pair of eagle eyes checking things. It certainly wouldn't be the first time that someone has saved me from myself! 😊
- 109 replies
- medway longboat
Thanks for the observation Jim. It was hard to tell from Chuck's photos just how much tape he used. Is there a down side to the extra tape?
- 109 replies
- medway longboat
It's been a couple of weeks, but I did manage to get some 'shop time' in this weekend. The four additional 3/32” keel pieces were then fit, following the advice in Chuck’s instructions. I used some scraps of 1/32” material to ensure that these pieces were centred on the 5/32” thick keel. I then traced the keel bolt locations from the plan sheet and used this to mark the bolt locations on the keel. Holes were drilled using a #70 drill bit to provide a tight fit for the kit-supplied 25lb monofilament fishing line that simulates the bolts. These were dipped in glue prior to fixing in place. Once the glue dried they were trimmed with a single edge razor and sanded flush. The whole assembly was then given a coat of satin Wipe-on Poly. I then made my first real boo-boo…. When fitting the transom piece, I glued it to the wrong side of the stern post! 😱I didn’t realise this until I went to test fit the single frames with the keel. Fortunately, a little isopropyl alcohol and some patience enabled me to de-bond the joint without any significant damage. I cleaned up the locating slot using some of my Russian micro chisels (thanks Mikhail😊) and re-glued the piece on the correct side. Phew! (Was too busy fixing the boo-boo to take a picture!) The single frames were then prepared just as Chuck advises. I used packing tape to cover the laser cut on both sides of each frame, and then added some reinforcing pieces using some 1/32” x 1/8” cherry strips that I had in my stash. I then tested and adjusted these for a snug but not too tight fit in the build board and the keel notches. I next made up all of the two-piece frames, again following Chuck’s instructions to the letter. The laser-cut reference line makes this a very simple process. All of these frames were then tested and adjusted in the build board and the keel slots. The frames are now ready for permanent attachment to the keel.
- 109 replies
- medway longboat
Looking really sweet Mark. I hope you spent the dime wisely...perhaps on some TicTacs, the international unit of scale measurement! 😉
Eiffel Tower by Mark Pearse - father/daughter build - WOOD
gjdale replied to Mark Pearse's topic in Completed non-ship models
What a great thing to do with your daughter Mark! You can both be very proud of the results. -
Thanks for the tips guys. Her only real concern was potential damage to the model, so my “temporary” solution is no real problem - will only be “temporary” until she forgets that it’s “temporary” and then it is “temporary” no more!😄😁😁 Our son dropped in for a visit yesterday and thought it was a really cool model, so another vote of confidence to help it keep its place.
Always a joy to follow your work Karl. I’m in.
- 87 replies
- royal caroline
- yacht
